Go Back   Focus Fanatics > Ford Focus Tech Discussions > DURATEC Performance (2003-2011)
DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
Old 04-15-2008, 05:09 PM   #1
honhon
Fan#: 24778
What I Drive: a better car than a focus.
FF Reputation: 219 honhon Excellent Standing Memberhonhon Excellent Standing Memberhonhon Excellent Standing Member
Buy-Sell-Trade Rating: (21)
*~2008 Ford Focus Intake Thread~*
Well, with the growing number of Duratec performance members, owning and bringing in the 08 for Performance Mods, usually everyone typically starts with an Intake.
As of Right now, there are very limited options, and I will go through them below:
_____________________________________________
---K&N Replacement Filter---
Often these Go also by Drop-In filters, as they require NO modification to be installed.
2008 has an advantage over the earlier Model duratecs, as the earlier models have a 100k non-serviceable filter from the factory.
Wheres in 2008, they have a serviceable filter, which allows it to be replaced by a "drop-in" filter
K&N’s replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. We make over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are washable and reusable and are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. With most vehicles you simply remove the disposable air filter and replace it with a K&N. See applicable instruction sheet for details. Our stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED.
33-2401 Product Specifications
Product Style: Unique Air Filters
Filter Re-Oiling Amount: 0.76 oz (23 ml)
Height: 1 in (25 mm)
Outside Length: 8.5 in (216 mm)
Outside Width: 7.813 in (198 mm)
Weight: 1 lb (0.4 kg)
Product Box Length: 11.69 in (297 mm)
Product Box Width: 10.38 in (264 mm)
Product Box Height: 1.88 in (48 mm)
33-2401 Price: $42.19, and usually typically net around 3 to 4hp.
---K&N 69 Series Typhoon Kit---
Built for performance and show, the Typhoon™ Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles. Typhoon intakes come in one of three designs; cold air intakes (CA), short ram intakes (SR), or complete cold air (CCA) intakes which can be configured as either a cold air intake or a short ram intake. Some Typhoon's have high quality finish options including polished aluminum (part ends with TP), powder coated blue (part ends in TB), powder coated red (part ends in TR), and powder coated silver (ends in TS) among others. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction allowing more air flow to your engine. More air means more usable power and acceleration throughout the engine's RPM range.
69-3513TTK Product Specifications
Product Style: 69 Series Typhoon Kits
Estimated Horsepower Gain: 5.24 HP @ 5400 RPM
Color: Textured Black
Replacement Filter: RU-4950
CARB Exempt: No
System Type: Short-ram intake system
Weight: 7.2 lb (3.3 kg)
Product Box Length: 19.3 in (490 mm)
Product Box Width: 14.5 in (368 mm)
Product Box Height: 8.4 in (213 mm
69-3513TTK Price: $321.04 - 5.24hp
---Steeda Short Ram Intake---
Steeda calls it a Cold Air Intake on their website, but infact, it really is a short ram intake.
Steeda's new high flow air intake for the 2008 2.0L Ford Focus is 2 intakes in one all inclusive kit!
Our high flow cold air intake includes an insert allowing you to use it as a direct bolt on intake kit with no tuning required, or remove the insert to for even more airflow and combine it with a custom tune for the most powerful kit on the market for your Focus.
Steeda's cold air intake kit is also designed to use your stock air induction system, helping to take in cooler outside air!
Steeda's high flow intake also features a stainless steel heat shield and high flow cone style air filter for great airflow. Low intake air inlet temperatures can be accomplished with the heat shield and a provision to re-use your factory Ram air. Improved gas mileage will also be noticed!
We got an easy 7hp and 12ft/lbs of torque in mid range RPM's with peaks around 6hp and 5ft/lbs with the insert in place. More to be had with no insert and custom tuning.
$239.95
To read Specifics and information directly related to the filters these 2 use, please check out
http://www.knfilters.com
or for the Steeda
http://www.sbfilters.com
http://www.full-race.com/r14-fire-video.html
honhon is offline
Fan#: 1
Old 04-15-2008, 05:37 PM   #2
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '07 ST and '86 XR4Ti
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (11)
honhon is the man. lol. You should sticky this one.
'07 ST ; formally bewst'd
'86 XR4Ti ; 2.3L Turbo, 15psi
D23 Crew: #07
Jgrove998 is offline
Old 04-15-2008, 05:43 PM   #3
honhon
Fan#: 24778
i dont have that power anymore.
but im sure one of the nice modly friends will stickie it.
honhon is offline
Old 04-15-2008, 10:13 PM   #4
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
FF Reputation: 352 NemesisEnforcer Outstanding Standing MemberNemesisEnforcer Outstanding Standing MemberNemesisEnforcer Outstanding Standing MemberNemesisEnforcer Outstanding Standing Member
good stuff, tho i dont have an 08, but threads like this are why the rep system exists, lol...
sorry honhon, it wont let me give you any more rep right now!!
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 04-16-2008, 08:35 AM   #5
richdeerht
Fan#: 55194
What I Drive: 2008 Vapor Silver SE Sedan
FF Reputation: 1 richdeerht Good Standing Member
I have a '08, and was considering the Steeda or the Typhoon. Any other pros/cons on these two? I want a SRI, not necessarily a CAI. I can't trust myself to stay out of puddles!
richdeerht is offline
Old 04-16-2008, 09:00 AM   #6
focusdarko
focusdarko's Avatar
Fan#: 29836
What I Drive: 2008 MS3
FF Reputation: 8 focusdarko Good Standing Member
Buy-Sell-Trade Rating: (10)
You cant go wrong with either intake. K&N is great and i use a drop in for my SVT now. But i have used a Steeda SRI for my SVT and my zetec in the past. i never had a problem and they sounded sweet. By what honhon wrote the steeda sri seems to be the best deal for the price and nets you the most hp/tq.
Out of the Focus world for now, and onto the Jeep World.
Enjoy your new SVT Warneej
focusdarko is offline
Old 04-16-2008, 09:19 AM   #7
Arkaign
Arkaign's Avatar
Fan#: 53519
What I Drive: 2008 Red Focus Coupe 5Spd
FF Reputation: 3 Arkaign Good Standing Member
Thanks for this HonHon! Fantastic Info, and this will be great to have in one place for the growing number of '08+ newcomers.
Arkaign is offline
Old 04-16-2008, 11:41 AM   #8
honhon
Fan#: 24778
the information listed is directly off of the mfg. websites.
honhon is offline
Old 04-29-2008, 01:53 PM   #9
richdeerht
Fan#: 55194
When you check the K&N website, the drop-in 33-2401 filter is listed as non-PZEV only.
Old 04-29-2008, 05:32 PM   #10
honhon
Fan#: 24778
i honestly dont see the air box itself being different... that would probably cost way too much to have 2 different intakes for the same car.
if the 08 is the same as the previous years... the only difference in the intake is a large 1inch diameter tube that hooks into the intake tube right before the throttle body.
honhon is offline
Similar Threads
Zero to 60 & 1/4 Miles Times (List of all cars) OrangeSVTguy Drag Racing 35 10-06-2009 02:36 AM
Even this fOCUS!!!! Jeezzzz!!!! TORQUERULES Ford Focus & General Car Chat 22 02-11-2007 10:47 PM
2008 Ford Focus US-Spec part 1 mitchlguzin Ford Focus & General Car Chat 9 01-08-2007 05:57 PM
Aussie Fords Coming? igor Ford Focus & General Car Chat 27 06-06-2006 11:32 AM
2005 Economy Sedan Comparison Test Kneel Ford Focus & General Car Chat 4 08-24-2005 10:02 AM
