Clunking rear shock mounts: Solved? - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-19-2008, 01:13 AM   #41
loudfocus01
loudfocus01's Avatar
Fan#: 26006
What I Drive: 2001 White LX 2002 Infra-Red Svt
FF Reputation: 107 loudfocus01 Excellent Standing Member loudfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (17)
I'm watching this thread closely, cause mine are clunking and its annoying as hell.
I may have tightened the nut down to much last time I messed with them, but it
seems really hard to figure out how much to tighten them down. Cant exactly get
a torque wrench on the nut and hold the shaft in place at the same time, so its
hard to just gauge how much to tighten it.
O'Reilly Auto Parts
Store Manager
Oak Grove, MO
loudfocus01 is offline
Old 10-19-2008, 02:53 AM   #42
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
You have an early Focus. Can you not just do as WD40 did? That really is a good solution. I would use it if possible, but the shocks on my 07, the thread is to short.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 10-19-2008, 03:01 AM   #43
loudfocus01
Fan#: 26006
His Koni shocks must be different than my eibach ones. Mine didn't come with washers....
But, I may look into doing what he did. Looks like an easy enough solution.
O'Reilly Auto Parts
Store Manager
Oak Grove, MO
Old 10-28-2009, 12:12 AM   #44
malim
malim's Avatar
Fan#: 55004
What I Drive: 2007 Ford Focus ST - Black
Points 981, Level 16
Points: 981, Level: 16 Points: 981, Level: 16 Points: 981, Level: 16
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
FF Reputation: 4 malim Good Standing Member
Hmmm, i am just wondering. The bushing that's on the top(seen in the trunk) should it be moving when pressing down on the suspesion or should it be tight but not too tight so there is no movement ?
I have a feeling that by not allowing it to move, makes the suspension stiffer, but having it move is wrong as well.
Chime in on this one, please :)
malim is offline
Old 10-28-2009, 08:58 AM   #45
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
If it moves, the nut is too loose. It should be tight, but it should not deform the bushing underneath it.
Honestly I don't know why it was designed this way. It would make more sense if a solid rubber bushing was used, unless I'm missing something.
CaysE is offline
Old 10-28-2009, 04:40 PM   #46
malim
malim's Avatar
Fan#: 55004
Originally Posted by Geezer View Post
Any shock that has a shaft that uses a single nut and bushings above and below the upper shock mount should never be fully tightened. That fully compresses the two rubber bushings which can cause noise and doesn't let them do their job correctly. The top shock mounting shaft has to be able to move and not be bound up. Most install directions that come with shocks clearly indicate how much the top bushings are to be compressed. Most of the time there's even a graphic. In most cases you're suppose to "slightly" compress the bushings and then stop tightening.
That sentensed confused me that's why i asked.Geezer is saying that it has to move.
malim is offline
Old 10-28-2009, 05:08 PM   #47
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
The shaft of the shock itself has to be able to move in the bushing. The stock bushing has an air pocket inside it... if you overtighten the nut, there's basically no bushing and the shaft can't move, making it prone to bending or breakage. You don't want the bushing itself to move around.
CaysE is offline
Old 10-28-2009, 05:32 PM   #48
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
The rule of thumb is to compress the bushings (stock rubber ones) so that they are no bigger in diameter than the above and below washers (stick out much beyond the diameter of the washer). For a urethane bushing this would be way too tight as they don't compress much unlike rubber. For urethane I'd just go hand snug (slight compression) on the upper nut unless the bushing installation instructions say otherwise. In either case, the goal is to not bind up the bushings.
Geezer is offline
Old 04-12-2010, 08:26 PM   #49
oddballmazda
Fan#: 74369
What I Drive: 2002 grey se sedan.
FF Reputation: 1 oddballmazda Good Standing Member
Can the clunking issue be solved the same way in a 2002 se sedan?
oddballmazda is offline
Old 05-22-2010, 12:48 PM   #50
Alex2507
Alex2507's Avatar
Fan#: 74979
What I Drive: 2000 Silver Focus SE Zetec
FF Reputation: 1 Alex2507 Good Standing Member
Let's hope so.
I'm going out to buy shocks now and armed with the 13 foot pound number I plan to make my 2000 SE ride like a Bentley.
This is like 30 days in County.
Alex2507 is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
LPE Rear Shock Mount Shims focusonthis420 Wheels & Tires 6 04-26-2008 03:38 PM
Clunking noise from rear of Stock SVT SVTF4243 Wheels & Tires 9 12-13-2007 11:56 PM
Idea to spruce up a stock rear bumper...cheap idea...need opinions J-Dawg MK1 Focus 33 01-11-2005 01:22 PM
rear shock mounts jeremy Wheels & Tires 2 02-04-2004 03:33 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
