Reverse Switch Replacement - How-To (MTX-75) - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-05-2008, 11:43 PM   #11
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Probably a lot the same. I believe the IB5 tranny in the SPI and the MTX found in the rest of the foci (minus SVT) are very similar. I would get the part, see what it looks like and just dig around. Chances are its in the same place or very close.
jetrinka is offline
Old 07-06-2008, 05:50 PM   #12
HawaiianBassHead
Fan#: 5625
What I Drive: 00 Midnight Blue ZX3
FF Reputation: 1 HawaiianBassHead Good Standing Member
they have the part, that's why I noticed it's slightly different from the one in the pic. I don't have alot of tools here so it's a mission they're gonna have to tackle through someone else :( just found out not only is the safety expired from feburary but the cars not registered since it doesn't have a safety lmao... been driving it around all weekend... it's kinda missing too at times, they changed the plugs and wires so maybe they crossed one or something, but when I crossed my zetecs wires it ran REALLY bad, there was clearly problems lol..
2005 Canteen green crew cab titan mines
2004 Jetta GLS 1.8T wifes
HawaiianBassHead is offline
Old 04-09-2009, 07:26 PM   #13
Motor_head
Fan#: 45583
What I Drive: Silver 2004 WRX
Points 1,826, Level 25
Points: 1,826, Level: 25 Points: 1,826, Level: 25 Points: 1,826, Level: 25
Level Up 26% Completed
FF Reputation: 3 Motor_head Good Standing Member
Do you have the part number for that bad boy?
2014 Focus ST. Boost is yummy.
Charlie
"Our lady of blessed acceleration, don't fail us now!" - Elwood Blues
Motor_head is online now
Old 04-21-2009, 12:57 AM   #14
terminator980
Fan#: 64499
What I Drive: 2005 Pitch black ZX3
FF Reputation: 1 terminator980 Good Standing Member
Thank you SO MUCH for this. I'm still learning about my car and stuff and I couldn't figure out what happened to my reverse lights. I knew it was a good idea to sign up for this forum, lol
terminator980 is offline
Old 03-27-2010, 02:22 PM   #15
sirguise
Fan#: 73554
What I Drive: 05 ZX3
FF Reputation: 1 sirguise Good Standing Member
I happened to like the knob the last owner put in the car so I didn't want to make any major changes other than disabling the lockout, so I thought I'd share what I did as an alternative.
1. Remove the side "braces" that allow the lockout to move up and down.
2. Run a zip tie through the end of the "braces" and loop/tie underneath the lockout.
3. Trim the end of the zip tie and you're good to go.
Loops removed from the plastic lockout block.
Zip tie the lockout block up and out of the way. Only need to clear a 1/4" or so.
Finished and works great. Want it back to stock? Break out the wire cutters, snip the zip tie and pop the braces back onto the lockout.
sirguise is offline
Old 03-27-2010, 10:13 PM   #16
jetrinka
jetrinka's Avatar
Fan#: 45622
^^^I am confused as to what this has to do with the reverse switch...
jetrinka is offline
Old 03-27-2010, 10:45 PM   #17
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,312, Level 75
Points: 13,312, Level: 75 Points: 13,312, Level: 75 Points: 13,312, Level: 75
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 99%
Yeah jet, Under $30 "Fixes" maybe. Got tagged onto a thread that doesn't fit for sure!
(Can't see the advantage, unless the lockout isn't working right though..)
sailor is offline
Old 01-01-2011, 03:40 PM   #18
eville
Fan#: 63254
What I Drive: 2005 silver zx4 st
FF Reputation: 1 eville Good Standing Member
Just used this how-to to fix my lights. Everything went smoothly. Thanks for the guide!
eville is offline
Old 08-21-2011, 11:08 AM   #19
Guetenburg
Fan#: 89056
What I Drive: 2007 Yellow ZX3 2.0L
FF Reputation: 1 Guetenburg Good Standing Member
Thanks or the info!
Guetenburg is offline
Old 08-21-2011, 11:11 AM   #20
Guetenburg
Fan#: 89056
I just wanted to say thank you and that this post was very helpful!
I will say however that I didn't need to remove the battery, trans mount or trans mount bracket to get at the sensor. It looks like you have an aftermarket air intake and filter. On the 2007 production 2.0L that I have, I was able to remove the aircleaner with 2 bolts and then disconnected the air intake hose by loosening the clamp at the throttle. Then I was able to get at the switch. First, I disconnected the wire and checked if it was the switch that was a problem by jumping the connector with a wire and the backing lights worked. So then I used a 7/8 inch deepwell socket and was able to get in under the trans mount and remove and install the switch. No need to take out the battery or the battery tray. I thought this was much simpler.
Similar Threads
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
help headlight control switch not illuminating properly ash1212002 General Technical Chat 2 12-07-2007 06:32 AM
LED momentary switch? Where to get? PhilMayfield MK1 Interior Mods & Upgrades 0 06-08-2006 04:00 PM
Hatchback Power Window Switch Problem Happenedtoyou MK1 Interior Mods & Upgrades 2 09-11-2004 04:18 AM
T/C Kill Switch ?? svtfocusmansvt SVT Performance (2002-2004) 9 09-03-2004 10:51 PM
