Lower motor mount poly insert how to - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-14-2008, 01:12 AM   #1
svtautox
Fan#: 43485
FF Reputation: 10 svtautox Great Standing Member
So I decided to be cheap and buy an insert instead of the 100 dollar one from cfm. And heres how you can be cheap just like me.
(Don't mind the o2 cheater next to it)
Tools needed-
13mm socket
Ratchet
Breaker bar
PB blaster-(Trust me you will need it)
Vice
Good hammer
Floor jack-(You will need it to move the motor)
1. Get that svt
2. Jack it up and put in on jack stands
3.You are gonna want to spray some PB Blaster on those bolts, mine were really tight and I slipped a little on the rear one so be careful.
Heres what your looking for
4. After it sits for a bit just pull those bolts out, I did the front one first.
Front
Rear
5. After I got the bolts out I pushed on the bottom of the motor toward the front of the car, and twisted the mount to the right to clear the bracket.
6. When you get that mount out clamp it down tight in a vice.
7. Now grab a hammer, you may want to use a ball-pin, don't make fun of my hammer I couldn't find my other one. So pretty much I just used some forceful blows right in the middle of the mount and it knocked right out. The front one was easy compared to the rear one.
8. After you get those out grab your new inserts and take the metal sleeve out of them. The front one is and oval shape so it was kind of hard to get in, I just used some PB Blaster and lubricated the insert. You just have to work it in, I put the broad side if the oval in first and worked it around.
9. I heard that some people have had problems with these slipping out so I grabbed some silicone glue and went all around the insert and then pushed it in all the way.
10.I did the same thing for the rear, but this one I used a screwdriver to help get it into the mount. In the picture you can see all I had to do was push the screwdriver to the left and it went in.
11. Don't forget to put those back sleeves in.
12. Now comes the hard part your going to want to put the mount back in and put the front bolt back in first and start it. Then your going to want to jack up on the motor, don't put too much pressure on it, and get the rear bolt started. You are probably going to have to tap the mount with a hammer and use the jack to adjust the motor to help get the holes lined up. Theres no exact way to tell, your just going to have to play with it. It took me a few tries to figure all this out, so trust me.
13. Now all you have to do is tighten those bolts up and you may want to torque them, but I didn't because I didn't know how much they needed.
You're finished!
Heres the two mounts compared
It took me about an hour to do including figuring out how to get it bolted back up which took about 15-20 minutes, so it should only take you about 45 minutes.
Review: It made the car so much smoother. When you let off the gas the car feels so much better than before. I say its a good 18 bucks to spend.
If you have any questions feel free to ask.
svtautox is offline
Old 04-14-2008, 01:35 AM   #2
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Wow, that's a great write up. Very informative. I thought about doing this so now I may have to.
Thanks +rep
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 04-14-2008, 01:47 AM   #3
j-zetec_pr
MACHINERY TECHNIAN
j-zetec_pr's Avatar
Fan#: 47101
What I Drive: 2000 Silver ZX3 Kona, MTX-75, Zetec
FF Reputation: 27 j-zetec_pr Great Standing Member
Buy-Sell-Trade Rating: (9)
i just bought these. Mike (Hilbish) convinced me they are as good as spending over $100 on a mount, so i should get them soon and get them on. nice write-up
off-topic--
where'd you get the o2 cheater? i need one and i can't find one
Carpe diem quam minimum credula postero
ODOMETER: 169,000 miles
j-zetec_pr is offline
Old 04-14-2008, 02:17 AM   #4
xryan85X
Fan#: 52189
What I Drive: 02 Sonic Blue SVT
FF Reputation: 19 xryan85X Great Standing Member
Nice, I've had mine sitting her for a while...I'll have to wait till it gets a tad warmer though. Nice write up.
xryan85X is offline
Old 04-14-2008, 12:48 PM   #5
besthaticouldo
i wear no pants
besthaticouldo's Avatar
Fan#: 26970
What I Drive: '11 OBP WRX Sedan
FF Reputation: 104 besthaticouldo Excellent Standing Member besthaticouldo Excellent Standing Member
Buy-Sell-Trade Rating: (23)
nice man. good write up
remember that building a car shouldn’t come from parts it should come from deep inside your soul. let the car speak for all the emotions, memories and experiences youve made and the car will take a life of its own. truth over fame.
besthaticouldo is offline
Old 04-14-2008, 01:12 PM   #6
svtautox
Fan#: 43485
Thanks fellas the o2 cheater came from cfm for 30, might as well order something else with it because shipping is 13ish.
svtautox is offline
Old 04-14-2008, 09:45 PM   #7
KRYPTO
KRYPTO's Avatar
Fan#: 45267
What I Drive: 02 race car red SVT
FF Reputation: 1 KRYPTO Good Standing Member
If you want to be cheaper go to Home Depot/ hardware store and get some Constrution adhesive (polyurithane) and fill in the mount.
FF welder
Barely Rolling Racing
KRYPTO is offline
Old 04-14-2008, 09:46 PM   #8
patalrob
Guest
Fan#: 51782
What I Drive: 07 Pitch Black ZX5, 02 Red SVTF
FF Reputation: 0 patalrob Newbie
Great write up!
patalrob is offline
Old 04-15-2008, 05:11 PM   #9
Wildosvt
Fan#: 54916
What I Drive: 2004, Sonic Blue, SVT ZX5
FF Reputation: 1 Wildosvt Good Standing Member
I cannot thank you enough for taking the time to do this!
You did a superb job with the write up!
Its my turn now to put these babies in!
Again, THANK YOU!
Wildo
2004 Sonic Blue ZX5 SVTF. with EAP's.Drop in K&N,so far.Tint, And Vent Shades.
2007 Red/White LeMans stripe Shleby GT500. C&L CAI, With Evo Tune.. And sequential tail lights for that period look. Followed up with FRPP GTA mufflers.
Wildosvt is offline
Old 04-15-2008, 10:30 PM   #10
christopher48197
christopher48197's Avatar
Fan#: 43786
What I Drive: 2002 CD Silver ZX5 mtx
FF Reputation: 12 christopher48197 Great Standing Member
Buy-Sell-Trade Rating: (6)
Great info. A while back I did some searching and there's not much on here about removing the stock bushings and putting in the inserts. A mechanic friend had told me that I would need a press to insert the urethane inserts and it would still be a pita. So I picked up a used mount to mess around with, just in case I couldn't get it.
I was pleasantly surprised at just how easy it was. The stock bushings popped out with 3 whacks each (sprayed a little TC-11 on them first). When I put in the urethane inserts I didn't even use any lube ( I heard that petroleum based lubricants will cause urethane to become brittle plus they had a light coating on them from the package). I just squeezed it in the vice with a piece of wood and kinda pressed them in. Piece of cake.
So now my mount is ready to go, I just need to get over to my dads garage so I can get under the car.
BTW, I like the pic with the mount in the vice and the hammer. That was a good inspiration.
christopher48197 is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
Lower Grill removal FocusVet MK1 Focus 7 02-08-2007 05:50 PM
W T B --- SVT Drivers LOWER SEAT SKIN >>black/red<< itbparada Archive 3 01-24-2007 10:51 AM
Euro grille - 2002 Upper / 1998 lower microtonal MK1 Focus 16 12-18-2003 05:03 PM
