How-To: Getrag Transmission Fluid Flush - Page 7 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus SVT > SVT Performance (2002-2004)
Old 04-15-2010, 06:39 PM   #61
BlackJack03
BlackJack03's Avatar
Fan#: 43232
What I Drive: 04 EAP ZX5 SVTF
FF Reputation: 31 BlackJack03 Great Standing Member
Haha...wow, glad this has helped so many people! Thanks for the rep, and glad I could help out!
BlackJack03 is offline
Old 04-22-2010, 04:16 AM   #62
Amn_cihon
Amn_cihon's Avatar
Fan#: 37705
What I Drive: 2003 Ifra-Red SVT focus #1991
Points 1,011, Level 17
Points: 1,011, Level: 17 Points: 1,011, Level: 17 Points: 1,011, Level: 17
Level Up 11% Completed
Forum Activity 2%
FF Reputation: 1 Amn_cihon Good Standing Member
OK, so what is the actual fluid thats spposed to be in the tranny?
...RP Synchromax
...75w-90 Syth. gear oil
...motorcraft full syth. transmission fluid
...Mercon V
Ive searched on here forever and everyone says something diffrent so does the books and the ford dealership.
DINSTAAR!
Amn_cihon is offline
Old 05-11-2010, 06:53 PM   #63
MVent
MVent's Avatar
Fan#: 17635
What I Drive: 2012 Focus Hatchback SE
FF Reputation: 2 MVent Good Standing Member
...RP Synchromax
...Mercon V
I'd like to know as well. Nobody has given a consistent answer as to what fluid is supposed to be in the SVT tranny. What weight is the original motorcraft tranny fluid?
2003 Focus SVT - SOLD
2012 Focus SE Hatchback
MVent is offline
Old 05-16-2010, 06:10 PM   #64
snowmobilerskidoo
Fan#: 75156
What I Drive: 2002 Grey Focus SE
FF Reputation: 1 snowmobilerskidoo Good Standing Member
Fluid type
i have a '02 focus se manual transaxle...time has come for it to be changed but i cant remember the type of fluid. if this helps; it has the 2.0L Zetec-E engine i think it takes synthetic manual transaxle fluid but is it any specific oil viscosity or is it just "Synthetic manual transaxle lubricant"?
snowmobilerskidoo is offline
Old 05-19-2010, 09:22 AM   #65
superunkn0wn
superunkn0wn's Avatar
Fan#: 75120
What I Drive: 2011 Mazdaspeed3
FF Reputation: 1 superunkn0wn Good Standing Member
Well I'm a newb here but thought I should offer some wisdom gained from performing maintenance on my other vehicles:
When changing fluid in a differential/tranny/transfer case that has both a drain and fill plug, ALWAYS remove the FILL plug first. That way, if your drain plug cannot be removed for any number of reasons, you are not stuck with an undrivable vehicle. As a bonus, removing the fill plug first helps to drain the fluid a bit faster.
superunkn0wn is offline
Old 05-19-2010, 09:48 PM   #66
RS3RS
RS3RS's Avatar
Fan#: 19416
What I Drive: 2003 Black ZX5 SVT
FF Reputation: 1 RS3RS Good Standing Member
superunkn0wn: Good point. You never know if some douche bag at Jiffy Lube used an impact gun to tighten down the fill plug.
RS3RS is offline
Old 05-31-2010, 03:30 PM   #67
03#1965
03#1965's Avatar
Fan#: 66541
What I Drive: 2003 Pitch Black SVT
FF Reputation: 3 03#1965 Good Standing Member
...RP Synchromax
...Mercon V
I've never heard or read anything negative about using the RP synthetic. Having just drained and filled with it about three weeks ago, it seems to perform well. I don't think it's a life-altering experience, as some would lead you to believe. But the shift action seems to be at least as smooth as it was with the original fluid in the gearbox.
Ed, Nashville
03 SVT Focus #1965
86 XR4Ti 5SPD
www.86xr4ti5spd.homestead.com
03#1965 is offline
Old 05-31-2010, 06:00 PM   #68
superunkn0wn
Fan#: 75120
I just ordered the Amsoil synthetic manual transmission & transaxle fluid. It's supposed to be very close to the Ford fluid in terms of lubricant properties, since Amsoil bases their recommendation on the ASTM specs for the tranny. I'm no Amsoil fanboy but their science is sound for the most part.
Definitelly avoid any GL-5 gear oil as the synchros are compatible with GL-4 only.
The Mercon V has been recommended by SVT according to some here. It seems that would be sound advice as well, and certainly one of the least expensive options.
...RP Synchromax
...Mercon V
Posted via FF Mobile
Old 08-18-2010, 01:00 PM   #69
qdenning
Fan#: 77729
What I Drive: 2003, Screamin Yellow, SVT Focus
FF Reputation: 1 qdenning Good Standing Member
Thanks!!
I just used this to guide me through changing my gearbox oil too. Pics were a great help.
I went with the Royal Purple Synchromax - I called Royal Purple and that's what they recommended for the SVT.
I noticed that my shifts are smoother - I'm talking instantly different. Was notchy in between gears at times, now much smoother.
I used our air powered oil suction pump to remove my old oil since the drain plug wouldn't budge.
qdenning is offline
Old 10-03-2010, 09:46 PM   #70
Cjscopp
Fan#: 79173
What I Drive: 2003 Focus SVT
FF Reputation: 1 Cjscopp Good Standing Member
Hello SVT owners. Working on my daughters boyfriends 2003 Focus SVT and just completed replacing the clutch with the updated DMF PP and disc. Checked here to get info on fluid replacement and see one post on a counterweight delete. I am curious about that. Can someone please post additional information on that procedure? Are they referring to the big weight on the shift linkage? Thanks,
Alan
Cjscopp is offline
Similar Threads
Need help with this code. 9318 DomestikZx3 General Technical Chat 17 07-11-2012 09:59 AM
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 12:53 PM
is transmission fluid power flush good ? leev General Technical Chat 26 07-29-2009 11:53 PM
how do you fill a mtx-75 with fluid?!!!! help please!!!! firemanchev General Technical Chat 26 09-11-2008 06:18 PM
auto trans fluid change robr General Technical Chat 9 06-07-2005 05:38 AM
