Fog Light Mod for 2007 [Fogs on w/ High Beams] - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 04-09-2008, 08:51 PM   #1
goodnight2u2
goodnight2u2's Avatar
Fan#: 50510
What I Drive: 2007 Pitch Black ST
FF Reputation: 19 goodnight2u2 Great Standing Member
Please Read post #7 & #8 before proceeding on this modification! Due to information regarding wiring schematics, this mod could be dangerous. Any mods performed are at your own risk.
Objective:
This mod is intended to allow the fog lights to remain on when switching to high beams. It was performed on a 2007 model, but may work on 05 and 06 seeing as how they are all similar. There have not been any issues with this mod at this time, but if you experience one please post your issue. Tinker at your own risk.
Items Needed:
1. 12 Gauge Solid Wire
2. Wire Cutters/Strippers
3. 4 Spade Lug Crimp Terminals
4. Crimpers
Install Time:
10 Minutes
Directions:
Step 1
Locate the fuse/relay box inside the engine bay.
Figure 1
Step 2
Take note of the diagram on the top of the box, paying special attention to the location of RL-2 (relay 2).
Open the cover to the fuse box.
Figure 2
Step 3
Locate and remove relay 2 (RL-2).
It's in real snug so it helps to have something that can slide underneath the sides of the relay.
Figure 3
Step 4
Cut two 2" lengths of wire and strip both ends.
Crimp male terminals onto each end of both wires.
(Figure 4)
Left- the underside of relay 2 (notice it's terminals are numbered)
Center - after removing the relay, these correspond to the female terminals in the box where the wires will go
Right - relates to the center diagram (shows finished product, refer to step 5 for inserting wires)
Figure 4
Step 5
Connecting the wires (refer to diagram in figure 4):
>Wire 1 - insert terminals into slots 85 and 87
>Wire 2 - insert terminals into slots 87a and 30
Make sure they form snug fits and then try out the lights.
Figure 5
The End
Last edited by goodnight2u2; 06-25-2008 at 08:33 AM. Reason: Information from wiring schematics regarding hazards brought forward
goodnight2u2 is offline
    Quick reply to this message
Old 04-09-2008, 09:15 PM   #2
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
Points 86,025, Level 100
Points: 86,025, Level: 100 Points: 86,025, Level: 100 Points: 86,025, Level: 100
Level Up 0% Completed
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
Nice write-up going to give this a 30 day sticky for everyone to see.
Tom is offline
Old 04-14-2008, 09:40 AM   #3
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the HOW TO ARCHIVE...............
Chad (S2)
S2 is offline
Old 04-16-2008, 01:10 PM   #4
herman
Fan#: 53783
What I Drive: 2007 Red SES
Points 1,123, Level 18
Points: 1,123, Level: 18 Points: 1,123, Level: 18 Points: 1,123, Level: 18
Level Up 23% Completed
Forum Activity 2%
FF Reputation: 1 herman Good Standing Member
Fog lights that serve as DRL's
This post has the exact fuse relay box as mine and will work, but is their any way to mod it to where the foglights only come on when the key is on, with the marker lights off.
herman is offline
Old 04-24-2008, 12:20 PM   #5
Toby1685
Fan#: 55438
What I Drive: 2007 Black ZX4
FF Reputation: 1 Toby1685 Good Standing Member
Nice mod. I just did it. Thanks I've been trying to figure that one out.
Toby1685 is offline
Old 05-26-2008, 03:59 PM   #6
Waffles ZX3 Kona Sport
WAFFLEY!
Waffles ZX3 Kona Sport's Avatar
Fan#: 10426
What I Drive: 2006 Fusion SE Midnight Blue
FF Reputation: 11 Waffles ZX3 Kona Sport Great Standing Member
Buy-Sell-Trade Rating: (6)
I've been wanting to do this since I've had my 07! Thanks for posting this!!
Waffles ZX3 Kona Sport is offline
Old 06-25-2008, 01:16 AM   #7
ahmadr
Fan#: 37615
What I Drive: 2006 ZX5
FF Reputation: 2 ahmadr Good Standing Member
NOOOOO!! DON'T!!
I double checked the schematics, and this is plain dangerous.
Basically, what this mod is doing is REMOVING the high beam circuit relay, and powering the high beams (~20 Amps) through the wiring and switch designed to only power the relay and the dashboard indicator (<1 Amps). You WILL screw up the switch or wiring (or the whole car if they catch fire. The fogs are fine though.
You have been warned!
ahmadr is offline
Old 06-25-2008, 01:49 AM   #8
ahmadr
Fan#: 37615
OK, this is a better way:
1. Remove the relay
2. Cut the pin labeled 87a on the RELAY. Insert a wire with a spade terminal that sticks out the absolute minimum possible (you probably have to solder the wire to a modded spade to keep size down) into 87a. The part sticking out MUST be insulated well. Put the modified relay back in. It should fit snugly if the spade terminal in 3 is not sticking out more than 2-3 mm.
3. The other end of the wire MUST go to a fuse (20A) and the other side of the fuse should go to 12v (always on).
Note: I used the subwoofer fuse for my case, since I don't have the sub but have the fuse. In this case, make sure you are taking fused power AFTER the fuse. Don't do this if you are not absolutely sure what you are doing.
Instead of item 2 above, you could also do this (this is how I did it):
2. (Alternative method) Mod the relay so pin 87a is electrically disconnected (but physically present), and insert a (stranded type) wire (or 2 if using thinner wire) in 87a. Any part sticking out MUST be insulated well. Then put the relay back so the pin on the relay keeps the wire snugly in place
This will keep the foglight switch functional when high beams are on.
Note: this applies to 07 and most 06 models. 05 and early 06 models have a different schematic.
DISCLAIMER: Take this advice solely is at your own risk. This was only my opinion and is not a suggestion. Note to Ford/others: I only did this mod in my dreams. I never did/will do such a mod in real life.
ahmadr is offline
Old 06-25-2008, 08:24 AM   #9
goodnight2u2
Fan#: 50510
Thanks Ahmadr for looking into the schematics for this, I have not been able to find any. Can you tell me where you were able to find the wiring diagrams and schematics? I've been waiting on Haynes to come out with their manual for the 05-07 model years, but I'm not sure when that's going to happen.
Can you post pics for this mod? (even if they are from your dreams) ;-)
Old 06-26-2008, 10:55 AM   #10
ahmadr
Fan#: 37615
I'll try to take pictures sometime next week, when my new camera arrives. My old one recently hit the dust :(
For now, I've updated my post with another way you could do it (what I actually did)
As for schematics, you might be able to ask your dealer to look at it for a few minutes. I did that once. I also had my (now dead) camera with me on that day and took some beautiful pictures (not from the schematics, of course - it was a nice sunny day outside ;) )
You could also get a subscription for your car from alldatadiy.com (~$45 per car for 3 years). It includes tons of service manuals, schematics, and TSBs, and has helped me quite a bit.
ahmadr is offline
Closed Thread
Similar Threads
[:)][:)][:)][:)][:)][:)]FREE Fog Light Mod Wiring[:)][:)][:)][:)][:)][:)] JohnMichael Archive 29 07-17-2007 01:40 PM
fog light mod cause a draw?? blkeurosvt1986 Focus SVT 2 12-17-2006 08:33 PM
Independent fog light w/ high beams? svtfocusmansvt General Technical Chat 10 11-27-2004 12:37 AM
fog light mod gone wrong need help!!!!!!!!!!!!!!! bluezx3 MK1 Focus 6 12-17-2003 11:37 AM
Fog Light Mod Question??? chuka Ford Focus & General Car Chat 3 12-02-2003 11:29 AM
