Clunking rear shock mounts: Solved? - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-15-2008, 10:17 PM   #31
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
I measured and there is only ~5/8" of thread on the rear shocks WD40. So the bushings won't work. I am going to cut some foam fillers for the stock shock mounts, or make some new ones from scratch. The rubber ones I made are working 'ok' though (Not great, just good, or adequate). Will post if I get a good solution.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 10-17-2008, 05:48 PM   #32
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^What is so different on the 07 rear shocks?
Do you have any pics?
5/8" of thread and that's it? Weird.
I can't believe they'd expend that much effort to re-design the rear shocks when they were more or less fine the way they were.
WD40 is offline
Old 10-17-2008, 05:53 PM   #33
HawkeyeFLA
Fan#: 6078
What I Drive: 2002 Ford Focus ZX3 Pitch Black
FF Reputation: 5 HawkeyeFLA Good Standing Member
Originally Posted by Egz View Post
P-51 on fj used to make shims that you can put inside the rubber piece below the washer. No clunking, and solid action.
On a side note, anyone know if its still possible to get these? Or if anyone else makes something similar?
HawkeyeFLA is offline
Old 10-17-2008, 05:58 PM   #34
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,228, Level 41
Points: 4,228, Level: 41 Points: 4,228, Level: 41 Points: 4,228, Level: 41
Level Up 39% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Could try contacting P-51 to see if he has some around. That's how I got mine. He was done making them at the time but a couple sets laying around.
I now drive a Japanese Ford.
macdiesel is offline
Old 10-17-2008, 06:00 PM   #35
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
I wouldn't get them unless you plan on drag racing... otherwise they're just more noise for no reason.
CaysE is offline
Old 10-17-2008, 06:24 PM   #36
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
Here is a pic of the top of the rear shocks. You can just see the stop.
Also, a pic of the 'doughnuts' I made from a heavy rubber foam. These add considerable resistance to the stock rubber mount (also pictured, doughnuts fit inside). Hope to get them in this weekend. Note: These are not solid like the ones from P-51.
Name:	Top rear shock.JPG
Name:	Rear shocl rubber mounts.JPG
Old 10-17-2008, 07:03 PM   #37
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Ah ha...that's not much different (if at all) from what the earlier models have.
None of those parts you have shown are used anymore on my car.
That's where the extra room is going to come in to be able to use the other type of bushings.
I'll try and see if I can get a pic sometime this weekend...
WD40 is offline
Old 10-17-2008, 07:15 PM   #38
WD40
The Librarian
WD40's Avatar
Fan#: 5157
OK...So you can't wait till I take a pic...
This will have to do for now.
Enjoy!
Note.
My Koni shocks have a welded shoulder.
I don't remember what the stockers have, but there should be a shoulder
to keep the washer from sliding down the shock shaft.
I've had this setup on since my original post in this thread, and it's working great, and quiet/clunk free as can be.
WD40 is offline
Old 10-17-2008, 08:06 PM   #39
BeeFzX3
BeeFzX3's Avatar
Fan#: 46655
What I Drive: 2013 Focus ST
Points 5,963, Level 50
Points: 5,963, Level: 50 Points: 5,963, Level: 50 Points: 5,963, Level: 50
Level Up 7% Completed
FF Reputation: 40 BeeFzX3 Great Standing Member
Buy-Sell-Trade Rating: (8)
I think the problem is that those plastic things hit sides of the hole. I used WD40's idea. I got my old rubber rear sway endlinks bushings and cut them so they fit inside the black boot and go in and around those plastic tabs. P-51 shims do make strange noise it's like cracking plastic. I need to try removing them. So far no other noises, except P-51 shims.
BeeFzX3 is offline
Old 10-17-2008, 08:52 PM   #40
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
WD40 >> Ref your pic. The "Shoulder or Welded area" . That is where the threads start on my shock and are only 5/8" long. You can see the shoulder on my pic. But! My shoulder also extends up into the "car body shock mounting hole". The plastic clips extend upward beyond the hole. So the differences may look minor, but they prevent the use of the bushings as you describe them. Nice pic btw! :)
BeeFzX3 >> Can you draw a pic on how you did it? I think I get the idea, but a graphic would be nice.
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
LPE Rear Shock Mount Shims focusonthis420 Wheels & Tires 6 04-26-2008 03:38 PM
Clunking noise from rear of Stock SVT SVTF4243 Wheels & Tires 9 12-13-2007 11:56 PM
Idea to spruce up a stock rear bumper...cheap idea...need opinions J-Dawg MK1 Focus 33 01-11-2005 01:22 PM
rear shock mounts jeremy Wheels & Tires 2 02-04-2004 03:33 PM
