2000 focus blower fan location needed - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-06-2004, 08:36 AM   #1
guest
Fan#: 8855
FF Reputation: 1 guest Good Standing Member
I got high speed fan only with no ac then some days no fan at all.I heard a screaching sound once.Fan must have bad bearings.My question is wheres the blower fan and do you replace it,or is there something else causing this?This car is falling apart in other areas and I can't afford to take it in.Thanks in advance.
guest is offline
Old 06-06-2004, 09:54 PM   #2
ispy
Fan#: 6031
FF Reputation: 1 ispy Good Standing Member
I had a churping noise coming from my recirculation fan on my 2000 Focus LX. I think the blower fan sits right next to the recirc fan. The recirc fan is located behind the glovebox. You can open the glovebox and disconnect it so that it swings all the way down for access to the fans. I sprayed oil on my fan and it stopped making the annoying noise. Good luck in finding it. I think I saw it there but not sure. Good place to start looking. Look in there while selecting the blower on and off and you should be able to locate it through that compartment.
ispy is offline
Old 06-06-2004, 10:22 PM   #3
guest
Fan#: 8855
Hey Thanks! I'll do that next opportunity and let you know results.What you say makes good sense.
guest is offline
Old 07-06-2004, 10:56 PM   #4
guest
Fan#: 8855
as ISPY says,the blower is located behind glove box.Very easy to get at but thats as good as it got.I found the motor seized with the lower bearing rusted.Oiled the hell out out of it but it was too late.The windings were damaged. Put in a new blower motor,runs real good on high speed,still no lower speeds and no AC.Called parts and said wtf,They said change resister pack.Did that and bingo.Total fix at $90.00 in parts and about 12 hours of my time uside down on my back sweating like mad over a period of several days.Is this another example of how we have all been sold down the river by substandard designs and flaws in this model of car.I won't even get into the wheel bearing,fuel pump desintegration debacle.That was covered.Hope this helps someone else save time and money when it happens.I still wonder though,how did water get into the motor housing and will it happen again in another 4 years.
guest is offline
Similar Threads
2008(+) Focus Crew: All the info you will ever need... Derek Zoolander DURATEC Performance (2008-2011) 165 09-09-2013 01:10 AM
Official: Introducing Next Generation Ford Focus for 2012 FFTeam MK3 Focus 809 12-21-2010 01:33 PM
Problem with heater blower. zlaja General Technical Chat 3 10-30-2009 12:07 AM
Even this fOCUS!!!! Jeezzzz!!!! TORQUERULES Ford Focus & General Car Chat 22 02-11-2007 11:47 PM
