Third brake light not working? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-08-2008, 09:22 PM   #1
2000FordFocus
2000FordFocus's Avatar
Fan#: 9275
What I Drive: Vintage 2000 Focus SE Sport Wagon
FF Reputation: 1 2000FordFocus Good Standing Member
For some reason, my third brake light is not working (I have a wagon, is the light located on the hatch).
The L/R brake light works!
There are about 5 light bulbs on the third brake light, all of them are not working at the moment. It doesn't make sense to have all the light burn out light that and if only one light is out, I assume the other light will work~
I have visually inspected all the bulbs and they look ok....
So what is going on? Why wouldn't it work?
Vintage 2000 Focus SE Sport Wagon (Canadian Version)
Goodyear Assurance Triple Tred P195/60R15
2000FordFocus is offline
Old 05-08-2008, 09:44 PM   #2
foci01
foci01's Avatar
Fan#: 41223
What I Drive: 01 Twiligh Blue SE 4DR Sedan
FF Reputation: 1 foci01 Good Standing Member
Check the harness that runs through the black rubber conduit between the hatch and the body. Look for any chaffed or broken wires.
"Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy crap..What a ride!"
SEDAN REVOLUTION#23
foci01 is offline
Old 05-08-2008, 10:16 PM   #3
2000FordFocus
Fan#: 9275
Ok, so I took apart the third brake light and use a multi-meter to check if any voltage when the brake are pressed.... Nothing!
So that tells me that no electricity is coming out.
This tells me:
1. The module that control the third brake light might not be working, or
2. The wiring from the bake module to the third brake light is broken within (open circuit)...
Replacing the wiring from the brake module to third brake light can be very diffcult~ Not sure exactly how to unwire it~
So I want to determining if the output of the brake module is working correctly or not....
I will need to know where exactly does this wire start. Does anyone know where I can check this? I can use my multimeter again....
Old 05-10-2008, 02:30 AM   #4
Itchrelief
Fan#: 49898
What I Drive: 2007 silver Sedan
FF Reputation: 1 Itchrelief Good Standing Member
Could it be possible that all of the bulbs are wired in series?
It seems very unlikely and a cruddy way to wire a string of light bulbs (christmas tree lights anyone?), but considering it could be a pita to check/replace the wiring, I'd try to eyeball the bulb filaments and see if any are broken.
Itchrelief is offline
Old 05-10-2008, 10:23 AM   #5
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
No.
penguin is offline
Old 05-10-2008, 10:45 AM   #6
Warren914
Warren914's Avatar
Fan#: 52443
What I Drive: 2003 Grey SE wagon
FF Reputation: 1 Warren914 Good Standing Member
Third brake light
Look at the wiring diagram for the car.
http://members.rennlist.org/warren/focuswiring.pdf
The third brake light is shown on the lower left of the diagram, labeled as high mounted stop lamp.
If your other brake lights are working, the switch is ok.
Check the bulbs, make sure the ground connection is good, and then follow the green/yellow wire. The wiring harness can be accessed through the small square port on the driver side when you open the hatch. Pull the entire side off the car and you can disconnect the plugs and find which wire isn't working properly.
Warren914 is offline
Old 05-11-2008, 11:57 AM   #7
sleep2much
sleep2much's Avatar
Fan#: 55921
What I Drive: Jag XJ8, wife has the FocusTDI
FF Reputation: 1 sleep2much Good Standing Member
I've seen from earlier posts the most common reason was the wires worn out in the rubbery tube between the body and hatch door, I had the exact same problem with no third light, with the MOT due soon I scoured the internet and found this site, and the possible fault, with screwdriver in hand I nipped out for a check, 1, all the bulbs were good, 2, pulled back the rubbery thing and there it was, the green wire was broken and the black on its way out, a quick snip and splice.......just the damn same, it may have cured their problem but I'm now stumped as to what mine could be.
sleep2much is offline
Old 07-28-2008, 10:38 PM   #8
KAISER
KAISER's Avatar
Fan#: 57987
What I Drive: Special Edition 2000 FOCUS KONA
FF Reputation: 1 KAISER Good Standing Member
Cool diagram warren914. Do you have the wiring diagram for the windshield washer pump too? Thanks!
(¸.-´ (¸.-` ♪ by ΚΛISΞЯ ♪.-´¯`-.♪
©opy®ight 2010
KAISER is offline
Old 07-29-2008, 12:17 AM   #9
penguin
Fan#: 21700
So, did you check the wires between the hatch and the body as suggested. That's typically where the problem lies.
penguin is offline
Old 07-30-2008, 06:26 PM   #10
gostinger
Fan#: 44867
What I Drive: 2013 SE Black Pack Loaded 5 Spd MTX
FF Reputation: 1 gostinger Good Standing Member
open the hatch and the access compartment on the left the harness starts in there
gostinger is offline
Similar Threads
Problem with turning signal, brake light, and cruise~ 2000FordFocus General Technical Chat 6 05-05-2008 11:44 PM
2008 LED third brake light fit 05-07 sedan models?? Focus_723 MK2 Focus 17 10-24-2007 11:38 PM
brake light flicker going round a bend? talonk4 Wheels & Tires 1 02-01-2006 12:21 PM
Parking brake light Newkleus General Technical Chat 4 01-10-2006 08:07 PM
Brake Light on.. Happenedtoyou General Technical Chat 4 07-24-2005 08:53 PM
