HOW TO: Install Cosworth Balance Shaft Delete Kit with Pictures - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-14-2008, 04:57 PM   #1
PitchBlackST
PitchBlackST's Avatar
Fan#: 41335
What I Drive: 2004 F-150 SuperCab XLT 4x4
FF Reputation: 30 PitchBlackST Great Standing Member
HOW TO INSTALL YOUR BALANCE SHAFT DELETE KIT ON YOUR 2.3L DURATEC.
Supplies needed:
Cosworth B/S Kit
Bottle of red locktight
Bottle of black RTV
Metric socket set (3/8 drive will do)
1. Drain oil and put plug back in oil pan.
2. Remove the oil pan and set it aside so that nothing besides air can get in it. (8mm, 10mm, 13mm socket used)
3. Remove the bolt circled in RED and swing the oil pickup tube out of the way. (see picture below)
4. Remove the 4 bolts circled in RED holding the Balance Shaft in and get ready to grab it. It had alittle weight to it. (see picture below)
5. Put some red thread locker on the Socket Head Cap Screw that comes with the Cosworth B/S kit. Make sure the O-Ring is still on the plug side. (see picture below)
6. Insert the plate and Socket Head Cap Screw into the block and tighten down to 18 ft/lbs. (see picture below.
7. Put oil pickup tube back in place and tighten bolt to 8-10 ft/lbs
8. Clean off both block and oil pan surfaces where the 2 meet together. (razor blade and brake cleaner works great)
9. Put a 1/16 to 1/4 beed of Black RTV around the oil pan (there is a spot on the side of the oil pan.)(follow the dotted lines FOMOCO gave you on the oilpan)
10. Put the oil pan back in place and hand tighten all the blots in place untill they just start to get tight. And leave it like that for about an hour to hour and a half for the RTV to tack up alittle. (as your waiting you can do your oil filter at this time or get on the internet and go to www.focusfanatics.com )
11. Tighten all the oil pan bolts. (10mm and 8mm bolts to 30 in/lbs not to tight, the the 4 13mm bolts are much tighter if you remember on the removel of the oil pan.
12. Fill the motor back up with your selected motor oil. ( will now take more than 4.5 qts)
13. Car is now 18lbs lighter. Please drive safe. Wear your seatbelt.
Focal Point
2011 F150 Screw FX4 EcoBoost
2013 Focus SE 201A
PitchBlackST is offline
Old 04-14-2008, 05:03 PM   #2
PitchBlackST
Fan#: 41335
Any questions please fill free to ask them here or PM.
There are some noticible vibrations. Nothing to big that i dont mind. I did also notice trottle response incressed alittle.
Track time stock is 15.7 best on 8 runs
Track time with exhaust and intake installed is 15.2 best on 6 runs
Track time with above and BS delete kit installed coming soon.
Focal Point
2013 Focus SE 201A
Old 04-14-2008, 05:12 PM   #3
jwh172
jwh172's Avatar
Fan#: 42415
What I Drive: LG ST
FF Reputation: 1 jwh172 Good Standing Member
good write up, and i'm pretty anxious to see the new times.
jwh172 is offline
Old 04-14-2008, 05:20 PM   #4
ChazimusZX4ST
Fords suck
ChazimusZX4ST's Avatar
Fan#: 30557
What I Drive: 2005 Graffiti ZX4 ST
FF Reputation: 19 ChazimusZX4ST Great Standing Member
Buy-Sell-Trade Rating: (7)
Tony, looks like the next available money I'm doing this, it was so easy.
2005 ZX4 ST Graffiti Edition
1990 VW Corrado G60
2000 Crown Vic Interceptor
ChazimusZX4ST is offline
Old 04-14-2008, 06:35 PM   #5
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
Points 86,025, Level 100
Points: 86,025, Level: 100 Points: 86,025, Level: 100 Points: 86,025, Level: 100
Level Up 0% Completed
FF Reputation: 60 Tom Excellent Standing Member
Very nice write-up, gave you some rep points.
Tom is offline
Old 04-14-2008, 06:41 PM   #6
PitchBlackST
Fan#: 41335
thanx alot tome for the rep points ... i thought thats not a vary popular mod that people get sence you have to go inside the motor. i thought a how to would get more people to think about it.
Focal Point
2013 Focus SE 201A
Old 04-14-2008, 06:52 PM   #7
Bambooburnr
Bambooburnr's Avatar
Fan#: 48682
What I Drive: 2007 Black SeS
FF Reputation: 4 Bambooburnr Good Standing Member
Wow thats an easy Mod and your write up is so easy to follow!
Wonder if They mae something similar for the 2.0D
Cossie CAI, FS Stealth Exhaust, Upper Front and Rear Stress Bar (FS). Tune by FocusSport
Bambooburnr is offline
Old 04-14-2008, 07:15 PM   #8
kenzx3
Say NO to FRPP Drops
Fan#: 42651
What I Drive: '00 ZX3, '03 ZX3, '07 ZX3
FF Reputation: 125 kenzx3 Excellent Standing Member kenzx3 Excellent Standing Member
Buy-Sell-Trade Rating: (49)
I don't think we have the BS in the 2.0 if I am correct?
kenzx3 is offline
Old 04-14-2008, 09:28 PM   #9
PitchBlackST
Fan#: 41335
yes your right. the 2.0 don't come with the balance shaft. lucky
Focal Point
2013 Focus SE 201A
Old 04-19-2008, 08:37 PM   #10
silvercarbonfocus
Fan#: 55323
What I Drive: 2005 laser blue zx3
FF Reputation: 0 silvercarbonfocus Newbie
Buy-Sell-Trade Rating: (-1)
will it work on the 2.0?
silvercarbonfocus is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Balance shaft delete questions Blackcatn2o DURATEC Performance (2003-2007) 59 04-16-2008 01:24 PM
Balance Shaft Delete? Coach DURATEC Performance (2003-2007) 16 05-31-2007 11:12 PM
when buying your own balance shaft delete kit... FocusFactorDave DURATEC Performance (2003-2007) 10 04-02-2007 11:21 PM
install kit dave30 Car Audio, SYNC, MyFord Touch & Electronics 12 11-04-2003 10:35 PM
