Won't start...security system? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 05-22-2008, 10:42 AM   #1
rexwilkinson
Fan#: 55231
What I Drive: 2002 Red ZX3
FF Reputation: 1 rexwilkinson Good Standing Member
Question Won't start...security system?
I've got a 2002 Zx3 and it won't start right now. It's not a dead battery b/c all the interior lights still turn on and everything...a few days ago it didn't start and I unhooked the positive terminal from the battery and when I hooked it back up it started right up? Does this mean it's got something to do with the security system? I've also heard about a possible faulty clutch sensor that can cause the vehicle not to start, but that idea doesn't match up with the battery solution. Anyways...I tried unhooking and hooking the terminal back up this time, and it still won't start up. Any suggestions? Thanks!
rexwilkinson is offline
Old 05-22-2008, 12:03 PM   #2
JRODSVT
Dragon Warrior
JRODSVT's Avatar
Fan#: 15362
What I Drive: 03 SVT ZX5
FF Reputation: 97 JRODSVT Excellent Standing Member
Buy-Sell-Trade Rating: (6)
does it crank at all or do you turn the key and nothing happens?
J-RAWK!!!
FocusFests best of sound 2008
(Oo> (SVT) <oO)
o xxxxxxxxxxxx o
JRODSVT is offline
Old 05-22-2008, 01:31 PM   #3
rexwilkinson
Fan#: 55231
nothing happens...
Old 05-22-2008, 02:06 PM   #4
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Its a security thing if the light by the hazzard button flashes rapidly when you try to start it.
But don't rule out the battery too quickly. Sometimes accesories will operate, but the battery could lack the amps to turn the starter. See if it takes a jump. If it doesn't, it could be the relay on the starter, which means the starter would need to be replaced. Or if its a manual, double check the clutch interlock.
Egz is offline
Old 05-22-2008, 03:09 PM   #5
rexwilkinson
Fan#: 55231
How do I double check the clutch interlock?
Also, any idea off the top of your head, the price for a new starter?
Thanks for the help guys!
Old 05-22-2008, 05:09 PM   #6
Vance
Vance's Avatar
Fan#: 24185
What I Drive: 2007 ZX3 SE 2.0L ATX Aqua Blue Met.
FF Reputation: 6 Vance Good Standing Member
Check the negative battery cable to make sure it is on tight and has no corrosion. Not sure what the 02 battery connections look like but you may want to pull the wire out of the part that clamps to the terminal. I had a car that, visually, the cable didn't look corroded, but when I pulled the cable apart, it was completely corroded inside the connection. I had lights, radio, etc. but it just wouldn't crank. Once it was cleaned out, the car started right up.
For Sale: VF Engineering torque mount (used <1k miles)... $60 incl. shippiing w/i the 48 states
Vance is offline
Similar Threads
Problems with ignition system, weird ones! brianw General Technical Chat 7 06-07-2008 12:58 AM
Viper 5900 Alarm/keyless/remote start installed MattZX3 Car Audio, SYNC, MyFord Touch & Electronics 17 10-26-2007 01:35 AM
Eibach Sport System VS Sport System PLUS??? abrock124 Brakes, Suspension & Body Chassis 11 08-20-2005 05:21 PM
Security System Justjimmy Car Audio, SYNC, MyFord Touch & Electronics 1 05-20-2004 03:29 PM
