How to Remove 08 Sedan Grille / Headlight - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-16-2011, 01:12 AM   #41
blindreap3r
Fan#: 73709
What I Drive: 2008 S Coupe
FF Reputation: 1 blindreap3r Good Standing Member
Wish I found this before I repainted my grill. Broke one of the tabs on a headlight.
2008 Ford Focus S
13.84 @104 MPH
blindreap3r is offline
Old 03-22-2011, 09:51 AM   #42
focusduratec20
Fan#: 84176
What I Drive: 2010 silver se (sedan)
FF Reputation: 1 focusduratec20 Good Standing Member
I have a 2010 focus se sedan and i wanna remove the lower part of the grill in between the fog lights. How would i go about doing so
focusduratec20 is offline
Old 03-22-2011, 10:00 AM   #43
CamoCustom
CamoCustom's Avatar
Fan#: 78390
What I Drive: 2011 Mazda 3 iTouring 2.0
FF Reputation: 2 CamoCustom Good Standing Member
Pretty sure you are gonna have to go from underneath. First remove the splash guard, then you should have access to the rear part of the bumper and black grille and remove as needed.
"A country boy can survive"
'11 Mazda 3
CamoCustom is offline
Old 03-22-2011, 10:09 AM   #44
focusduratec20
Fan#: 84176
Thanks man
ill try that out and see if it works
Old 06-17-2011, 05:38 PM   #45
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 2 Miztaken1312 Good Standing Member
Big thanks BradWhite. This guide came in quite handy as I took my 08 grille off last night for paint.
Miztaken1312 is offline
Old 07-31-2011, 08:15 AM   #46
CourtneyNYC
Fan#: 86057
What I Drive: 2010 - Sterling Gray&2012 White Ti
FF Reputation: 1 CourtneyNYC Good Standing Member
UPDATE; Just used this procedure to install PIAA H13 bulbs in a 2010 Focus SEL
Procedure worked perfectly.
I used a pair of very small screwdrivers to pop the 4 expansion plugs that retain the top of the grill. I laid one down and used it as a fulcrum and gently put the blade of the 2nd screwdriver under the head of the plug and removed it with no damage.
With the 4 plugs out of the way . . . I was able to reach the clips in the lower portion of the grill. I'm not sure the plugs really do anything. The key here is that there are 4 alignment tabs. A tab on the grill slips under each of them to hold the grill.
Between each pair of 2 tabs on each side is a smaller tab that has a lip on the back. This lip slips over and edge and "clicks" into place.
At first I was trying to remove the expansion plug until I learned it did nothing. The key is to simply wiggle the grill gently and release the tab that hangs over the lip.
I was able to change both lamps in roughly 30 minutes.
Thanks to those who posted the photos and the procedure.
CourtneyNYC is offline
Old 07-31-2011, 08:17 AM   #47
CourtneyNYC
Fan#: 86057
Old 12-07-2011, 06:09 PM   #48
GreatLakesAngel
Fan#: 92541
What I Drive: 2008 True Blue SES
FF Reputation: 1 GreatLakesAngel Good Standing Member
I tried to change my blink bulb today. I was able to easily get the pins on top of the grille easily, but I'm having a ton of trouble getting those snap fasteners off. I tried to pry them off, but that didn't work.
Do you have any advice on how to get those two fasteners off easily? That seems to be the part giving me the most trouble.
GreatLakesAngel is offline
Old 12-07-2011, 10:10 PM   #49
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
What I Drive: 08 Sedan SE Vista Blue
FF Reputation: 174 BradWhite Excellent Standing Member BradWhite Excellent Standing Member
The lower catches are always an issue. Get a good flashlight and pull back the top of the grill so you get a good look down there. The pins are different down there, small round top on the pins. You can slip a small flat screwdriver blade between the top of the pin and the retainer body, pull the pin up with the screwdriver. Grap the top of the pin with pliers and pull it out. AutoZone sells a body and trim tool kit for $15, worth the investment!
Good luck,
Brad
Best wishes and keep on modding April 2009 SOTM, July 2009 ROTM, 2009 FF ROTY
RIFF CREW, Sedan Revolution #137, TEAM Duratec #181, Bremerton Raceway #658, NW POSSE #6
BradWhite is offline
Old 12-08-2011, 09:12 AM   #50
2011 SE
2011 SE's Avatar
Fan#: 80951
What I Drive: 2011 SE
FF Reputation: 8 2011 SE Good Standing Member
The way I've always handled it (since I've removed the grill about 20 times now):
1. Note where the two catches are
2. Get a long, thin flat head screw driver
3. From the front of the grill, slide the flat head under the grill - in between the top of your bumper cover and the grill itself
4. If you aimed it right, you can wiggle the screwdriver up and down until the catch is no longer resting on the bumper cover, but instead on your screwdriver.
5. Lightly pull on that side of the bumper (if you're prying the right catch, pull lightly on the right side of the grill) until it pops towards you.
6. Repeat for the other catch.
Does that make sense? If not, I can probably try to grab some pictures at some point today.
2011 SE Manual - black exterior/interior
Eagle Eyes halo projectors using 55w 5000K DDMtuning HIDs
LED Conversion (license plate, map/dome lights), and LED Taillights
Autobots decal over Ford emblems
Flat black TFB Designs hood stripes
2011 SE is offline
Similar Threads
Headlight issues - continuing electrical issues.... The_good_guy General Technical Chat 4 09-26-2012 05:13 PM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
How To: Remove the 05+ Speedometer Cluster myfocusrocks MK2 Interior Mods & Upgrades 11 01-04-2011 02:09 PM
Timing belt problem matthewsvt General Technical Chat 22 07-16-2007 04:00 PM
RS grille installed.. turn signal help needed neojen MK1 Focus 15 03-04-2004 11:54 PM
