HELP! Cooling Fan Problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-18-2008, 07:58 PM   #1
FociBoi121
FociBoi121's Avatar
Fan#: 53573
What I Drive: 2003 InfraRed ZX3 ATX
FF Reputation: 4 FociBoi121 Good Standing Member
Exclamation HELP! Cooling Fan Problems
ok so live in FL
i rarely use the A/C
WELL stuck in traffic i decide its A/C time i jus drove by a digital sign that says 92 degress be4 the jam whew
my car starts overheating so i speed up after getting out of traffic (the radiator needs air ventilation to cool after i turn a/c off )
Basically i knew my fans arent working
car is fine for driving and idling just not idling with A/C
what should i check for?
connections?
a relay?
anything else?
Current Mods: about me profile
ZETEC Crew #237
HATCHBACK LOVER #121
PS3 ID: LarkBoi189
Slow bolt ons added or bolt ons slowly added?
FociBoi121 is offline
Old 05-18-2008, 10:28 PM   #2
ktwelsch
FoFo Lover.
ktwelsch's Avatar
Fan#: 30202
What I Drive: 2012 Mazda 3i
Points 7,790, Level 59
Points: 7,790, Level: 59 Points: 7,790, Level: 59 Points: 7,790, Level: 59
Level Up 20% Completed
FF Reputation: 9 ktwelsch Good Standing Member
Buy-Sell-Trade Rating: (27)
I would check your electrical connections to the Fan....also you might check your thermostat on the radiator.... supposedly it takes a much higher temp. for the stock ones to start working, so must people just swap them out.
^^^Those are just a shot in the dark,
But did it sound like your fan was running?
SEDAN REVOLUTION #42 Baby!
ktwelsch is offline
Old 05-18-2008, 10:29 PM   #3
Obocecha
Obocecha's Avatar
Fan#: 28484
What I Drive: 2002 Yellow ZX3
Points 1,641, Level 23
Points: 1,641, Level: 23 Points: 1,641, Level: 23 Points: 1,641, Level: 23
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 15 Obocecha Great Standing Member
Buy-Sell-Trade Rating: (9)
Typically the low speed fan stops working but the high speed fans will work with the AC on. The fans are forced on when the AC switch is on. I would check all the wiring and harnesses connected to the fans. Many foci have problems with the harnesses burning out.
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is offline
Old 05-19-2008, 02:25 AM   #4
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
Points 8,660, Level 62
Points: 8,660, Level: 62 Points: 8,660, Level: 62 Points: 8,660, Level: 62
Level Up 70% Completed
FF Reputation: 17 svtguy88 Great Standing Member
I was going to mention that the fans are running when the AC is on automatically. It helps get extra flow to the condenser. Right now, if you don't have the A/C on, it doesn't overheat, but it does when the A/C is on? Is either fan working?
I would check the wiring first, as if neither fan is working, that may be the problem. After that, check the fuse/relay. Hopefully it is something simple like that. I don't think it would be the temp sensor, as if it is overheating (like the gauge is reading way off to the right), the car knows what temperature it is. Because, as far as I know, the temp sensor for the fans and the temp gauge are the same...and the actual gauge in the car doesn't really read the temperature. Instead, it gets a signal from the ECU saying whether or not the car is cold/warm/hot. Now, if the car is getting too hot, the temperature gauge goes was off to the right by having the computer simply tell it to. I'm pretty sure that is the way that it's set up. I think I remember reading that in my Haynes manual while I was bored one day.
I don't think it would be the thermostat though, at least, not unless the fans are actually working and the car is still overheating.
svtguy88 is offline
Old 05-19-2008, 04:36 PM   #5
FociBoi121
FociBoi121's Avatar
Fan#: 53573
I tested the fans.. not working when the a/c is on at any speed
theres no overheating issues at any other time, just that the car will overheat when trying to run the a/c at a full stop
ZETEC Crew #237
PS3 ID: LarkBoi189
Old 04-01-2010, 05:38 PM   #6
MRDANGLES
Fan#: 74071
What I Drive: 2003 ztw
FF Reputation: 1 MRDANGLES Good Standing Member
did you find out what the prob was? my 03 is overheating and the fans DO NOT TURN ON when the a/c is on... the fans are working with direct power to them. all fuses look good to. i see alot of issues with the thero but this has nothing to do woth the fans ( i think)
4 WHEELS MOVE THE BODY, 2 WHEELS MOVE THE SOUL
M.I.L.F HUNTER
MRDANGLES is offline
Old 04-06-2010, 01:06 AM   #7
svtguy88
svtguy88's Avatar
Fan#: 13476
Check your relays. I haven't looked at the wiring diagram in a while, but I think if your A/C light (the button on the dash) is turned one, the fan *should* be running....
svtguy88 is offline
Old 04-06-2010, 02:19 PM   #8
MRDANGLES
Fan#: 74071
^^ will do thnx.. the fans are comming on right about when the car is overheated in which case they do not cool it down enough @ that point. still no fan on while the ac is running. ann blowing hot air out the a/c but i am more worried about the over heat issue
M.I.L.F HUNTER
Old 04-06-2010, 11:39 PM   #9
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,775, Level 73
Points: 12,775, Level: 73 Points: 12,775, Level: 73 Points: 12,775, Level: 73
Level Up 82% Completed
Forum Activity 99%
Posted via FF M obileCheck the fan resistor threads - lots of info
sailor is online now
Old 04-14-2010, 04:27 PM   #10
MRDANGLES
Fan#: 74071
okay, i need to know how to check and where the a/c switch control sensor and coolant fan temp sensor are located.. also which are the relays in the box in the engine compartment located for the a/c and fan unit? sorry for all the question just having hell with this focus
M.I.L.F HUNTER
Similar Threads
Focus Problems disscusion... walshka07 Ford Focus & General Car Chat 6 12-28-2007 06:57 PM
svt cooling fan resistor BMARTIN03ZX3 General Technical Chat 5 07-09-2007 01:49 AM
Cooling Fan Problems!! (help) mystikcid General Technical Chat 6 06-27-2006 12:19 AM
Cooling Fan samkell General Technical Chat 4 04-12-2004 04:04 PM
For Sale: Flex-a-lite 12-in Electric Fan With Controls - 1250 CFM mr.squatch Archive 6 04-01-2004 06:44 PM
