SVT spdometer cluster into 2.0 zetec zx3. Can it be done? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 05-30-2008, 05:42 AM   #1
<focusONthis>
<focusONthis>'s Avatar
Fan#: 55388
What I Drive: 2002 silver ZX3
FF Reputation: 1 <focusONthis> Good Standing Member
Buy-Sell-Trade Rating: (6)
I wanted to know if the svt speedometer cluster gauges with the two extra gauges it comes with could be put in a non-svt with a 2.0 zetec. I don't need it but I think they look nice. White face gauges with SVT logo. Can it be done? Will the gauges read the right way? And what do u need to do this?
<focusONthis> is offline
Old 05-30-2008, 05:46 AM   #2
<focusONthis>
Fan#: 55388
it'd be a nice little upgrade.
Old 05-30-2008, 06:55 AM   #3
foci01
foci01's Avatar
Fan#: 41223
What I Drive: 01 Twiligh Blue SE 4DR Sedan
FF Reputation: 1 foci01 Good Standing Member
AFAIK the cluster itself will go in but the 2 smaller guages (oil pressure+temp?) are a PITA to install.
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy crap..What a ride!"
SEDAN REVOLUTION#23
foci01 is offline
Old 05-30-2008, 07:38 AM   #4
slipster17
slipster17's Avatar
Fan#: 37217
What I Drive: 2011 Yellow Blaze Fiesta SES
Points 4,068, Level 40
Points: 4,068, Level: 40 Points: 4,068, Level: 40 Points: 4,068, Level: 40
Level Up 59% Completed
FF Reputation: 16 slipster17 Great Standing Member
Buy-Sell-Trade Rating: (11)
heh, just answered this question for a gentleman on the other forum as well.
as long as it is a pre-05 car you own then the main portion of the SVT gauge cluster (speedo, tach, fuel and water temp) are plug and play. The axillary gauges from the SVT however (oil temp + pressure) cannot be installed as the non-SVT models lack the wiring harness for it.
You will also need to go buy a power inverter to connect the electroluminescent gauge face to. Like this one from Speedhut:
http://www.speedhut.com/product_deta...NUMBER-368.htm
The only other thing to keep in mind is the milage on your current odometer. Write it down and keep it someplace you will remember it. This is because although your cars milage reading is calculated and stored in the ECU, the value is saved in the cluster as well. So when you plug in the SVT gauge cluster, your cars odometer will show the millage of the SVT it came out of. There is debate as to whether or not the ECU and cluster can be synched up again and how much it might cost at a dealer.
I installed an SVT cluster in my car right around 100k miles and instantly got a car that read 37k miles The value may not seem very important, but if you ever want to trade the car in, I really recommend disclosing the cars actually millage over what the odometer reads.
Hope that helps!
April 2010 ROTM
2011 Yellow Blaze Metallic SES Fiesta hatch
Carlisle All-Ford Nationals 2011 1st Place - Fiesta Class
slipster17 is offline
Old 05-30-2008, 02:20 PM   #5
<focusONthis>
Fan#: 55388
I've got an 02 zx3. What does the power inverter do? Does it light up the gauges?
Old 05-30-2008, 02:40 PM   #6
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
the inveter is for the electrolumenescent palnel the evens out the green gow. with out it you get a strang glow like i have here
the paels wiring will be on top of the cluster. mine was missing it and i installed it anyway. the cluster still works and i thingk its really cool like this
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 05-30-2008, 03:10 PM   #7
slipster17
slipster17's Avatar
Fan#: 37217
I have seen yours before as well. It is quite cool in my opinion, but you are missing a little more than just the wiring for the EL glow, heh. Whoever had the cluster before you actually took the time to peel the EL glow layer OFF of the hard silver backing and then pasted it back onto the clear plastic base.
The SVT gauge clusters don't light up via bulbs behind the cluster like non-SVT models do. The whole face of the gauge lights up about the same color green as your trip/odometer box, while the numbers remain black. I only have one sucky picture of it at the moment. This is what the SVT gauges looked like when I first put them in. The REAL ones light much brighter. Mine is so dim on account of not having the correct inverter installed; the EL gauge face isn't getting enough power.
And a stock one with the bulbs behind the cluster shining through the green numbers.
April 2010 ROTM
Old 05-30-2008, 04:20 PM   #8
<focusONthis>
Fan#: 55388
so i just need to get the right power inverter and i shouldn't have a problem?
Old 05-30-2008, 08:08 PM   #9
melbzetec
melbzetec's Avatar
Fan#: 10307
What I Drive: 2003 Machine Silver Zetec
FF Reputation: 2 melbzetec Good Standing Member
As well, these gauges work off the ECU. Therefore, even if you tried to wire them in they still won't work, as the standard ECU won't drive them
FR Head milled .040". FR Stage 2 cams, Pipercross Viper intake, Ford Racing long header, RT Hi Flow cat, Herrod Motorsport 2.25" stainless catback, Quaife LSD, Eibach Pro-kit, Wilwood 13" brakes
cardomain.com/ride/2773918/1
melbzetec is offline
Old 06-01-2008, 09:21 AM   #10
<focusONthis>
Fan#: 55388
so just a power inverter and I'm good? I'll leave out those 2 small guages.
Similar Threads
Can u put a Zetec SVT Engine in a Zx3 ? Sh311 ZETEC Performance (2000-2004) 20 12-24-2005 10:41 PM
Difference between 2.0 zetec and svt engine QuickSilverSVT Focus-Power Tuning 10 05-20-2005 08:10 AM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
