DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
#1 | ||||
Head Hurt
Simplified Lunchbox Delete (2008 Focus Sedan)
The “Lunchbox” in this case is the resonator at the end of the exhaust system closest to the exhaust tip. Here's a good link to "How the Exhaust Works", including the resonator. http://auto.howstuffworks.com/muffler.htm I would like to credit the original thread that I received this idea from written by Jamussport of FF. That thread can be found here: http://www.focusfanatics.com/forum/showthread.php?t=161083 My instructions retain the original exhaust tip (thank you Derek Zoolander of FF for this revision), if you would like to replace your existing exhaust tip while you make this modification refer to the thread above. Removing the rear resonator will give your exhaust a new, louder tone. Don’t expect NASCAR sound out of this, we’re talking about a Focus here after all. Here’s a sound clip of mine after removing the resonator. However, I do have a Steeda SRI installed which by itself already adds to the sound from the stock exhaust. I tried to get a sound clip while driving, but with my recorder the wind and road noise washed out the exhaust on the recording no matter where I placed the microphone. And, I swear, I wasted a ¼ tank of gas trying to get that recording! http://s286.photobucket.com/albums/l...hboxDelete.flv Cost: Approximately $17 plus tax Time to Complete: 45 minutes to 1 hour This time will vary greatly depending on what tools you have available to cut the exhaust with. See “Tools Required” below. Material Required: 18” (51mm) of Flexible Exhaust Pipe - 2” inside diameter $5.99 AutoZone part #17033 – "Flexible Exhaust Repair Kit" is an 18” piece of 2” I.D. flex pipe which includes (1) 2” Exhaust Clamp. (1) 2” Exhaust Clamp $2.49 AutoZone part #17124 (1) Exhaust Joint and Crack Seal $2.99 AutoZone part #00160 (or exhaust seal/cement or your choice) (1) spray can of Hi-Temp Paint $5.49 AutoZone part #DE1634 Low Gloss Black Engine Enamel (use any hi-temp paint/color you want) Tools Required: Reciprocating Saw with metal cutting blade / hacksaw can be used (see note below) 3/8” and/or 1/2" socket or box end wrench (to fit exhaust clamp nuts) Sandpaper (pick a grit between 120 or lower, you’re just scuffing the pipe a little with it) Manual or Hydraulic jack Jack stand(s) Wheel blocks Note: A reciprocating saw (Sawzall) makes this job a snap. If you do not own one, buy one or borrow one from a neighbor. This job can be done with a hacksaw however Jamussport (see link above) required 2 ½ hours just to remove the resonator using a hacksaw. Now that man was determined! HarborFreight.com has a reciprocating saw available for $39.99, not the highest quality tools you can find but perfectly acceptable for occasional jobs. Instructions: Locate vehicle on a solid level surface Make sure it’s in PARK or 1st gear Make sure the PARKING BRAKE is set and set good Block front wheels Now go back and make sure it’s in PARK or 1st and the PARKING BRAKE is set. SAFETY FIRST: Allows use jacks stands when you are working under a vehicle. Please DO NOT skimp on this, many a weekend warrior has died when the car slipped off the jack. Raise left rear to provide access to resonator (position jack correctly on vehicle to avoid damage) Set Jack Stand(s) in place Note: Service ramps are a great time saver and I believe them to be much safer than using an individual manual or hydraulic jack. For $39.99 you can purchase a pair of 8000lb Rhino ramps at AutoZone. SAFETY FIRST: Use Jack stands even with service ramps, look under my exhaust tip, you can see one there and there is another one on the other side out of view. ![]() Remove Resonator The resonator is the lunchbox looking thing welded to your exhaust tip (sorry no picture of it in place, but see removed resonator picture below). Remove it! Here’s a picture of mine after it was removed. The cuts I made worked out great for installing the flex pipe. You can adjust these cuts to suite your preference. Just remember “measure twice, cut once”. ![]() Install Flex Pipe Clean the outside of existing pipe where the flex pipe will overlap it, about 2 inches should do. Also scuff this area with sandpaper to allow for better adhesion of exhaust seal. I wore rubber gloves for the next part, do not get this stuff all over your hands. It is labeled "WARNING! Eye, skin and respiratory irritant". Apply a liberal amount of exhaust seal to the outside of existing pipe (the area you just cleaned) and to the inside of the flex pipe before you slip the flex pipe on. Slide flex pipe on, bending to position tip correctly. (fine tuning of tip position done later) Now apply a liberal amount of exhaust seal over the end of the flex pipe and existing pipe; fill any gaps between the two. Use enough seal so you don’t even see the joint, basically blend the flex pipe into the existing pipe with the exhaust seal. Install exhaust clamps (one on each end) and tighten. Position the ends of the clamp up toward the bottom of vehicle so you don’t see them sticking down when viewing the vehicle from the rear. Check the exhaust seal after tightening clamps, add more if required. Take a look at your exhaust tip (from behind the car), is it straight and centered? Adjust flex pipe until it is. Except for painting you are done and you want to wait until after the exhaust seal is dry enough before you paint it. You could of course paint the flex pipe prior to installation, but I was not that smart. You can leave the car in position and wait, or carefully lower the vehicle and drive it. The heat from the exhaust will help set the exhaust seal. I painted mine after driving for about 10 minutes. Yes, you do want to paint the flex pipe. Flex pipe is notorious for rusting quickly; the paint will help delay that process (a little). If this is a permanent addition you might do well by finding an exhaust shop that will bend and weld an actual piece of exhaust pipe in place at a reasonable price. Also, if you move the flex pipe (or it moves on its own) after it’s painted it will expose unpainted areas. Watch for those and hit them with a spray of paint. Below are pictures of my completed installation (including paint over spray on heat shield, oh well). ![]() ![]() ![]() You better appreciate the shine on the tip. Took some time with bug and tar remover and steel wool followed by a waxing to get it looking good again all just for that picture. Well that’s it; I hope you find these instructions helpful. If I can clarify, correct or just answer a question please don’t hesitate to PM me.
Best wishes and keep on modding April 2009 SOTM, July 2009 ROTM, 2009 FF ROTY RIFF CREW, Sedan Revolution #137, TEAM Duratec #181, Bremerton Raceway #658, NW POSSE #6 |
Remove Advertisements |
Fan#: 1
#2 | ||||
the flex pipe sure looks redneck... i got my res removed at my job for about 25 bucks (employee rate)
2010 Ford Fusion S 2.5l 4cyl 6MT |
#3 | ||||
Head Hurt
Must be nice to work somewhere you can get it done for $25 bucks. My local shop wanted $125 plus tax. Kiss my Mine is temp until I find the full catback I want. I did suggest that those leaving this on permanently check their local shop for a real pipe welded in at a decent price. Maybe if you could read, instead of just looking at the pictures like your magazines, you'd have noticed that.
#4 | ||||
Lol...burned...anyway I was asking how to do this and low and behold Brad comes through again! I asked my local shop and the cheapest was $85 so yeah...screw that! I think I might just go do this today or tomorrow pending how much time I have.
Sun Hyper Ground Kit, F2 Short Throw Shifter Airbox & Rear Resonator Delete, Custom Grille FocusNation #57 Team Duratec#713 |
#5 | ||||
nice 08 lunchbox removal instructions.
Done: Debadged,Tinted, MBRP SS 2.5 exhaust, K&N CAI Soon: tinted sidemarkers Last of the Hatches #48 Team DURATEC #151 SAP Krew #4 |
#6 | ||||
yeah i did the exact same thing you did about a week ago though only cost me 8.88 at advance lol company accounts gotta love em
#8 | ||||
Great write up brad, thanks for the shout...
Sure looks great, called mike on friday but he was out every time i tried... gotta get back on it on monday |
#9 | ||||
just for the record... if you offer cash a shop may do it for as cheap as $30... i did so and i got the response "government doesnt need to know." basically it was a 30 dollar tip when i had it done
TEAM DURATEC #72 : LAST OF THE HATCHES #39 : SAP CREW #5 "Death smiles at us all, all a man can do is smile back" "Sticking feathers up your butt does not make you a chicken." "True knowledge exists in knowing that you know nothing." |
#10 | ||||
^^^that didn't fly with any mechanic i talked too. and they even ran private shops. [I] hate my area.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lunchbox Removal Q's | SpecialEd | DURATEC Performance (2003-2011) | 47 | 08-14-2008 07:26 PM |
| * * * * C o m p l e t e ' H o w T o ' A r c h i v e * * * * | S2 | Member FAQ's & How-To Information Archive | 5 | 11-21-2006 08:54 AM |
| To hack the lunchbox or not...Tis the "?" | R00ST650 | SVT Performance (2002-2004) | 31 | 10-18-2005 06:24 PM |
| AC removal instructions | lparks | SVT Performance (2002-2004) | 11 | 10-28-2004 12:34 PM |
| Panel removal instructions here | sa_pyro_ne | Car Audio, SYNC, MyFord Touch & Electronics | 2 | 04-07-2004 11:12 PM |
