HOW TO: Install Cosworth Balance Shaft Delete Kit with Pictures - Page 7 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > DURATEC Performance (2003-2011)
DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
Old 05-10-2009, 11:47 AM   #61
SPYDERTUNE
Fan#: 29724
What I Drive: Currently, MK3 VW Jetta
FF Reputation: 1 SPYDERTUNE Good Standing Member
Originally Posted by jetrinka View Post
The bore is the same between the two at 87.5mm. The stroke however on the 2.0 is 83.1mm and on the 2.3 is 94mm.
Danke'
SPYDERTUNE is offline
Old 05-15-2009, 11:04 AM   #62
thefrohn1
thefrohn1's Avatar
Fan#: 20888
What I Drive: 03 ZX3 2.3 5spd
FF Reputation: 2 thefrohn1 Good Standing Member
Buy-Sell-Trade Rating: (4)
got my cosworth kit today, two questions, should I put loctite on the little bolt that holds the oil plug to the plate? and the 4 bolts that you remove from the balance shaft.. do those get put back in the holes after the bs is gone or just leave em out?
2003 Pitchblack ZX3 2.3
hey... i'm not ur BRO!
thefrohn1 is offline
Old 05-15-2009, 03:04 PM   #63
thefrohn1
thefrohn1's Avatar
Fan#: 20888
also is there a torque sequence when putting back on the oil pan?
Old 05-15-2009, 04:55 PM   #64
Svtzx555
Fan#: 27739
What I Drive: '06 silver ST
FF Reputation: 11 Svtzx555 Great Standing Member
I'm sure there is a torque order, but just use common sense when tightening them up. Snug one bolt on one side of the pan, then snug one on the opposite side. Then tighten them all up.
Leave the 4 bolts out that held in the BS. I didn't use locktite. I used a lockwasher.
My ST holds 5.5 as well now, not the 6 that the instructions say.
Gumpcrew#7
Originally Posted by the_07ninja View Post
Svtzx555-3 to Sn4ckm4st3r-1
Originally Posted by TnFocus View Post
Yea, I'll go .080 over on his face.
Svtzx555 is offline
Old 05-15-2009, 05:02 PM   #65
thefrohn1
thefrohn1's Avatar
Fan#: 20888
thanks for the info
Old 05-19-2009, 12:22 PM   #66
thefrohn1
thefrohn1's Avatar
Fan#: 20888
sooo... i started this a few days ago.. it was going well until the head of one of the last oil pan bolts i was removing snapped off, turns out it was put in crooked.. so now i've gotta drill that out and re-tap the hole, also when i dropped the pan i found the oil pickup tube to be broken at the end.. yay, gotta order one of those now. The balance shaft is out though and the cossie kit is in. Just gotta sort out this other crap.
I'd say this oil pan has been off before...
Old 05-22-2009, 05:39 PM   #67
pssdfocus
pssdfocus's Avatar
Fan#: 49794
What I Drive: 06 liq g st
FF Reputation: 3 pssdfocus Good Standing Member
where are you located in Mi? just finished mine. f2 bsd
ST CREW #102 TD #209 SR #19 asa, eibach, f2, fswerks, steeda, 2.3 dohc (destroyer of hideous civics)
pssdfocus is offline
Old 05-22-2009, 09:25 PM   #68
thefrohn1
thefrohn1's Avatar
Fan#: 20888
i'm in Riverview, and i just got everything straightened out today, drilled out the old bolt, re-tapped the hole and replaced the pickup tube, it's all back together and on the road. A lil more responsive, i like it :) haha
Old 03-03-2010, 12:36 AM   #69
kgb05
kgb05's Avatar
Fan#: 62912
What I Drive: 05 Red ST
FF Reputation: 1 kgb05 Good Standing Member
did I miss those new track times after the mod?
kgb05 is offline
Old 03-03-2010, 05:32 AM   #70
ChazimusZX4ST
Fords suck
ChazimusZX4ST's Avatar
Fan#: 30557
What I Drive: 2005 Graffiti ZX4 ST
FF Reputation: 19 ChazimusZX4ST Great Standing Member
Buy-Sell-Trade Rating: (7)
Nope, Tony no longer drives a Focus. Don't think he ran after he installed.
2005 ZX4 ST Graffiti Edition
1990 VW Corrado G60
2000 Crown Vic Interceptor
ChazimusZX4ST is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-26-2009 11:05 PM
Balance shaft delete questions Blackcatn2o DURATEC Performance (2003-2011) 59 04-16-2008 12:24 PM
Balance Shaft Delete? Coach DURATEC Performance (2003-2011) 16 05-31-2007 10:12 PM
when buying your own balance shaft delete kit... FocusFactorDave DURATEC Performance (2003-2011) 10 04-02-2007 10:21 PM
install kit dave30 Car Audio, SYNC, MyFord Touch & Electronics 12 11-04-2003 09:35 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
