Go Back   Focus Fanatics > Model Specific Discussions > MK1 Focus
Old 05-19-2008, 10:04 AM   #1
Sn4ckM4st3r
Fan#: 24432
What I Drive: 2002 Stealth ZX3
FF Reputation: 91 Sn4ckM4st3r Excellent Standing Member
Buy-Sell-Trade Rating: (4)
How-To: VHT Niteshades Tails
I looked through the archives and found nothing on this so i thought i would try my hand at this.
Materials:
Baby wipes or rubbing alcohol
800 Grit Wetordry Sandpaper
1000 Grit Wetordry Sand paper
1 or 2 Cans of VHT niteshades (depending on how dark and how many lenses)
1 or 2 Cans of High Gloss clear coat (again depending on how many lenses) *Side note* If you wish to have a different look try a high gloss clear with a sort of metallic flake in it. Something like Clear Effects.
Plenty shop towels or microfiber
Rubbing compound (Meguairs Scratch X recommended)
Your favorite Wax
Packing Tape
Preparing
Open your trunk or hatch depending on your trim line.
Reach in and remove the wing nuts to the tails, and the screws on the sides for the hatch focus. Remove both tails and put ziploc bags or plastic wrap around the bulbs and wiring to prevent ANYTHING.
*At this point if you would rather do the inside for a light smoke take your lenses in and bake at a very low temp long enough to melt the seal*
Once you have the tails inside or where you will be painting take your baby wipes or rubbing alcohol and lightly apply and clean the lenses.
Wipe down with shop towels or microfiber.
Wetsand with 800 VERY lightly and make sure to do the whole lens. Be careful not to sand your reverse lens if you want it left clear.
Wipe down with baby wipes again.
Niteshading
After both lenses are clean and prepared put some kind of protection underneath them to protect whatever they are on.
*If you wish to leave your reverse lights clear take your packing tape and apply it perfect over and then gently cut it to the shape and contour of the reverse lens.*
Spray your first coat of niteshade. Make sure to spray it on VERY lightly in an almost dusting style. Make sure to cover the whole lens evenly.
Make sure to wait for the nitesahde to completely dry *10-15 minutes*
When it does dry wet sand lightly with your 1000 grit every coat.
Apply 3 coats of this for a light smoke
Apply 4 coats in a similar fashion for a darker smoke
Apply anywhere from 5-6 coats for a dark or almost black lens.
Clearing
After your final coat of niteshade has dried, wetsand lightly with 1000 grit.
After you wetsand apply 3-5 coats of clear to achieve the shine desired. Also wen clearing make sure to wetsand all impurities or flaws made while spraying on the clear.
After the clear has dried put the tails back onto the car at this point.
Shine
When the tails are back on the car take your rubbing compound ( i used scratch X and found it to work best out of the 3 i had.) and gently work a very small amount in with an applicator.
Rub it off in circular motions with a microfiber POLISHING cloth.
After this apply your favorite wax ( I used Meguiars Tech 2.0)
Let dry and buff out with the same or another polishing microfiber cloth.
*Note*
Depending on your darkness and amount of braking time look into LED style bulbs from ebay or such. These can be helpful as they are brighter and don't share the same heat problems or concerns as do the stock style bulbs*
You are now done, i do not have pictures as my camera was dead.
Also note to do the side markers as well as front signals the procedure is identical. The procedure is the same for the 3rd Brake lens as well, make sure to cover the back of it with plastic or aluminum foil and to clean the washer nozzle if you get over spray on it.
Pics of finish product-
Tails-
Front End-
3rd Brake Lamp-
Norcalfocus01-
Video of light-
Sn4ckM4st3r is offline
Fan#: 1
Old 05-19-2008, 02:41 PM   #2
trailbikerider
I <3 Conspiricizing.
trailbikerider's Avatar
Fan#: 50501
What I Drive: 2002 Granny Gold ZTS, 94 2.3 Ranger
FF Reputation: 14 trailbikerider Great Standing Member
Buy-Sell-Trade Rating: (15)
Not quite sure, but isn't that illegal to have your taillights like that?
Originally Posted by SVT3658
I am enjoying this ice cream like Evan enjoys drinking a beer from a koozi in a beach chair across the street from a middle school
trailbikerider is offline
Old 05-19-2008, 02:46 PM   #3
TKE_Quailman
FF God of South FL
TKE_Quailman's Avatar
Fan#: 44442
What I Drive: 07 Pitch Black ZX3
FF Reputation: 35 TKE_Quailman Great Standing Member
Nope so long as your brake lights shine trough at least here in miami thats how it is
02 Black ZX5 R.I.P.
07 Black ZX3 Work in progress
Last of the Hatches #1
XBOX LIVE:TKE428
GIVE REP POINTS IF IM HELPFUL
TKE_Quailman is offline
Old 05-19-2008, 04:51 PM   #4
FocusedEnergy
FocusedEnergy's Avatar
Fan#: 48574
What I Drive: 2006 Liquid Gray ZX4SE
FF Reputation: 3 FocusedEnergy Good Standing Member
"After you wetsand apply 3-5 coats of niteshade to achieve the shine desired. Also wen clearing make sure to wetsand all impurities or flaws made while spraying on the clear."
I believe you meant 3-5 coats of clearcoat, not niteshade . Cool though- good writeup. I believe though that you have to let the paint really dry out and breathe before you coat it with wax, and if I'm not mistaken, that usually takes around 6 months. Just my two cents.
Again, good writeup.
SEDAN REVOLUTION #51
The tighter the budget, the slower the mod progress. Estimated completion date: September 2057
FocusedEnergy is offline
Old 05-19-2008, 10:11 PM   #5
Sn4ckM4st3r
Fan#: 24432
Sorry fixed that. And this is the third set of tails i have used this exact setup on. Never onced had an issue and always turned out great. I believe i will be using clear effects to try and give it a different look some time.
Old 05-20-2008, 02:18 PM   #6
CapnGnarly
CapnGnarly's Avatar
Fan#: 50250
What I Drive: '04 ZX3, 2.3L Duratec
FF Reputation: 7 CapnGnarly Good Standing Member
Clearcoats react MUCH differently than color coats. I haven't done it on a car before, but I have on guitars quite a bit (been doing custom paint jobs for nearly 6 years).
If you wax a color before it's cleared, it will "suck out" the dyes in it, which will cause the color to fade and sometimes the "flatness" of it warp, causing curves, wrinkles, and even orange peel in some extreme cases. A clear on the other hand is typically a MUCH harder compound, takes about a year to truly cure, and has no dyes in it.
On guitars, I use beeswax (which I know is very different than car wax), and usually put it on within 6 hours of the top clear drying. If I didn't put a clear on, then I don't wax it at all. The wax does the same thing it does on your car, it fills in whatever small scratches or dings or chips are in there, and is easier to "spread," so it flattens out and smooths over any rough spots while still staying glossy and clear.
On a clear, I'd say it's okay to throw some wax on it. Wait a day or so, but it's okay. If you don't put any clear on it, don't touch it with wax until a LONG time after you've sprayed it. I can see the plastic getting warped with the color if it were to happen. I can't say "if you do this, you will ruin your headlights" because that's more than likely not true, but the caveat should be there, just in case.
2004 Pitch Black 2.3L, FSWerks CAI and Focus Central 65mm TB
FRPP Competition Rally Brake Kit
Team Duratec #333
CapnGnarly is offline
Old 05-20-2008, 02:21 PM   #7
CapnGnarly
CapnGnarly's Avatar
Fan#: 50250
Editing is freaking out on me, so this post will make my changes for me.
"If you wax a color before it's cleared" should be "before it's cured."
Team Duratec #333
Old 05-20-2008, 02:27 PM   #8
nacnudv8
nacnudv8's Avatar
Fan#: 52725
What I Drive: former owner:Pitch Black '03 SVT 3D
FF Reputation: 7 nacnudv8 Good Standing Member
front turns look good - they are really "stealth"
An eye for an eye makes the whole world blind.
Mahatma Gandhi
nacnudv8 is offline
Old 05-20-2008, 02:47 PM   #9
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
FF Reputation: 28 thenorm Great Standing Member
its a good, detailed write-up for super high quality work.
when i shaded mine, i didnt have the patience that you did, so i never wetsanded, didnt wax either or buff. All i did was.
rubbing alcohol
3 coats of shade (drying between)
2 coats of clear.
they turned out good IMO, but i suppose side by side with yours, I would see the difference made by your procedure.
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 05-20-2008, 02:59 PM   #10
Sn4ckM4st3r
Fan#: 24432
Thanks. Yeah i have done 3 sets of tails in the past 2 years. And every single set i have done this way has NEVER been warped, discolored, or faded. The scratch X is more like a polishing deal to take away small blemishes that were left after wet sanding. And then the Tech 2.0 keeps them shining bright. Like i said NEVER had a problem. And while paint is the same i have found that nitesahde behaves VERY differently then car paint or such. They told me not to wax my bumper on my old car for like 2 months so i didn't. But these i have done it everytime and ALWAYS loved the end result.
EDIT: Also if you feel really dark you can use the 1000 to sand down your ford emblem and then wet sand it. After that hit it with niteshade a few coats to black it and then clear it and use the same shine precedure. I need to hit mine with another coat of clear but i blacked it for that added stealth effect.
Similar Threads
My euro spec. sedan tails are here!(now installed!) loudfocus01 Ford Focus Builds & General Showroom 43 03-22-2008 04:52 PM
HELP with VHT Nite-Shades, MY TAILS CAME OUT VERY FOGGY! Mr.Bergner MK1 Focus 12 07-06-2007 05:26 PM
using window tint on tails FocusTuner27 MK1 Focus 2 09-07-2006 10:01 PM
HatchBack Tails 3 Sets! Focusedat50 Archive 9 12-28-2004 10:54 PM
