Official FF System Pics Gallery - Page 19 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-04-2011, 08:07 AM   #181
02Zetechse
02Zetechse's Avatar
Fan#: 65832
What I Drive: 2002 Satin Black SE
FF Reputation: 6 02Zetechse Good Standing Member
2are grounds that will be connecting front battery to rears...I will also be grounding them to the body of the car .yes 6 runs is to reduce voltage drop as the class I had previously run only only allowed for a single battery . I am now building a wall for 6-8 10" subwoofers in a 4th order bandpass wall .
Current : 2 15s 149.5@56hz 2k rms Previous Trunk box 1 18 ,146.4@43hz 3500rms,Sony 12s 145.6@63hz
02Zetechse is offline
Old 11-04-2011, 09:36 AM   #182
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '14 TB ST3, '04 Silver SVT
Points 15,057, Level 79
Points: 15,057, Level: 79 Points: 15,057, Level: 79 Points: 15,057, Level: 79
Level Up 42% Completed
Forum Activity 3%
FF Reputation: 17 BLRich1 Great Standing Member
Buy-Sell-Trade Rating: (6)
you realize that the grounds don't need to be connected directly to the battery, just grounded to the car? A run that long kind of defeats the purpose of a ground.
My Rides:
'14 Tuxedo Black ST3
'13 Ingot Silver Escape Titanium AWD
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
Old 11-04-2011, 09:40 AM   #183
02Zetechse
02Zetechse's Avatar
Fan#: 65832
It still will make a difference ...especially when going for a .1 gain on a termlab
Old 11-04-2011, 05:41 PM   #184
Gazookz
Gazookz's Avatar
Fan#: 82103
What I Drive: 2011 Metallic Gray Focus SE
FF Reputation: 5 Gazookz Good Standing Member
Direct grounds are good. No harm in having them. It will eliminate the resistance in the welding points of the car. A lot of people actually run grounds from the front to the rear that are doing competitions because it does help gain on the meter by having less resistance for your grounds. If you think about it, when you ground to the car, it still has to travel to the front battery. So when you eliminate the possibility of resistance, you gain on the meter and voltage!
Gazookz is offline
Old 11-04-2011, 11:20 PM   #185
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
What I Drive: 2000 silver zx3
Points 4,255, Level 41
Points: 4,255, Level: 41 Points: 4,255, Level: 41 Points: 4,255, Level: 41
Level Up 53% Completed
Forum Activity 3%
FF Reputation: 6 alaskanzx5 Good Standing Member
thats why you ground to the frame of the car, so that way the welds and anything else doest get in the way. it is always best to ground everything straight to the frame.
alaskanzx5 is offline
Old 11-04-2011, 11:56 PM   #186
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
This is what i have always heard
Galatians 6:14
crice8 is offline
Old 11-05-2011, 02:42 AM   #187
Gazookz
Gazookz's Avatar
Fan#: 82103
Yeah but I was talking about competitions since he said he goes to them. Grounding to the frame is one of the best ways to ground, but it's still only as good as the grounds to your frame are under the hood. The more wires you have and connection points, like ring terminals, the higher the resistance is. So that may be the difference in .1dB on the meter. But for mostly everyone else grounding to the frame is the best choice as long as you have sufficient grounds under the hood to the frame. Even if you run 0 gauge to the amp, without 0 gauge grounding to the frame from your front battery, your 0 gauge just became limited to the stock wiring.
EDIT - thats why you should have more grounding points than just one under the hood as well.
Gazookz is offline
Old 11-05-2011, 11:25 AM   #188
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
and if you upgrade your grounds though out the car then to the frame and as short as possible it still the best.
Old 11-05-2011, 12:17 PM   #189
Gazookz
Gazookz's Avatar
Fan#: 82103
The whole body of the car, even when grounding to the frame, acts like a long wire. The ground wire to your rear battery or amp still has to travel to the front. The one wire for the ground results in less resistance from terminals. Believe it or not, each ring terminal you use adds resistance no matter how you put it on (solder or crimp). That little bit adds up for the people in competitions and can gain on the meter.
But like I said the only people who really do that are the ones that have their vehicle dedicated to competitions or who are widely involved in it. And even then you will find people running to the frame. I'm not argueing that grounding to the frame is bad, I'm saying that is why people run a seperate ground sometimes.
Gazookz is offline
Old 11-05-2011, 07:03 PM   #190
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
i understand what your saying, i just dont think that running a wire front to back would make a difference in the ground. also you still put a terminal end of some kind at both sides of the wire even if its going from under hood to trunk. rather then a ground from front to back 2 grounds in back to me is more reasonable.
Similar Threads
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
New System Setup......PICS - '07 focus ST - 56K beware pfry10 Car Audio, SYNC, MyFord Touch & Electronics 20 08-18-2010 04:13 PM
Stereo System Gallery?... AcIdBuRn02ZTS Car Audio, SYNC, MyFord Touch & Electronics 5 12-26-2006 12:26 PM
Sst Focus Int Pics In Photo Gallery... sstfocus Ford Focus Builds & General Showroom 0 11-30-2003 06:46 AM
