HOW TO: FRPP (or any) Lowering kit (springs, shocks, dampers) - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-06-2009, 02:40 PM   #11
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,634, Level 94
Points: 23,634, Level: 94 Points: 23,634, Level: 94 Points: 23,634, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
Google search ftw awesome writeup I will be using this for my setup in a couple weeks maybe
mikebontoft is online now
Old 09-06-2009, 07:15 PM   #12
Phacade
Chronic Curmudgeon
Phacade's Avatar
Fan#: 32246
What I Drive: '03 EAP SVTF
FF Reputation: 11 Phacade Great Standing Member
Buy-Sell-Trade Rating: (7)
Great writeup!
I mock your cheese danish and all it stands for!
Phacade is offline
Old 07-21-2012, 03:15 AM   #13
RAF_S197
RAF_S197's Avatar
Fan#: 91991
What I Drive: 2014 Oxford white Sport Black Pack
Points 7,515, Level 57
Points: 7,515, Level: 57 Points: 7,515, Level: 57 Points: 7,515, Level: 57
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
Forum Activity 12%
FF Reputation: 21 RAF_S197 Great Standing Member
Awesome write up! I'll be using this as a guide to install my FRPP kit next week. Thanks!!!
2014 Oxford white Focus SE Sport Black pack
Instagram: 5_POINTOH
RAF_S197 is offline
Old 07-21-2012, 03:20 AM   #14
LiciouzSVT
LiciouzSVT's Avatar
Fan#: 83568
What I Drive: 2013 Performance Blue ST
Points 1,170, Level 18
Points: 1,170, Level: 18 Points: 1,170, Level: 18 Points: 1,170, Level: 18
Level Up 70% Completed
FF Reputation: 1 LiciouzSVT Good Standing Member
Buy-Sell-Trade Rating: (6)
Nice write up bro! I should have take. More pics like this when I did my suspension! Wanna see pics of it lowwwwwws
2003 Screamin' Yellow SVT - Wrecked
2004 Silver SVT- Sold
2013 Performance Blue ST- BEASTY
LiciouzSVT is offline
Old 07-21-2012, 07:52 PM   #15
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Your lucky as hell that the rear LCA bolt came out easily.
I had to cut mine, both sides.
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 07-27-2012, 03:18 AM   #16
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Forum Activity 12%
Does anyone have a write up on how to assemble the springs onto the struts?
RAF_S197 is offline
Old 10-08-2013, 02:11 PM   #17
formnewbie19
Fan#: 119601
What I Drive: 2005 yellow zx3
Points 50, Level 1
Points: 50, Level: 1 Points: 50, Level: 1 Points: 50, Level: 1
Level Up 50% Completed
FF Reputation: 1 formnewbie19 Good Standing Member
is that a voltage stabilizer in there too? J.W. because I'm looking into some performance parts and don't know where to start or which ones to trust?
formnewbie19 is offline
Old 11-06-2013, 10:32 PM   #18
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 2 Miztaken1312 Good Standing Member
Quick question...
I know nothing about suspension works, or why you do certain things, etc..
Why do you tighten the front and rear strut bolts after the car is on the ground?
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 11-06-2013, 11:30 PM   #19
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 2 ferret15 Good Standing Member
I don't see how any of those lower bolts would get "properly" torqued when the vehicle is on the ground, I had enough trouble putting the back in tight.
So anyway the rear is a fickle beast. A 4ft breaker bar and a lift and a friend helped the most. Pulled the top bolt, then the bottom bolt of the shocks, then the sway bar and thats it for the rear.
I use a internal spring compressor to remove the spring and like 5" of spacer nuts to keep the stupid thing from hitting the car. I remember reading that you couldn't get it, so I did it with an autozone rental.
Then with the breaker bar to help pull it open as far and long as it would. We sprayed some pb blaster on the bottom of the new spring and put the top in and jammed the bottom in with weight and if needed a prybar.
*To note: I re-used the bump stop and top for the shocks, and if you can find new lower bolts before you start. I had to replace 1 because the old rubber bushing sleeve (which is metal) fused to bolt, but the other was fine.
The front was easier, break the pinch bolt loose and remove, take the break line out, and the abs wire out of the way. The tie rod endlinks were rusted on, but a socket fit on the front and there was a spot on the backside to get a big wrench on to keep it from spinning. The allen key spot was a joke, I bent on and moved on. Once it apart I gave rotor a light kick and the strut popped out. The strut went in just as quick (assuming you assembled yours before starting.
On the ground almost all the way. I started with an ST which measured about 2" in the front and 5" in the rear. The kit brought both to a little more than .5" and they have yet to settle.
I hope this helps somebody.
ferret15 is offline
Old 11-16-2013, 08:09 PM   #20
Miztaken1312
Fan#: 74993
How did you guys tighten and torque your front strut piston nuts? There's no allen key spot on mine and it just keeps spinning when I try to tighten it down more. I got one good blast with the impact, but its definitely not tight enough or torqued
Sent from my SGH-I747 using FF Mobile
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Pics of FRPP lowering kit and FS exhaust after install.............. zzr4u2nv Ford Focus Builds & General Showroom 40 05-24-2008 04:36 PM
lowering springs vs a whole new suspension kit PatinPending Brakes, Suspension & Body Chassis 18 04-28-2008 08:48 AM
For Sale: Brand New Eibach Sportline Springs and Pro Dampers *SOLD* jeeptofocus Archive 26 02-21-2006 02:27 PM
