HOW TO: Reinforce your Rear Lower Control Arms. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-13-2008, 09:41 PM   #1
honhon
Fan#: 24778
What I Drive: a better car than a focus.
FF Reputation: 219 honhon Excellent Standing Member honhon Excellent Standing Member honhon Excellent Standing Member
Buy-Sell-Trade Rating: (21)
Well... ive gotten a few questions about how my rear LCA's are modified, and reinforced.
First let me say that i reinforced them because i was originally running the Steeda 28mm rear bar, but didnt like it so i switched to the progress 22mm rear bar.
Lets get started, here are pictures of a stock rear, zx3, zx5 and zx4 rear LCA
those are 2 pictures i took today of my stock OEM LCA's that have been sitting in my locker at work for about 2years now... they only have about 5k miles on them... i dont know if i want to sell them, or modify them, so if you are interested, but not gonna low ball me, PM me..
Heres a quick note on my write up:
what ford did i will use BLUE
and what i did i will use RED
in the pictures below.
So for the writing part of what i did....
but first alittle backround... through SEARCHING on focusfanatics.com, i found that the SVT focus has a reinforced rear Lower control arm... because the rear and front bars are bigger sinse everyone knows the SVTF, is fords little gift to the sport compact world...
but anyways... the reinforcement that Ford did was, they had a piece of straight stock steel welded to the top of the LCA around the endlink hole. it is about 2inches wide by 1inch long and about 1/8th inch or slightly thicker.
heres a quick illustration:
So... what i did... was i talked with Mike at hilbish and aquired the part number for the SVTFocus Rear LCA's, and i ordered them from my local ford dealer across the street... and when i ordered them, i got 2 out of the last 4 in the contry at the time... I dont know if they are still making the "reinforced" models, so if you want just the SVTF arms, give mike a call and check..
so when i got the SVTF rear LCA's i sanded the inside of the arm down, and then cut a piece of straight stock steel the same size as the plate ford had welded on top of the arm, and welded it to the inside of the arm... like so:
So basically, i just coppied the what ford had did to reinforce the LCA ontop, and did it on the inside...
because if you have seen a broken rear LCA, you'll note that it cracks in a straight line with the endlink hole.
If i were to reinforce it more, i would weld a pice of flat steel on the front and rear of the LCA about 1inch wide and 6 inches long...
but i feal my idea is pretty good and doesnt add too much weight... plus... how many people run the 28mm bar? i have my reinforced SVTF arms on and am only running a 22mm, lol, but i am planning to throw an H&R front and rear bar within the next year.
If you have questions and/or comments please post them... i talked with a friend earlier tonight and he said hes gonna post his idea on reinforcing the arms... so there will be more pictures...
and if you have an idea you want to share, by all means please post it!
http://www.full-race.com/r14-fire-video.html
honhon is offline
Old 05-13-2008, 11:38 PM   #2
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Sound great man! This should be a sticky I think.
Instead of welding could one use a big washer or two to help distribute the stress more I wonder. One on top and one on bottom.
jetrinka is offline
Old 05-13-2008, 11:42 PM   #3
honhon
Fan#: 24778
welding would be better due to welding actually "adds" material and is solidly mounted wheres a washer could move and bend.
honhon is offline
Old 05-13-2008, 11:52 PM   #4
jetrinka
jetrinka's Avatar
Fan#: 45622
This is true. Thanks for the write-up.
jetrinka is offline
Old 05-14-2008, 09:48 AM   #5
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO ARCHIVE'.........
Chad (S2)
S2 is offline
Old 05-14-2008, 10:07 AM   #6
honhon
Fan#: 24778
daily bump. i know some people are wondering about this.
honhon is offline
Old 05-14-2008, 10:09 AM   #7
Blackcatn2o
soon to be turbo!
Blackcatn2o's Avatar
Fan#: 48278
What I Drive: 06 silver ZX4 ST
Points 8,020, Level 60
Points: 8,020, Level: 60 Points: 8,020, Level: 60 Points: 8,020, Level: 60
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 48 Blackcatn2o Great Standing Member
Buy-Sell-Trade Rating: (13)
Hey i took 6 pictures of the lca i did last night just have to learn how to upload them.
Blackcatn2o is offline
Old 05-14-2008, 10:42 AM   #8
Fordcus Fan
Fan#: 31604
What I Drive: Blue 2014 twin turbo F150 Limited
Points 674, Level 13
Points: 674, Level: 13 Points: 674, Level: 13 Points: 674, Level: 13
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 3 Fordcus Fan Good Standing Member
Buy-Sell-Trade Rating: (11)
If you run the 28.6 mm bar, you should also upgrade the front to the H&R 24mm at the same time, plus add front & rear stress bars. That way you reinforce the car top to bottom front to rear. My SVTF has that set up over a year 10k city miles later with a lot of hard cornering with sticky tires, no problems.
I don't need training wheels.
(AWD,Traction control,Stability control,Launch assist,Autotrans,Paddle shifters). Got my driving skills driving front/rear wheel drive high performance cars on the street for the last 40 years.
Fordcus Fan is offline
Old 05-14-2008, 10:43 PM   #9
jetrinka
jetrinka's Avatar
Fan#: 45622
The strut bars have no effect on the suspension system whatsoever and don't decrease suspension travel at all. It is for chassis stiffening which quickens the car bodies response to turns and such.
jetrinka is offline
Old 03-02-2009, 02:48 PM   #10
SuperFlea
Illegal Alien
SuperFlea's Avatar
Fan#: 28261
What I Drive: One Of Teh Hottest Wagons on FF!
Points 20,402, Level 90
Points: 20,402, Level: 90 Points: 20,402, Level: 90 Points: 20,402, Level: 90
Level Up 11% Completed
FF Reputation: 44 SuperFlea Great Standing Member
Buy-Sell-Trade Rating: (46)
No pics? =(
<--Jonathan-->
I'm back, Itchbes!
SuperFlea is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Rear Lower Control Arm Bolt Seized, need ideas... Mulingko Wheels & Tires 10 02-19-2008 03:25 PM
WTB: rear lower control arm outer bolts & bushings brandnew161 Archive 0 10-18-2007 10:58 PM
Ford Focus: Suspension & Brakes hotfocus Brakes, Suspension & Body Chassis 0 02-17-2005 04:40 AM
Need new front lower control arms... gthang Ford Focus & General Car Chat 23 11-19-2003 12:35 PM
