Timing belt issues - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-31-2008, 08:58 PM   #1
Jetphuel
Fan#: 54818
What I Drive: 2001 green SE
FF Reputation: 1 Jetphuel Good Standing Member
Timing belt issues
I have just finished replacing the timing belt on my 2001 and I have gone thru the adjustment proceedure three times but I still cant seem to get the timing correct. It misses and I am not sure where I have gone wrong. Could this be from the ECU needing to "relearn" the settings? Any suggestions would be appreciated. I am considering taking it to Ford and letting them set the timing at this point since I am drawing a blank.
What happened to the simple timing marks on the pulleys and block method???
Jetphuel is offline
Old 04-01-2008, 08:04 AM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,924, Level 100
Points: 51,924, Level: 100 Points: 51,924, Level: 100 Points: 51,924, Level: 100
Level Up 0% Completed
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
Buy-Sell-Trade Rating: (28)
Double check your self this way , remove valve cover and #1 spk plug , put long screw driver into #1 plug hole and with ratched rotate the engine in its running direction till it comes to the VERY TOP where it does not move any more , you may have to do this a few times to get use to what to look for as when your at TDC (Top Dead Center ) the crank will still rotate slightly but the screw driver not go up any more , you have to do this slow and have some one helping , when you get to this point , you could be right on and your cam plates slip right in or 180 deg off and have to ratate it around till you get TDC again
What your looking for is the piston at TDC and the cam plate to slip right in , some engine stop tools were made wrong and had the engine in the wrong position to install belt
If the timing is anywhere neer close you should not be getting any missing
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-01-2008, 01:27 PM   #3
Jetphuel
Fan#: 54818
Thanks for the info turbo. I made my own stop pin tool from a bolt and information in the Haynes manual. It said to make it 63.4mm long and I found a 65mm and washer and ground the end down a bit to give some better clearance from the exhaust. I just find it hard to believe that there is a documented process for this that I have followed quite carfully and cant seem to get it right. Probably done a dozen belts on other cars and no where near this much trouble...
Jetphuel is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
2002 1/2 zx3 timing belt removal With a twist not the same as most of the other cars Knuckles899 General Technical Chat 4 03-11-2007 04:34 PM
Timing Belt - Loosen sprockets or not? flyingfocus ZETEC Performance (2000-2004) 2 11-11-2006 11:32 AM
Loosening Cam Sprockets - Timing Belt flyingfocus General Technical Chat 1 11-09-2006 07:01 PM
Timing Belt jac0b ZETEC Performance (2000-2004) 2 11-25-2003 05:52 PM
