blower fan only work in position 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-06-2008, 05:32 PM   #1
siffleu
Fan#: 52304
What I Drive: 2002 Focus SE
FF Reputation: 1 siffleu Good Standing Member
Hi there,
I own a 02 sedan with SPI engine and starting last week I have no more speed on my blowing fan, only position 4 is available, all others are OFF...
should I consider the control as the source ?
I hear about a possible resistance near the fan motor itself.. anyone can be specific about that can be done ?
thanks
siffleu is offline
Old 05-06-2008, 05:36 PM   #2
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
What I Drive: 2014 ford
Points 16,124, Level 81
Points: 16,124, Level: 81 Points: 16,124, Level: 81 Points: 16,124, Level: 81
Level Up 55% Completed
FF Reputation: 23 MattZX3 Great Standing Member
Buy-Sell-Trade Rating: (4)
sounds like the blower motor resistor to me
there is a resistor, on the actual blower motor
sounds like its bad...
never changed one on a focus, but shouldnt be too hard
MattZX3 is offline
Old 05-06-2008, 05:52 PM   #3
siffleu
Fan#: 52304
any procedure to test it ?
siffleu is offline
Old 05-06-2008, 06:03 PM   #4
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
i believe there is a way, but you would be better off buying the part and replacing it.
if it doesnt fix it, take the part back, but i can almost guarantee 100% its the resistor
MattZX3 is offline
Old 05-06-2008, 06:48 PM   #5
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
With those symptoms, it's a 98% probability the problem is the fan motor resistor. Do a search on this message board and you will find a really good "how to," complete with pictures.
penguin is offline
Old 05-07-2008, 11:35 AM   #6
Titan1969
Titan1969's Avatar
Fan#: 38797
What I Drive: '00 Pitch Black ZX3 236000 miles!
FF Reputation: 1 Titan1969 Good Standing Member
Its the fan switch
Originally Posted by siffleu View Post
Hi there,
thanks
I had same issue. I could get fan to work with a/c if I held the switch halfway between 3 and 4. If this works for you, it needs a switch. I used mine like this for several years until it finally caught on FIRE . Once I replaced it everything worked aok.
Titan1969 is offline
Old 05-07-2008, 06:19 PM   #7
siffleu
Fan#: 52304
i have replaced the resistor
25$cdn
here is the old one
the new one is black
problem solved!
thanks
siffleu is offline
Old 05-07-2008, 06:38 PM   #8
penguin
Fan#: 21700
Thanks for letting us know how it worked out.
It is a bit frustrating when one provides info and never knows the outcome.
penguin is offline
Old 05-07-2008, 08:18 PM   #9
siffleu
Fan#: 52304
I will do the same thing for every problem I will have with it..
done the same thing with the front coil suspension problem.. (broken one)
50% tell it was broken, 50% say it was ok...
bit scary... :P
siffleu is offline
Old 05-14-2008, 09:35 AM   #10
dsordlyerc
Fan#: 56005
What I Drive: 2001 Green Focus - Girlfriends
FF Reputation: 1 dsordlyerc Good Standing Member
Replace the resistor. Pull the glove box out, it's behind there. We're on our third one on an 01. The parts guy jokingly asked if I wanted to go ahead and buy extras.
dsordlyerc is offline
Similar Threads
HVAC fan control knob not working... Speedwagon General Technical Chat 6 10-10-2014 05:01 PM
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
Fluidyne SVT radiator and stock fan fitment? 99dot General Technical Chat 2 03-16-2006 02:35 PM
fan switch or blower relay needin help General Technical Chat 4 08-09-2004 01:07 AM
2000 focus blower fan location needed guest General Technical Chat 3 07-06-2004 10:56 PM
