spring noise from front suspension after coil change - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-06-2008, 05:35 PM   #1
siffleu
Fan#: 52304
What I Drive: 2002 Focus SE
FF Reputation: 1 siffleu Good Standing Member
Question spring noise from front suspension after coil change
Hi there,
I own a 02 sedan, with SPI engine, 80 000km, had the coil problem, (both were broken) and about a month and half later, I have "spring" noise when I turn the steering wheel and when the suspension traver up and noise
doesn't seem to come from the top plate, it sound more like a "spring" noise "squi squi squi" when the suspension is working from up to down, and a noise that sound like a old house door that make noise when I turn the steering wheel...
the noise seem to come from both side...
anyone have an explication ?
siffleu is offline
Old 05-06-2008, 08:14 PM   #2
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Check the swaybar endlinks to see if they are tight.
Also check the main nut that retains the piston in the strut on the top of the strut tower. The big one in the middle of the three small ones. If it is not tightened down all the way it will allow the spring to shift around when going over bumps and such making a noise.
jetrinka is offline
Old 05-06-2008, 08:34 PM   #3
zx505focus
AKA KILLA XB
zx505focus's Avatar
Fan#: 44497
What I Drive: 2010 Scion XB RS7
Points 10,155, Level 67
Points: 10,155, Level: 67 Points: 10,155, Level: 67 Points: 10,155, Level: 67
Level Up 27% Completed
FF Reputation: 44 zx505focus Great Standing Member
Buy-Sell-Trade Rating: (19)
this happen to me when i put my svt suspension on, all it was, was the upper cup was upside down. check that out.
Murasaki Warrior
zx505focus is offline
Old 05-06-2008, 09:02 PM   #4
siffleu
Fan#: 52304
upper cup ?
siffleu is offline
Old 05-06-2008, 09:05 PM   #5
jetrinka
jetrinka's Avatar
Fan#: 45622
The cup that retains the top of the spring just as the cup below the spring retains it. It fits between the spring and the upper bearing mount located just under the top of the shock tower.
jetrinka is offline
Old 05-12-2008, 07:04 PM   #6
siffleu
Fan#: 52304
I've done all of the above
the rubber on the swaybar endlink are worn on both side
is this can cause the "squeee squee rust spring like sound"
the sound can be hear by just adding weight into the car so I did the test with a helper and put my hand on the endlink and I was able to feel the vibration of the sound into the endlink
is worn, cracked rubbers of endlink can cause this annoying noise ?
siffleu is offline
Old 05-12-2008, 08:04 PM   #7
ken6x6
ken6x6's Avatar
Fan#: 31100
What I Drive: 03 Black SVTF
Points 3,466, Level 36
Points: 3,466, Level: 36 Points: 3,466, Level: 36 Points: 3,466, Level: 36
Level Up 78% Completed
FF Reputation: 2 ken6x6 Good Standing Member
Buy-Sell-Trade Rating: (7)
make sure the spring is set in to the bottom cup correctly, there is a certain way the spring has to sit. the bottom cup looks like the bottom of the spring and it fits rite in.
i didnt have mine it right and i kept making a "twang" noise. all i did was jack up the front end and spun the spring till it popped in place.
03 SVTF #3804, full suspension, CM FX300, Torsen LSD, no cat, dual exhaust, Tom's tune. 167whp 154 wtq (dyno jet) and some other stuff. dyno- http://www.youtube.com/user/ken6x6#p/a/u/1/cKH4FX7c9L4
ken6x6 is offline
Old 05-12-2008, 08:10 PM   #8
siffleu
Fan#: 52304
what do you think of that ?
http://img99.imageshack.us/my.php?im...oto0019vd6.jpg
siffleu is offline
Old 05-12-2008, 08:32 PM   #9
ken6x6
ken6x6's Avatar
Fan#: 31100
yup ... that looks good to me.
ken6x6 is offline
Old 05-12-2008, 08:37 PM   #10
zx505focus
AKA KILLA XB
zx505focus's Avatar
Fan#: 44497
yes, thats what im talking about, thanks
Murasaki Warrior
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
weird noise from left front suspension fast5 Brakes, Suspension & Body Chassis 16 08-06-2004 02:38 PM
Suspension noise Sagent00x General Technical Chat 12 07-21-2004 02:16 AM
Wings West Front Air Dam, 2000 Focus stock bumper, 2000 Focus stock suspension sale! meanpiolin Archive 0 07-10-2004 03:51 PM
front suspension sounds UGLY!!! dwdgsi03 Brakes, Suspension & Body Chassis 3 06-02-2004 10:32 AM
