Sway bar end link replacement. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-07-2008, 08:06 PM   #1
brandnew161
brandnew161's Avatar
Fan#: 46064
What I Drive: 95' Eagle Talon TSi AWD
FF Reputation: 4 brandnew161 Good Standing Member
i noticed a sound coming from the front of my car over the past few months. Its a popping, metal on metal noise. Mostly occurs over bumps at low speeds. I thought it was my passenger motor mount since one of the bolts was sheared right off. I replaced that bolt but the noise is still there. I searched the forums and found that the culprit is most likely the sway bar end links. I jacked up the front of the car and took the wheels off. There is no play in the wheels so the ball joint or w/e is good. So i tugged on the end link and it moved, not a lot but it definitely wasnt as tight as i thought it should be. I pulled on it a little bit harder and it made the popping, metal on metal noise that i hear while driving. The joint right where the link meets the sway bar is popping and what not. I highly doubt this is normal. I want to make sure this is the part which needs to be replaced so that i dont just go spend money on parts i dont need. Thanks in advance.
ZC#172
brandnew161 is offline
Old 04-08-2008, 03:22 PM   #2
jbs03svt
Fan#: 22003
What I Drive: '03 CD SILVER SVT 3DR
FF Reputation: 1 jbs03svt Good Standing Member
I just changed my sway bar links with the OEM's and the sound was gone. Alot of folks say to get the MOOG replacments, I just couldn't wait for them.
It is not hard to change them at all, just be careful so you don't rip the boot when putting them back on. here is the link. Good advice from people with same experiences. Good luck.
http://www.focusfanatics.com/forum/showthread.php?t=155570
JB
jbs03svt is offline
Old 04-08-2008, 03:25 PM   #3
besthaticouldo
i wear no pants
besthaticouldo's Avatar
Fan#: 26970
What I Drive: '11 OBP WRX Sedan
Points 31,982, Level 100
Points: 31,982, Level: 100 Points: 31,982, Level: 100 Points: 31,982, Level: 100
Level Up 0% Completed
Forum Activity 6%
FF Reputation: 104 besthaticouldo Excellent Standing Member besthaticouldo Excellent Standing Member
Buy-Sell-Trade Rating: (23)
get the moog dude. no other way to go
remember that building a car shouldn’t come from parts it should come from deep inside your soul. let the car speak for all the emotions, memories and experiences youve made and the car will take a life of its own. truth over fame.
besthaticouldo is offline
Old 04-08-2008, 04:01 PM   #4
Cube
Cube's Avatar
Fan#: 53155
What I Drive: 2013 F150 EcoBoost 4x4
FF Reputation: 1 Cube Good Standing Member
I just replaced mine over the weekend. I got the replacement ones from Advance Auto. 18-20 bucks for the two of them.
Alot better then OEM. They now look like a TRE instead of the ball in socket setup.
I just hope you don't run into what I did. Drivers side lower mount was frozen. Stripped the nut and ended up cutting off the ball mount with a 3" cut off wheel and then grinding the rest off until I was almost to pop it out of the sway bar.
Handling is 100 times better then the OEM ones.
Oh and I was had the same noise you are talking about. Mine was so bad it did it when i turned the wheels.
Cube is offline
Old 04-08-2008, 09:48 PM   #5
brandnew161
Fan#: 46064
thanks guys. Looks like i needs some end links!
ZC#172
Old 04-08-2008, 09:51 PM   #6
PapoSwing
Regulator...mount up
PapoSwing's Avatar
Fan#: 3062
What I Drive: 03 Pitch Black SVT
Points 5,930, Level 49
Points: 5,930, Level: 49 Points: 5,930, Level: 49 Points: 5,930, Level: 49
Level Up 90% Completed
FF Reputation: 28 PapoSwing Great Standing Member
Buy-Sell-Trade Rating: (10)
Hit Mike up at Hilbish Ford hes got em in stock
PapoSwing is offline
Old 04-25-2008, 07:51 AM   #7
munky18
Fan#: 55290
What I Drive: 2001 Black ZX3
FF Reputation: 1 munky18 Good Standing Member
Anyone of a link to a cheap set of OEM or Moog. The best I have found so far is $24 a piece. Advanace Auto has 71 of them on back order already where I live. WTF!?
munky18 is offline
Old 04-25-2008, 08:32 AM   #8
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
FF Reputation: 17 wickedgreyzx3 Great Standing Member
Why are you trying to pimp OE parts with no grease-able fittings that will just wear out. Also moog's have a lifetime warranty.
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 04-25-2008, 08:40 AM   #9
PapoSwing
PapoSwing's Avatar
Fan#: 3062
^ hey dumba$$ Mike carries the Moog's as well
Old 04-25-2008, 08:56 AM   #10
UnFocusedST
Fear the TurboSnail!
UnFocusedST's Avatar
Fan#: 40342
What I Drive: 2013 Performance Blue Focus ST
Points 6,361, Level 52
Points: 6,361, Level: 52 Points: 6,361, Level: 52 Points: 6,361, Level: 52
Level Up 6% Completed
Forum Activity 9%
FF Reputation: 13 UnFocusedST Great Standing Member
Buy-Sell-Trade Rating: (14)
Were can I get a set of Moog's and how much will they cost?
Team Duratec #17
Hatch Nation #17
Midwest Crew #55
Boosted Crew #118
UnFocusedST is offline
Similar Threads
Changed out my Front Sway Bar Links theshadowconspiracy Wheels & Tires 2 03-10-2008 05:19 PM
Recommendations for SVT sway bar replacement The Blue Rocket Wheels & Tires 15 02-28-2008 12:50 PM
steeda rear sway bar mounting kit. One little problem. seige123 Wheels & Tires 12 12-12-2007 08:12 PM
Roush Sway Bar? klodkrawler05 Wheels & Tires 2 10-26-2007 10:43 AM
Running without a sway bar endlink oh-la-la General Technical Chat 3 07-01-2007 05:10 AM
