Go Back   Focus Fanatics > Model Specific Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 06-03-2004, 01:34 AM   #1
ZTS_Import_Eater
ZTS_Import_Eater's Avatar
Fan#: 560
What I Drive: '02 White ZTS
FF Reputation: 1 ZTS_Import_Eater Good Standing Member
Quick Questions (amp install)
ok now i have just finished reading (for about 2 hours) other posts on this site about installing subs and amps. and i only have 3 questions.
1) i've read that alot of ppl have gotten their LOC from www.davidnavone.com but i got mine from BestBuy... and it looks different from the ones in this forum. Mine has on one side, 2 small screws for adjusting, and the other side had the 2 RCA ports.. but mine are molded into the plastic, and finally the biggest differance is that mine has 6 wires coming out... (gray, gray/black, white, white/black, and 2 browns) reading the box the 2 browns are grounds... are these nessicary??
2) ive seen some wireing quides for the MP3 HU but i have the 6 Disc im just curious what are the colors for the Rear Left +/- and Rear Right +/- wires are... and also what color the ground wire is ( i haven't looked at my harness yet so there might be a black wire for ground but ill ask now just to save time).
3) now for the remote wire... during my reading i found that there was 2 suggestions for this wire... green/yellow or yellow/black... what wire is the best for the remote wire?
ZTS_Import_Eater is offline
Fan#: 1
Old 06-03-2004, 09:41 AM   #2
racer35
racer35's Avatar
Fan#: 1395
What I Drive: 93 jeep YJ and (lifted) 2004 blazer
FF Reputation: 1 racer35 Good Standing Member
for your wiring question go to the newbie section under YOUR DECK, the focus has two decks make sure you have the right wire diagram. Second two grounds are need for the LOC, but just connect both the your deck or make your own. The adjusting screws are for whines. If you have a whine or hear engine noise in your speekers adjust them depending on front or rear.
Dream as if you will live forever,
Live as if you will die today.
James Dean
racer35 is offline
Old 06-03-2004, 01:58 PM   #3
sa_pyro_ne
sa_pyro_ne's Avatar
Fan#: 1437
What I Drive: 2000 Ranger V6 4.0L 4x4 XLT Ext Cab
FF Reputation: 4 sa_pyro_ne Good Standing Member
the grounds should only be used if you are getting noise in your system, otherwise, don't connect them.
- Scott
sa_pyro_ne is offline
Old 06-03-2004, 02:51 PM   #4
racer35
racer35's Avatar
Fan#: 1395
Really??
Why not be safer than sorry. It doesn't hurt it.
James Dean
racer35 is offline
Old 06-04-2004, 12:32 AM   #5
DidHeFocus?
Fan#: 1704
What I Drive: 2003.5 ZTW PZEV
FF Reputation: 1 DidHeFocus? Good Standing Member
The speaker wire colors should be the same for all of the Ford head units.
Aren't the adjuster screws in the LOC basically gain or sensitivity controls to match the output of the HU to the input of the amp?
I'm a middle aged guy, with a middle school mind.
DidHeFocus? is offline
Old 06-04-2004, 12:41 AM   #6
sa_pyro_ne
sa_pyro_ne's Avatar
Fan#: 1437
nice catch didhefocus, i missed that part in the post. they are to match the hu, yes. not for whines. An older american international LOC that i had said not to connect the ground wire unless you were expirencing noise issues. so i take there word for it.
- Scott
Old 06-04-2004, 10:23 AM   #7
racer35
racer35's Avatar
Fan#: 1395
oh woops your right sorry! you guys probubly think I am a dumb a$$
James Dean
racer35 is offline
Similar Threads
Amp install help on 2008 ses focus Casper666 Car Audio, SYNC, MyFord Touch & Electronics 29 07-10-2008 06:34 PM
Sub and Amp Install HELP PLZ! laso2687 Car Audio, SYNC, MyFord Touch & Electronics 1 03-09-2008 08:24 AM
Tri-Ax/F install questions 05STRedLeader MK1 Interior Mods & Upgrades 7 02-01-2008 10:07 PM
Few questions on HFC install atxFocusSVT SVT Performance (2002-2004) 4 01-23-2008 08:30 AM
Suspension install questions... ZXTHR33 Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 12 12-15-2007 08:23 PM
