Key Fob Programming How-To - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-22-2012, 11:47 AM   #11
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
I have a Ford Transit Connect
The procedure is different in a subtle way between the owner's manual and the service manual. Both will work but the service manual allows for more leeway
So different years will make a difference and also consult a Ford Workshop manual
mikeeshaq is offline
Old 07-22-2012, 12:12 PM   #12
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
Djzx3
New fobs are under $10 on ebay, shipped.
elsolo is offline
Old 09-08-2012, 02:01 PM   #13
CREWZIN
CREWZIN's Avatar
Fan#: 80454
What I Drive: 11 Focus, 01 PT Cruiser, 87 Vette
FF Reputation: 1 CREWZIN Good Standing Member
Just ordered 2 RED extra remotes for the wife on eBay. $15.00. I'll try the 07-11 remote programming as soon as they arrive. Thanks for the info.
She's always grabbing my keys by mistake that hang on the hooks as they both look similar. Shouldn't always blame her, I do the same when in a hurry. Now, if she has the RED fob, there shouldn't be any mistakes.
Also ordered the red rim stripes that I saw someone else put on their Focus. Will take some pics when they arrive and I've put them on.
PT Cruiser Links Moderator.
Public Service Officer, Citrus County Sheriff's Department
CREWZIN is offline
Old 10-10-2012, 07:04 AM   #14
longarm
Fan#: 328
What I Drive: 07 Infra-Red ST SAP
FF Reputation: 1 longarm Good Standing Member
I have a 2007 ST. I tried the instructions listed above and it doesn't work. I turn my key on and off 4 times and in the off position with the key in the ignition, it chimes.
Then I push the lock button on a remote and the headlights flash and the door locks cycle. I then try it for a second remote and nothing. I can only get this done for one remote and it's frustrating. Any suggestions?
**EDIT** Never mind, I'm good. I dug up my owners manual and got r done. The sequence was different than what was listed here.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote."
- Benjamin Franklin, 1759
longarm is offline
Old 10-10-2012, 04:28 PM   #15
CREWZIN
CREWZIN's Avatar
Fan#: 80454
The instructions here were good for our 2011 BUT, had problems at first. Wanted the new RED and old black to work and apparently once you program the new ones, the old ones don't work anymore and it seems liked if I left the second one of the same color in or near the car, it took the program away from it while programming the second key. Very frustrating for awhile but got both red done and just not using the black ones, not that I needed them anyway.
The RED rim stripes didn't work at all. Guess they really meant for the wheels on our car. Not really enough room on the outside of the spokes to get the red stripe on.
CREWZIN is offline
Old 10-11-2012, 02:31 AM   #16
SD_ZTW
SD_ZTW's Avatar
Fan#: 91209
What I Drive: 2003 White ZTW, D23 PZEV, ATX
FF Reputation: 2 SD_ZTW Good Standing Member
Hey Longarm,
Curious to hear what worked for your car. It will help the group. Also, just saw you said you switched 4 times but for the 2007 model, key needs to be turned 8 times...
Hey Crewzin,
You found that out. Yep, each time you change the code, you got to do all the ones you want to use at the same session. The key fobs not in
the car are no longer any good.
George
2003, ZTW, White wagon
ATX, 2.3L Duratech
SD_ZTW is offline
Old 10-28-2012, 11:15 AM   #17
red_devil_04
red_devil_04's Avatar
Fan#: 71963
What I Drive: 2004 Vermillian Red SE Sedan
FF Reputation: 1 red_devil_04 Good Standing Member
hey, so i programmed my new remote that i got last week and was able to be successful with it. now, i have my step brother with another focus and a coworker with a ranger that can unlock my car with their fobs even though i closed the programming when i did mine. anyone know exactly whats going on?
'04 SE Sedan: TEIN lowering springs, straight pipe/thrusher exhaust, JBA shorty header, FSWerks Cool-Flo Intake
Sedan Revolution #182/NW Posse #40
Why fit in when you were born to stand out?
Dr. Seuss
red_devil_04 is offline
Old 10-28-2012, 12:28 PM   #18
SD_ZTW
SD_ZTW's Avatar
Fan#: 91209
Red_Devil_04,
Go back to your old fob and see if the problem persists. If so the new fob is at fault.
Program away from other cars if possible.
ATX, 2.3L Duratech
SD_ZTW is offline
Old 10-28-2012, 01:41 PM   #19
red_devil_04
Fan#: 71963
k when i get home tonight i'll try going back to the other fob. right now both fobs are programmed to the car and i dont know how to remove any programmed fobs.
Dr. Seuss
Old 10-28-2012, 02:39 PM   #20
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,809, Level 73
Points: 12,809, Level: 73 Points: 12,809, Level: 73 Points: 12,809, Level: 73
Level Up 90% Completed
Forum Activity 99%
Going through the programming sequence with the fob or fobs you want to use SHOULD make just that one or ones work.
That is, for example, if you go through the sequence with just ONE of the fobs that would be the only one that will work until you repeat the procedure with both.
"adding" a fob requires BOTH to be present for both to work....
My owner's manual warns that you need all on hand that you want to use B4 starting the procedure for this reason.... Also it mentions that there is a maximum of 4 that can be programmed to work at the same time.
I remember having to do it twice B4 I got it right when I added an extra (only one came with the used car).
Luck!
sailor is online now
Similar Threads
Need Ford Recall, TSB, or your vehicle history? Click Here! DJ Lukdogg General Technical Chat 368 10-13-2008 06:04 PM
Lost Key FOB Midas Ford Focus & General Car Chat 0 12-06-2007 02:55 PM
Key Fob compatibility drbadskwerl General Technical Chat 2 11-15-2007 05:30 PM
Key Fob Battery Question miniboon Car Audio, SYNC, MyFord Touch & Electronics 2 10-01-2007 02:01 PM
Fob and key question 96ConceptGL General Technical Chat 10 06-02-2007 09:19 AM
