#1 | ||||
LETS TURN DIRT!!!!
I "borrowed" this from someone else and decided it should be a sticky
Focus ecu pinout 1 shift solenoid - B gn/bu 2 not used 3 IMRC module signal wh/rd 4 Transmission range sensor - reverse gn/bu 5 not used 6 not used 7 transmission range sensor - 1st / EVAP vent valve gn/wh - bk/og 8 transmission range sensor - 2nd gn/og 9 Barometric absolute pressure sensor wh/bk 10 not used 11 transmission range sensor - drive gn/bk 12 switched ground bk/wh 13 Flash EEPROM power supply og/bk 14 not used 15 SCP - bu/bk 16 SCP + gy/og 17 switched ground bk/wh 18 not used 19 TX signal gy/og 20 Injector 3 control bk/bu 21 crankshaft position sensor + wh/rd 22 crankshaft position sensor - bn/rd 23 ground bk/ye 24 ground bk/ye 25 ground bk 26 switched ground CDA (coil 1-) bk/og 27 start inhibit relay circuit bk/rd 28 vehicle speed signal output wh/vt 29 overdrive cancel switch input gn/bk 30 not used (12v input from auto tranny only. DO NOT hook this up on manual trans ecu's, you will fry them) 31 Power steering pressure sw input / press. sensor bk/yel / wht/vt 32 sensor return (reference/ground) bn/ye 33 Output shaft speed sensor - bn/bu 34 turbine speed sensor + wh/vt 35 HO2S 2 signal wh/rd 36 MAF return bn/bu 37 transmission fluid temp + wh/gn 38 cylinder head temp / coolant temp sensor wht/vt / wh 39 MAF input wh/vt 40 fuel pump monitor gn/bk 41 A/C clutch pressure cycling switch input gn/ye 42 PATS indicator control bk/og 43 sensor signal wh/bu 44 Pressure control solenoid A + gn/og 45 Camshaft timing actuator control bk/rd 46 Low fuel indicator bk/wh 47 electronic vacuum regulator solenoid valve control bk/gn 48 not used (tach signal, anything needing this signal can be hooked here) 49 CAN bus L bu/rd 50 CAN bus H gy/rd 51 ground bk/ye 52 switched ground CDB bk/gn 53 RX signal wh/gn 54 fuel pump output / switched ground bk/wh - bk/bu 55 hot at all times rd 56 EVAP purge valve control bk/bu 57 Knock sensor + wh/bk 58 VSS / OSS + wh/bu - wh/bu 59 generator monitor circuit gy 60 HO2S 1 signal wh 61 not used 62 fuel tank pressure transducer sensor signal wt/vt 63 fuel rail pressure transducer sensor signal wh/gn 64 transmission range sensor P/N / clutch switch grn/yel / wht 65 exhaust pressure transducer signal wh/bu 66 not used 67 EVAP canister vent control bk/og 68 switched ground bk/bu 69 switched ground bk/ye 70 injector 1 control bk/wh 71 power hold relay output (VPWR) gn/ye 72 generator communicator command lb 73 shift solenoid - A / check fuel cap light grn/yel / blk/wht 74 not used 75 gnd (power return) bk/wh 76 turbine speed sensor - / signal return / sig rtn bn - wh/vt - bn/wh 77 power ground bk/ye 78 not used 79 not used 80 IMRC control bk/wh 81 pressure control solenoid A- bk/rd 82 Shift solenoid C gn/bk 83 idle air control valve control grn/yel 84 not used 85 camshaft position sensor signal / sensor sig rtn wh/vt - bn/wh 86 sensor signal wh/rd 87 knock sensor - bn/ye 88 MAF output wh/bu 89 throttle position sensor signal wh 90 VREF ye 91 transmission fluid temp - bn 92 stop lamp switch input gn/rd 93 HO2S 1 control bk/ye 94 not used 95 injector 4 control bk/og 96 injector 2 control bk/ye 97 power hold relay output gn/ye 98 not used 99 shift solenoid D gn/og 100 HO2S 2 control bk/bu 101 not used 102 shift solenoid E gn/wh 103 ground bk/ye 104 not used
[B]1951 McCormick FARMALL M 2007 MINI Cooper S Turbo... new project car 1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel 2004 Harley V-Rod.... sex on wheels 2011 Harley Electra Glide Ultra Limited [/b] |
Remove Advertisements |
Fan#: 1
#2 | ||||
Late for Dinner
I didn't realize I'd changed my pb account around and broke all my previous links.
so here's all the info you ever wanted for wiring and pinouts, including plugs... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
If Guns Cause Crime, Mine Must Be Defective Last edited by WD40; 09-24-2010 at 01:07 PM. |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| ATX to MTX Swap Guide | boosted2nr | Engine & Transmission Swap | 92 | 05-04-2013 01:10 PM |
| *Ford Focus Awards* | DrkKnight614 | Ford Focus & General Car Chat | 31 | 02-08-2009 12:21 PM |
| The Ford Focus Parts List! | gthang | MK2 Focus | 13 | 01-26-2009 11:05 PM |
| Hood Companies | S2 | MK1 Focus | 1 | 06-20-2005 08:57 AM |
| Body/Lip Kit Companies | S2 | MK1 Focus | 1 | 12-04-2004 04:20 PM |
