How to Remove 08 Sedan Grille / Headlight - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-25-2008, 04:43 AM   #1
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
What I Drive: 08 Sedan SE Vista Blue
FF Reputation: 174 BradWhite Excellent Standing Member BradWhite Excellent Standing Member
Cool How to Remove 08 Sedan Grille / Headlight
Maybe it's just me or there's some trick that I don't know, but removing a headlight from an 08 Sedan, per the owners manual instructions, is simply a lesson in frustration. And you have to completely remove the headlight to get to the bulbs. I now get the grille out of the way, a 5 minute job, and save myself a lot of grief.
To remove the grille, remove the four (4) plastic expansion plugs (blue circles). After removing the plugs pull up to release the alignment tabs (red circles).
While holding the top of the grille up look inside at the bottom, you will find one more expansion plug (blue circle) on each side, remove those. There is also a catch on the grille that hooks onto the bumper (red circle) on each side. Push in on the grill, push down on the bumper close to the grille catch and release the grille. If you did it right the catch should be released. You might have to try a couple times to get the hang of it. Also note the four alignment slots for re-installation, two on each side (yellow circles).
That's it, once those catches are released the grille should slid right out.
Now you can remove all three bolts from the headlight (blue circles), pull it clear of the fender and up to release that enormous tab on the bottom of it. And you can do it all without swearing or a cutting torch!
All I know is that if I'm doing anything with a headlight, my grille comes off first!
To put the grille back in, start from the bottom and slide it into those four alignment slots, replace the lower expansion plugs, push the top in and get the two top alignment tabs in place then replace the four top expansion plugs. Your done. That is assuming you remembered to re-install the headlight first. Which according to the owners manual can be done with the grille in place, but hey - good luck with that.
Best wishes and keep on modding April 2009 SOTM, July 2009 ROTM, 2009 FF ROTY
RIFF CREW, Sedan Revolution #137, TEAM Duratec #181, Bremerton Raceway #658, NW POSSE #6
BradWhite is offline
Old 05-26-2008, 09:44 AM   #2
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO ARCHIVE'...........
Chad (S2)
S2 is offline
Old 05-26-2008, 10:04 AM   #3
SuperFocusMan
SuperFocusMan's Avatar
Fan#: 20307
What I Drive: 12 Cloud 9 White SEL
Points 3,074, Level 34
Points: 3,074, Level: 34 Points: 3,074, Level: 34 Points: 3,074, Level: 34
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 3 SuperFocusMan Good Standing Member
Buy-Sell-Trade Rating: (4)
Nice, are you going to paint the grill?
N/A Crew #2
SuperFocusMan is online now
Old 05-26-2008, 10:43 AM   #4
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
Man you have good eyes. How did you see my grille work in those pics? If you're curious there's a pic of it in my gallery.
You know I didn't plan to paint it, but you are the second person to ask that question so I guess I'm going to look at doing that. Would you suggest painting just the center section or all of it?
Old 05-26-2008, 11:13 AM   #5
john m.
john m.'s Avatar
Fan#: 55541
What I Drive: 2008 Focus SES Vista Blue 5 speed
Points 2,016, Level 27
Points: 2,016, Level: 27 Points: 2,016, Level: 27 Points: 2,016, Level: 27
Level Up 11% Completed
FF Reputation: 0 john m. Newbie
Why did you have to replace the headlights on a new car? I got a 08 and if those lights burn out so fast I would like to know about it!
john m. is offline
Old 05-26-2008, 11:50 AM   #6
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
Nope, no problems with the stock bulbs. I just replaced them with some that are supposedly brighter.
When you do get around to having to replace one though I highly recommend removing the grille first. Yeah, it seems like overkill, but it's just so much easier to get the headlight out. Personally, I'll never go after a headlight again without removing the grille first.
Hey, would you like brighter fog lights? I know this trick works. Replace the bulbs with H9's, they are 2200 lumens brighter than stock. You just need to shave off one tab on the inside of the H9 and it fits right in. I'm using them and they are turned on a lot, no problems from extra heat or anything else.
Old 05-26-2008, 12:05 PM   #7
SuperFocusMan
Fan#: 20307
I would suggest painting the whole thing minus the mesh, possibly body color or black. But I am leaning to body color. It would look killer.
N/A Crew #2
Old 05-27-2008, 02:38 PM   #8
theWorst
theWorst's Avatar
Fan#: 55690
What I Drive: 2008 Edge SEL
FF Reputation: 6 theWorst Good Standing Member
i didn't have that 5th thing..
jsut the four top ones... and tilt the grille down and it popped out.
why didn't anyone tell me turning off traction control gave me faster launches and better gas mileage...
theWorst is offline
Old 05-27-2008, 03:52 PM   #9
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
I'm jealous, that's even easier than the Sedan!
Old 05-27-2008, 04:20 PM   #10
theWorst
theWorst's Avatar
Fan#: 55690
i dont know why it would be different.. it pops out and in.. lol
maybe it was a manufacturing change somehwere down the line?
on a different note... i'm mad ford made their pegs offset.. i removed the emblem only to find out it won't fit upside down.
oh well.. at least i learned how to take off the grille..
but yeah.. without the grille it would DEFINITELY make the headlights easier to remove
+1 for painting your grille body color... i'm torn between body color and satin black...
theWorst is offline
Similar Threads
Headlight issues - continuing electrical issues.... The_good_guy General Technical Chat 4 09-26-2012 05:13 PM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
How To: Remove the 05+ Speedometer Cluster myfocusrocks MK2 Interior Mods & Upgrades 11 01-04-2011 02:09 PM
Timing belt problem matthewsvt General Technical Chat 22 07-16-2007 04:00 PM
RS grille installed.. turn signal help needed neojen MK1 Focus 15 03-04-2004 11:54 PM
