Klondike's Build Thread: - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-27-2008, 04:02 AM   #121
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
ok so that was issue number 1 with my pod. i had the bondo mixxed too hot. no wonder it looked like ass.
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 04-27-2008, 08:30 AM   #122
Waffles ZX3 Kona Sport
WAFFLEY!
Waffles ZX3 Kona Sport's Avatar
Fan#: 10426
What I Drive: 2006 Fusion SE Midnight Blue
FF Reputation: 11 Waffles ZX3 Kona Sport Great Standing Member
Buy-Sell-Trade Rating: (6)
Damn dude this is gonna be sick! Very nice writeup billy.
Waffles ZX3 Kona Sport is offline
Old 04-27-2008, 09:55 AM   #123
Klondike
GreyRice WOoT!
Klondike's Avatar
Fan#: 25991
What I Drive: GI, '07 zx3 LG
Points 33,169, Level 100
Points: 33,169, Level: 100 Points: 33,169, Level: 100 Points: 33,169, Level: 100
Level Up 0% Completed
FF Reputation: 53 Klondike Excellent Standing Member
Buy-Sell-Trade Rating: (26)
i cant wait to get these bad boys and creme my pants everyday lol
Focus Nation
Focus Revolution
Chrenron 1 of 3
Velveeta Lover Shell#1
LOTH 00!
Klondike is offline
Old 04-27-2008, 08:18 PM   #124
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
What I Drive: SC 5.0 FOFO BUILD IN PROGRESS
FF Reputation: 106 SquillyB Excellent Standing Member SquillyB Excellent Standing Member
Layer #2...whammy!!!
smooothhhh..... or smoother anyway
That sanding thing where it is still wet will do this to your sand paper so change it frequently.
Keep your edge nice and clear,
a little finer^^
See the diffrence between the two, left is after right is before.
MECP 1ST CLASS
FF08 FASTEST OVERALL TRACK TIME
SquillyB is offline
Old 04-28-2008, 01:58 AM   #125
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
Now for the instructional part of the deal. When you buy bondo it comes with the red tube I spoke of earlier that will match the color of the speader when done properly.
I save this for finishing so I can see the contrast better. You will be able to see where the old bondo was and the new bondo went down.
MECP 1ST CLASS
SquillyB is offline
Old 04-28-2008, 02:04 AM   #126
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
Remember, before and after...
These are that "after" once they have been hit with 150 grit . From rough (80), to the medium (120-150) now...
The largest blemishes you should have at this point are about this big, the size of a pin head, no bigger. You might "see" some lines but you should not be able to feel them with your finger tips.
MECP 1ST CLASS
SquillyB is offline
Old 04-28-2008, 02:08 AM   #127
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
When your spearding this layer you will have some left as the work time comes close to a hault. When your making the pass and you realize its getting thick, dig into the pile you have left and jam it in some areas you haven't started yet. Smear it in tight as possible. No need to waste good bondo. You can tell the areas I filled in quickly down by the tweeter's side.
and some along the ridge on the lower right hand curve. Gives us an "edge" to work with.
MECP 1ST CLASS
SquillyB is offline
Old 04-28-2008, 02:20 AM   #128
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
ENTER THE RED TUBE OF HEART BREAK!!!
Here comes the notorious red hardener I keep talking about. Grab some 150 grit or close to, a new spatula, a good can of bondo ( no old shit here) some clean spreaders, and the green paper. The paper comes in all kinds of thickness but I use the pretty thick stuff. Contractors paper. Cut it into strips that will cover about 1 sq ft. I have boards I use for work areas as you can tell, so just wrap the paper around the board and tape the other side. This gives you a nice clean surface to mix on. This batch will be very important, it has to be perfectly mixed. No dust in it, no air bubbles, nothing, smooth or it won't turn out that way.
I choose the green so it would add nice picture contrast to the red bondo.
The #2 spreader from Bondo is shown here. Get a glob of bondo on your paper about the same size as the spreader and half an inch thick. then lay out a 1" thick line of hardener.
Start mixing, remember to scoop-swirl 360* then scrape swirl-repeat starting at scoop-swirl. NO AIR BUBBLES!! And you want it to be the color of the spreader. Darker red= less work time / 1/2 the cure time__lighter red = more work time 2X the cure time. So be careful. Getting ti the same color will give you about 5 minutes once uniform in color.
Yup, you guessed it, "squilly will mix that hot" start at the edge and get a good layer on there all the way to the other layer. I know at this point people are like, "damn, thats a lot of bondo; gonna be heavy" NOT TRUE. I sand so much off you could never tell how much went on originally.
Again, even with the new color, dump the "oh shit" bondo into large gaps and holes , press it in and set it down, you can't work it any more now.
MECP 1ST CLASS
SquillyB is offline
Old 04-28-2008, 02:24 AM   #129
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
Now remember the pin head holes on the top we saw. Hence the red tube of heartbreak to show us what we really missed after we sand it smooth again. Watch how much we really needed to fix.
DDDAAAMMMNNNNN!!!! Thats a lot of pink and not the good kind. I knew this was going to happen, kinda planned it. In all the pics it "looks" even to the naked eye and the camera. But when you straight edge from one side to the other with bondo (red) large dips and hidden groves get filled in.
MECP 1ST CLASS
SquillyB is offline
Old 04-28-2008, 01:50 PM   #130
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
What was that white cream you used earlier to mix with the bondo? Also, and sorry for the newb type question, what does it mean to mix it too hot?
Mr.Bergner is offline
Similar Threads
Need help with a duratec build archie DURATEC Performance (2003-2007) 13 07-14-2006 04:40 PM
