SVT spdometer cluster into 2.0 zetec zx3. Can it be done? - Page 2 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 06-01-2008, 09:47 AM   #11
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
i would say just get speedhut to make you some.....its gonna be such a pain. A focus guy had them in LA and he couldn't get the face to light up worht shit. you need the AUX gauges, they have the curcuit bard in them that powers the face. And it's not just 12V, it's all converted to some wierd shit......have fun!!!
HaveBlue83 is offline
Old 06-01-2008, 06:18 PM   #12
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
i woild try an inverter first. as far as i know the extra gauges jsut power themselves lighting wise by pluggin into the extra harness end that noremal zx3's dont have.
i ahve not had an issue with mine at all. and i see waht you mean with missing a bit more. the whole panel is gone... but i dont care....
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 06-02-2008, 05:43 AM   #13
<focusONthis>
<focusONthis>'s Avatar
Fan#: 55388
What I Drive: 2002 silver ZX3
FF Reputation: 1 <focusONthis> Good Standing Member
Buy-Sell-Trade Rating: (6)
I found an SVT cluster on eBay for $50. It has almost the same amount of miles on it as my car. It has a 90 day warranty. And says it works perfect. U think this is a good deal or is it 2 much 2 deal with?
Killerzetec, u installed your SVT cluster without using a power inverter?
(off topic) static-x is a good band.
<focusONthis> is offline
Old 01-12-2014, 08:38 PM   #14
nitrous focus
nitrous focus's Avatar
Fan#: 119564
What I Drive: 02, liquid gray, power premium Zx3
FF Reputation: 1 nitrous focus Good Standing Member
To make them work correctly you need the aux gauges and the wiring pigtail for it. You will need to have the wiring diagram. The main cluster gets it power for the back light from the aux gauges. I did it on my 01 zx3 if done correctly the brake light will go off as well as the ABS light.
nitrous focus is offline
Old 01-13-2014, 12:29 AM   #15
TexasFoCi
Fan#: 118867
What I Drive: 2001 ZX3 5 Speed with 255,000 Miles
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Level Up 49% Completed
FF Reputation: 2 TexasFoCi Good Standing Member
I have the SVT Cluster installed and I have the AC Inverter.
I have no idea what to do with the INverter besides ground the black wire. ANy insight to powering it and conncecting it.
TexasFoCi is offline
Old 01-14-2014, 12:25 AM   #16
TexasFoCi
Fan#: 118867
Has anyone ever used the inverter from speedhut??
Old 01-14-2014, 01:40 AM   #17
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,210, Level 51
Points: 6,210, Level: 51 Points: 6,210, Level: 51 Points: 6,210, Level: 51
Level Up 30% Completed
Forum Activity 8%
Buy-Sell-Trade Rating: (22)
I used an inverter off of ebay.
It does work,
The Brake and ABS lights did stay on my non-ABS car. I did remove the ABS bulb. The Brake light is on all the time. This can only can be turned off by having the Dealership reprogram the cluster for $110.00
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 01-15-2014, 02:01 PM   #18
TexasFoCi
Fan#: 118867
It does work,
Ok cool, how do you make it work , my inverter has a white power, black ground, and another wire that has female plugs coming out of the inverter , not sure what do do with it besides ground the black wire. Can anyone help?
Old 01-15-2014, 06:10 PM   #19
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 8%
The one that has the dual wires and plug go into the connector on the top backside of the cluster housing. They are the 2 red wires.
Hatch Nation #140
freemind is offline
Old 01-20-2014, 04:23 PM   #20
TexasFoCi
Fan#: 118867
Installing SPEED HUT Inverter
HOW TO: Speed Hut Inverter
OK Figured it out. If anyone is doing the conversion using the SPEEDHUT Inverter, this might help.
Tools:
SpeedHut Inverter
A Roll Electrical wire
Crimping Plyers
Electric Tape
Couple screws
The Speed hut Inverter has a WHite wire, Black wire, and a double black wire with different connectors on it.
The WHITE WIRE (Power) I extended with some electrical wire and it connects to PIN 13 on the light switch Harness. This is a orange and yellow wire. the PIN bracket easily disconnects from the light switch. I just took a razor blade until some of the wire was bare and wrapped the wire on and then wrapped with electrical tape. Below, the picture on the Left shows the light switch bracket. Orange and Yellow wire is 13. Whatever you do, Don't cut the red wire, the bomb may not defuse.
Diagram 202. Shows which wire to tap into (PIN 13)
http://www.autozone.com/autozone/rep...96b43f802e8246
The BLACK WIRE (Ground) I also extended this wire with electrical wire and then connnected it to the Steel frame that holds the fuse box on the driver side. This is a great place to ground any wire, It connects to the frame.
THe remaining (Lighting Wire) wire consist of a long band of black, 2 strand wire that has 8 seperate connecting pins. They are all useless. I cut the wire where the first Pin started and then Spliced the 2 strand black wire to make 2 seperate Wires. These 2 wires connect to the top 2 RED Wires on top of the SVT CLuster. Works well except I still have a parking brake light.
Similar Threads
Can u put a Zetec SVT Engine in a Zx3 ? Sh311 ZETEC Performance (2000-2004) 20 12-24-2005 10:41 PM
Difference between 2.0 zetec and svt engine QuickSilverSVT Focus-Power Tuning 10 05-20-2005 08:10 AM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
