Key Fob Programming How-To - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-10-2012, 02:02 AM   #21
bebb88
Fan#: 107149
What I Drive: 2005,grey,focus
FF Reputation: 1 bebb88 Good Standing Member
I tried all this and the remote still would not work on the doors. I have a ford focus 2005 hatchback. I am able to go through the programming procedure ok but am unable to lock / unlock doors using remote.
bebb88 is offline
Old 05-27-2013, 02:03 AM   #22
FordFocus2002
Fan#: 113754
What I Drive: 2002 Green Ford Focus LR (MK1)
FF Reputation: 1 FordFocus2002 Good Standing Member
Hi guys I just brought a new remote I followed the 2000 - 2004 procedure it only got the doors locking and unlocking but it won't allow the new remote to start my 2002 Focus ????
FordFocus2002 is offline
Old 05-27-2013, 02:55 AM   #23
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,621, Level 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Level Up 14% Completed
Your car doesn't have remote start.
elsolo is offline
Old 05-27-2013, 03:05 AM   #24
FordFocus2002
Fan#: 113754
I know it doesn't.
Old 06-19-2013, 05:15 AM   #25
hillbagger
Fan#: 115906
What I Drive: 2008 Silver Focus Style
FF Reputation: 1 hillbagger Good Standing Member
Newbie here - so, sorry if I'm diving in and posting in the wrong place. Having tried all of the above re. programming a key fob for my 2008 Focus Style 1.8TDCI - I never get a 'bong' after turning the key to position II x 4 in 6 seconds. I've tried variations i.e. position I to position II / position 0 to position II but still no 'bong' - and red light on dash keeps flashing. I'm normally pretty good at fiddling about with things but this just isn't working for me. Any suggestions gratefully received.
Cheers
Ben
hillbagger is offline
Old 07-09-2013, 06:52 AM   #26
sternicka
Fan#: 116552
What I Drive: focus 2007 trend
FF Reputation: 1 sternicka Good Standing Member
I have similar problem than Hillbagger. I never had any problem programming the key in my focus 07, but after some years I tried to program a new key and it is impossible to enter in programming mode. I folllow the procedure step by step and it's impossible. I did it with all keys I have and the result is the same. When I should receive the "beep" there is a quickly message shown in the frontal panel "steering assist failure" but it keeps less than a second and it disappears. After it, the car never shows me any error message.
I will apperciate any help.
Thanks
sternicka is offline
Old 09-04-2013, 08:19 AM   #27
andysvision
Fan#: 117253
What I Drive: 2006 Grey Ford Focus
FF Reputation: 1 andysvision Good Standing Member
Hello i have a 2006 focus and i want to switch my non fliping key with a 2008 fliping key witch i will buy on ebay,can this bee done or this keys use different chips and frecuences?if yes,are this the steps i should follow thanks :)
andysvision is offline
Old 09-16-2013, 10:10 AM   #28
frosty68
Fan#: 118971
What I Drive: Red 05 1.8 petrol
FF Reputation: 1 frosty68 Good Standing Member
I have the same issue, fob locks/unlocks the doors,and opens the boot lid, but if i attach a key I can't start the car with it, same key attached to the original fob starts perfectly.
frosty68 is offline
Old 09-16-2013, 10:21 AM   #29
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 520, Level 10
Points: 520, Level: 10 Points: 520, Level: 10 Points: 520, Level: 10
Level Up 40% Completed
Forum Activity 10%
FF Reputation: 1 Leora83 Good Standing Member
The ignition key has a transponder chip that the car reads in order to start (passive anti-theft system, or PATS). Without the chipped key you are SOL. If you have a key cut it will work on the doors but unless you spend the bucks to get a chipped key programmed to your vehicle, you won't get the car started.
The remote has zero effect on your vehicle's starting ability.
Leora83 is offline
Old 09-28-2013, 12:32 PM   #30
iowford
Fan#: 119315
What I Drive: Focus
FF Reputation: 1 iowford Good Standing Member
Hi guys
I've tried this process and had some major problems which I'm going to need some help with!
I bought a 2001 Ford Focus (UK Car) with two keys, one worked the doors with the three button controls and also started the car and the ignition. The other opened the door as a key (not the remote) and went in the ignition but would not start the car (dash lights came on though)
I tried the process of key back and forward 4 time as described on page one of this thread with the non working key and it made the buttons on the previously working key not work. I then tried the working key in the ignition and now it won't start the car either.
I have tried to repeat the process from page one with the previously working key and it's back working the doors with the remote but still no ignition!
Thanks
The key looks like this:
_______________________________________
Nearly resolved - Some help still required
(Left original post as it may help someone)
It would seem that there is some sort of security feature that locks out the immobiliser for a period when a non programmed key is inserted.
Can someone help me make the two keys work the same?
KEY 1
Unlocks car as a key
Unlocks car as a remote
Turns off immobilser so car can start
KEY 2
DOES NOT Unlock car as a remote
DOES NOT Turn off immobilser so car can start
iowford is offline
Similar Threads
Need Ford Recall, TSB, or your vehicle history? Click Here! DJ Lukdogg General Technical Chat 368 10-13-2008 06:04 PM
Lost Key FOB Midas Ford Focus & General Car Chat 0 12-06-2007 02:55 PM
Key Fob compatibility drbadskwerl General Technical Chat 2 11-15-2007 05:30 PM
Key Fob Battery Question miniboon Car Audio, SYNC, MyFord Touch & Electronics 2 10-01-2007 02:01 PM
Fob and key question 96ConceptGL General Technical Chat 10 06-02-2007 09:19 AM
