front suspension sounds UGLY!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-01-2004, 04:20 PM   #1
dwdgsi03
dwdgsi03's Avatar
Fan#: 2298
What I Drive: 2000 Midship Runabout
FF Reputation: 1 dwdgsi03 Good Standing Member
i have no idea what this noise coming from my front suspension could be. i only hear it when i turn my steering wheel. it sounds like a whooshing noise and clicking. like it goes: whoosh whoosh whoosh click whoosh whoosh whoosh click. i know my top pillow mount its bad on my left side, but it sounds like my whole suspension is falling apart. btw: i installed my springs like 5 months ago, and i believe i didn't tighten something up all of the way. would bad shocks make noises?
(\_/) Copy this bunny to your sig because he`s better than the "other bunny"
(O.o)
dwdgsi03 is offline
Old 06-01-2004, 04:28 PM   #2
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Damn, I would check that out quick, sounds like something is up with the shocks and everything lining up. Bad shocks can make noise but that clicking isn't good, wonder if something is coming loose and rubbing or something??
Chad (S2)
S2 is offline
Old 06-02-2004, 10:14 AM   #3
Slam
Fan#: 8349
What I Drive: 2002 Burgundy SE
FF Reputation: 1 Slam Good Standing Member
I assume from your discription that the noise is cyclical. If the noise is cyclical and you can hear the noise when turn the wheel while stopped, the problem is with the power steering pump or the steering rack. If the noise is not cyclical, and you can hear it when turning the wheel while stopped, it is either 1) that the steering/suspension components are incurrig an obstacle, 2) a rubber bushing/damper is missing or damaged or 3) the ball joints or tie rod ends are sloppy. From your discription (I am assuming that it is a clyclical noise that you can hear only while the car is moving), the most likely candidate is a failing CV joint. If this is the case, depending on how far gone the CV joint is, you might hear a slight clicking while driving in a straight line, and an increasingly loud clicking as you turn tighter. Finally, you may have just ran over some road debris, and it is hung up under your car.
The quickest way to diagnose the car is to get it up on jack stands. Take a look around for the obvious problems. If nothing stands out as wrong, get someone to turn the wheel while you observe the movement from outside.
I hope this helps
Slam is offline
Old 06-02-2004, 10:32 AM   #4
dwdgsi03
dwdgsi03's Avatar
Fan#: 2298
thanks for the responses, i'll check those cv joints
(O.o)
dwdgsi03 is offline
Similar Threads
How how lowering your suspension affects suspension geometry tb1999 Brakes, Suspension & Body Chassis 24 07-28-2012 04:10 PM
Wierd Knocking Sounds - front suspension nikn General Technical Chat 45 11-18-2007 10:33 PM
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 12:55 PM
Ford Focus: Suspension & Brakes hotfocus Brakes, Suspension & Body Chassis 0 02-17-2005 04:40 AM
