A SVT Owner, Finally!! - Page 5 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 06-05-2008, 10:16 AM   #41
dmeray1
dmeray1's Avatar
Fan#: 53215
What I Drive: 2004 Sonic Blue SVT
FF Reputation: 5 dmeray1 Good Standing Member
Buy-Sell-Trade Rating: (6)
I also changed the transaxle oil and filled it up with Royal Purple Syncromax. I drove it in to work this morning and after just doing the Houston trip last week, I could tell that there is a difference. I like it. I also saw that there was a water hose that was sitting on top of the shift cable. I put a tyrap on to lift it up. It may have affected the shifting as well. Overall I am pleased and can't wait to install the STS that is due here on Friday.
Dan
dmeray1 is offline
Old 06-06-2008, 08:30 AM   #42
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
What I Drive: 2003 SVTF, 2003 G35, 2001 Audi S4
FF Reputation: 5 DirtyDeeds Good Standing Member
^^Yup...The same thing happened to mine. That water hose going to the heater core will sag over time and start resting on the shifter cables. I found the problem after the cables finally cut through mine.
DirtyDeeds is offline
Old 06-09-2008, 01:56 PM   #43
dmeray1
dmeray1's Avatar
Fan#: 53215
I installed the CFM STS on Saturday. It took 1 hour to install it and another hour to figure out why I lost reverse!! It is not clear in the CFM instructions and I did not recall in the illustrated instructions from WD40, you have to adjust the shifter by removing the infamous orange clip. I could then use reverse!
Everything seems fine except the 5 to 6 shift is a little stiff sometimes....kinda "notchy." Is there another adjustment that I overlooked? Is the orange clip not adjusted correctly? The 5 to 6 shift was fine with the original shifter. Any suggestions?
For future reference, the rubber "boot" that holds the plastic pivot pieces is a bear to remove and replace. The grease that CFM supplies is somewhat "sticky" and hard to work with. The pivot seems to work fine though.
Dan
'04 Sonic Blue SVT. Built 10/30/03, 344 of 1978. CFM STS, CFM TB, K&N Drop In, 2 1/2" Borla Center Exit, Jay's HFC, Energy rear mount, Edge rear wiper, Eibach Pro Kit, Mini mud flaps, RS wing, Massive front brace. Tom's Tune.
dmeray1 is offline
Old 06-11-2008, 06:44 AM   #44
dmeray1
dmeray1's Avatar
Fan#: 53215
Anyone have any suggestions for final adjustments after installing the CFM STS?
Dan
dmeray1 is offline
Old 06-13-2008, 02:35 PM   #45
FRDPLAY
Fan#: 54842
What I Drive: 2006 F-150 4x4, 99 SVT Lightning
FF Reputation: 1 FRDPLAY Good Standing Member
Dan,
Mine is sitting in a box at home going in this weekend. Do you recommend another grease to use, or any tips?
FRDPLAY is offline
Old 06-14-2008, 08:20 AM   #46
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
Here's a link to the "How To" thread on adjusting the Getrag Shifter cables...
http://www.focusfanatics.com/forum/s...4&#post1979054[/B]%3C/p%3E%3Cp%3E[B]
Old 06-16-2008, 12:36 PM   #47
dmeray1
dmeray1's Avatar
Fan#: 53215
Ok. Finally got the shifter cable adjusted. I now have all seven gears and the CFM STS almost shifts itself!
Next project will be to see if it is worth it to upgrade the speakers on the Audiophile system. Any suggestions? How about connecting the Ipod? Is FM ok? Can't find a hardwire solution. Don't want to replace the whole unit if I can help it.
Also, any suggestions to clean the cloth inserts on the seats? What is a good product to use?
Dan
dmeray1 is offline
Old 06-16-2008, 02:53 PM   #48
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
Dan
Do a search in the audio section. There are a number of threads covering hooking up an Ipod to the audiophile head unit. A hardwire through the antenna jack seems to be your best bet.
As for speakers, everybody has an opinion. Check in the audio section.
http://www.focusfanatics.com/forum/f...splay.php?f=51
On the seats, here's a thread covering that subject...
http://www.focusfanatics.com/forum/s...lean+svt+seats
Old 06-23-2008, 12:10 PM   #49
dmeray1
dmeray1's Avatar
Fan#: 53215
What would a weekend be without doing, adjusting, rubbing or adding stuff to my SVTF? For this weekend, I took my "Best Buy" gift certificates and traded them in for a set of Pioneer speakers for the front doors. I had my "how to" instructions from this site, thank you very much. Installation went pretty well. A little trouble releasing the electrical connectors from the panel, but not too bad. I used the harness that BB sells that adapts the stock speaker connector to the new speakers. Slick. I was a little worried when I pulled the sealed stock speaker box out. It has a tweeter on it and I thought, well maybe they put a premium speaker in here after all. I'll just return the new speakers. Well, I installed the left speaker and fired up the Audiophile. I used the "balance" to switch from left to right. I could immediately tell that the Pioneer speaker was better! I installed the right side speaker and cranked up the system. My wife came out because she could hear or feel the bass! For a $100.00, this was a great improvement!
Also, I decided to forget about connecting the ipod. The reviews on the "FM" type transmitters were mixed. I'll just burn a buch of CD's like we used to do. Not as fancy, but it works great with 6 cd's to work with.
Dan
dmeray1 is offline
Old 06-23-2008, 12:59 PM   #50
captcomputer
captcomputer's Avatar
Fan#: 9409
What I Drive: 2013 Focus ST (Sharp Dressed Tux)
FF Reputation: 37 captcomputer Great Standing Member
Good work, now slow down before you run out of things to do. They only get more expensive from here.
Have you looked at Ground cables for your motor. No gain in power, but it does smooth things out a bit. There are several post about that too.
Oh and congrats on the 04. I believe yours and mine were assembled on the same day.
Joe Cool
Social groups:
LoneStar Fanatics
(Former)Blue Focus Owners
captcomputer is offline
Similar Threads
HOW-TO: SVT IMRC DSI Intake Manifold Upgrade FOR ZETEC!!!! focituner ZETEC Performance (2000-2004) 131 05-31-2012 06:56 AM
2009 Ford Focus Coupe Unveiling at 12:01AM EST Tom Ford Focus & General Car Chat 97 05-13-2008 06:34 PM
Wiring up Recarro Seats Focusedat50 MK1 Interior Mods & Upgrades 9 02-25-2008 09:12 PM
new svt owner eurotrashvrt SVT Performance (2002-2004) 29 01-13-2006 04:09 PM
Finally Got The SVT Intakes Dynoed CDSilver5DoorSVT ZETEC Performance (2000-2004) 7 11-21-2004 11:51 AM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
