Power window problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-14-2008, 10:51 AM   #1
shane_c
Fan#: 53658
What I Drive: 2004 Light Tundra SE Wagon (SPI)
FF Reputation: 1 shane_c Good Standing Member
I installed my new OEM upgrade speakers yesterday and when I tried to put the rear, drivers side window down it wouldn't work. I tried both the main switch and the switch on the back door and neither would make it go down. I took the panel off the driver door again and checked to make sure no wires came loose it all looked okay. If something was disconnect in the drivers door would that prevent the switch on the door in question from working? I don't know for sure if the window would go down prior to me doing the speakers because it hasn't warmed up until now so I had no need to put it down. FWIW the other 3 windows work fine.
shane_c is offline
Old 04-20-2008, 07:42 AM   #2
shane_c
Fan#: 53658
anyone?
shane_c is offline
Old 04-20-2008, 07:50 AM   #3
greenZX10
Fan#: 50113
What I Drive: 2001 bright blue ZX3
FF Reputation: 5 greenZX10 Good Standing Member
I had a Focus I was selling. Guy came to look at it and I assured him everything on the car worked, because it did.....until he got there to look at it. He was trying out all the power windows when BAM!!!! The left rear one was half way up and just quit.....it stopped.....the motor went bad in an instant like that.
You need to somehow check voltage to the motor when you press the switch, or, just turn your key on, hit the switch, and watch your dome light....if it dims slightly or kinda flickers when you press the window switch, that means power is flowing but the window motor won't run, and you have your diagnosis. It's a hillbilly way to diagnose, but it works.
If you were in there doing speakers though, it could be something you missed if it worked before.
greenZX10 is offline
Old 04-20-2008, 07:50 AM   #4
focus_SWT
focus_SWT's Avatar
Fan#: 51264
What I Drive: 2000 FFV wagon
FF Reputation: 3 focus_SWT Good Standing Member
I would just check for power at the switch. Mine stopped working also. Then I kept trying and the dang window assembly broke. Stupid plastic crap.
focus_SWT is offline
Old 10-01-2008, 10:32 AM   #5
shane_c
Fan#: 53658
Strange thing happened today. After not working for the last 5 months I hit the button today and the window worked again. Weird.
2.0L SPI, automatic
shane_c is offline
Similar Threads
Power Window Swap? Wes_03_ZX3 General Technical Chat 6 07-29-2014 11:53 PM
power window problems fokuzsport General Technical Chat 2 07-01-2012 12:17 PM
power window problem Tlw1919 General Technical Chat 1 12-13-2007 02:39 PM
My RR power window is bad~ 2000FordFocus General Technical Chat 4 10-28-2007 10:56 PM
Engine Power Loss Problem? RB SVT Performance (2002-2004) 10 05-12-2005 12:55 PM
