Klondike's Build Thread: - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-24-2008, 07:17 PM   #61
Klondike
GreyRice WOoT!
Klondike's Avatar
Fan#: 25991
What I Drive: GI, '07 zx3 LG
Points 33,169, Level 100
Points: 33,169, Level: 100 Points: 33,169, Level: 100 Points: 33,169, Level: 100
Level Up 0% Completed
FF Reputation: 53 Klondike Excellent Standing Member
Buy-Sell-Trade Rating: (26)
so if i get the kicks as well, i should get a 30 watt rms 2 channel amp for the speakers? or can you run a 300 watt in 1 channel? im guessing then you cant adjust the frequency for each speaker then, just as a whole?
Focus Nation
Focus Revolution
Chrenron 1 of 3
Velveeta Lover Shell#1
LOTH 00!
Klondike is offline
Old 04-24-2008, 07:20 PM   #62
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
What I Drive: SC 5.0 FOFO BUILD IN PROGRESS
FF Reputation: 106 SquillyB Excellent Standing Member SquillyB Excellent Standing Member
Listen and watch in my vehicle with a similar setup. As I move the camera phone you can hear the sound stage change. You can actually hear the mid bass change as I lean away from the seat towards the dash. I move to a point where almost all the mids are gone then they come back in as I pass that area in the car and the front drivers are picked up near your feet!!
Often not enough care is taken to aim these properly. When I have the vehicle with me hear to work on the effects are dramatic indeed as you can hear once all the staging of the physical components is done.The pin point accuracy that these speakers are capable of is amazing.
MECP 1ST CLASS
FF08 FASTEST OVERALL TRACK TIME
SquillyB is offline
Old 04-24-2008, 07:28 PM   #63
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
You can tune individually with products like the RF 360.1 and 360.2 as well as JL's clean sweep. Seperate tuning for individual speakers is pretty crazy. The RF 360.2 is my drug of choice for doing this. I have tuned many a car from other shops installs using these and its incredible. Takes me about a day of being in the car, maybe 6-8 hrs of actual listening and RTA work with the O-scope.
If you were to purchase the amp that was powering the speakers in the videos, it's a RF T4004. You can tune seperate front and rear channels as well as gains for both. These vid's are with gains at two diffrent levels, alicia keyes tunes were SQ pre amp matched and the tool and other stuff was more of a stereo tune for on stage listening. Also I only had it wired to run 100 watts RMS to each corner. You could run a bridged stereo mode and only lose your fade control on the HU. However you could still adjust the levels using the two gains. It would run just under 200 rms peak to them, double the sound at low to mid volumes meaning a much richer fuller sound.
MECP 1ST CLASS
SquillyB is offline
Old 04-24-2008, 07:45 PM   #64
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
And now to upload the next step...
Fiberglassing the shape of the enclosure.
MECP 1ST CLASS
SquillyB is offline
Old 04-24-2008, 07:46 PM   #65
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
This is gonna need a sticky when I'm done fo sho!!!
MECP 1ST CLASS
SquillyB is offline
Old 04-24-2008, 08:24 PM   #66
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
Ok I'm out of fiber cloth I thought I had some, so lets do some shopping shall we?
Off to Lowes...
MECP 1ST CLASS
SquillyB is offline
Old 04-24-2008, 09:31 PM   #67
starfuryt550
I Speed Often.
starfuryt550's Avatar
Fan#: 18440
What I Drive: Audi S4, Turbo ZX3
Points 22,906, Level 93
Points: 22,906, Level: 93 Points: 22,906, Level: 93 Points: 22,906, Level: 93
Level Up 56% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 23 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (58)
this looks sick! be sure to do the how-to asap! I want to make those trim panels black/wrapped with something, as well as add tweeters!
Daily: Audi S4 b5 | Project: Turbo ZX3
LED Conversions | Vinyl Carbon Wrapping | Powdercoated Valve Covers
starfuryt550 is online now
Old 04-24-2008, 09:33 PM   #68
starfuryt550
I Speed Often.
Fan#: 18440
Forum Activity 21%
Off to Lowes...
...and let us know what type of cloth you used!
...and are you using spray adhesive for the cloth? I'm sure Lowes/Home Depot or Jo Ann fabrics has that stuff, right?
Old 04-24-2008, 10:57 PM   #69
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
The how to is happening around you. This whole thread will be edited down once I'm done or should I say organized.
As far as the cloth goes, any kind will work, just not to thick please. I use the Elmers fiber cloth because I've had good times with it.
It's in this section^^^
MECP 1ST CLASS
SquillyB is offline
Old 04-24-2008, 11:18 PM   #70
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
Ok, I hated the little tweet I made, luckily it was only the mock version. After stretching the cloth over it a few ways it looked bad, so I killed it.
In exchange for this...
Same thing only different. Start by cutting a hole that fits the tweet all the way through, then cut out the hole in the shape of a square.
Round off all flat edges so everything is smooth, this will give you a cleaner looking line when fiberglassing. And its far easier to fill and smooth with bondo when its a round edge as opposed to a sharp flat one.
MECP 1ST CLASS
SquillyB is offline
Similar Threads
Need help with a duratec build archie DURATEC Performance (2003-2007) 13 07-14-2006 04:40 PM
