Parking brake adjustment (drums)???? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-27-2008, 08:03 PM   #1
cancamo2
cancamo2's Avatar
Fan#: 53793
What I Drive: 2001 red station wagon
Points 663, Level 13
Points: 663, Level: 13 Points: 663, Level: 13 Points: 663, Level: 13
Level Up 26% Completed
FF Reputation: 39 cancamo2 Great Standing Member
Just installed new shoes and hub/drum assembly, all original parts, cleaned the new drum with brake cleaner to remove any oil, lubricated all moving parts including the adjusting strut. Followed each step of the Haynes repair manual, but the parking brake does not "adjust" to lock the wheels. Adjusted the parking brake cable, almost screwed the nut all the way in but no major change. I'm I missing something????
cancamo2 is offline
Old 03-27-2008, 09:43 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
I think there was something about driving in reverse and applying the parking brake gently to adjust the shoes. Then use the adjustment screw on the brake lever. So loosen the parking cable a bunch and try it that way. Then use the adjustment screw to snug the cable from there.
It's been a few years since I did mine, have to do them again soon.
iminhell is offline
Old 03-27-2008, 10:06 PM   #3
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
oh wow im gonna have to try that...
I can push my car when its in neutral and the e-brake is on.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 03-27-2008, 10:37 PM   #4
FocusFreak87
FocusFreak87's Avatar
Fan#: 28487
What I Drive: 2010 Toyota Tundra SR5
FF Reputation: 2 FocusFreak87 Good Standing Member
The e-brake adjustment is under the shifter. Ur car shouldn't move when u put it in D or 1st gear with 6 clicks of the handle...Hope this helps...
Go STEELERS!!!
TEAM DURATEC #108
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature
Metal... is... AWESOME!!!
FocusFreak87 is offline
Old 03-27-2008, 10:42 PM   #5
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
ah dun tried dat
im fully adjusted on that nut and I still only get 5 clicks.
but the car only barely crawls in D so maybe its not as bad as I think... still kinda not cool when the e-brake doesnt hold it still on a slight hill.
SUV this!
illinipo is offline
Old 03-28-2008, 09:57 AM   #6
JRODSVT
Dragon Warrior
JRODSVT's Avatar
Fan#: 15362
What I Drive: 03 SVT ZX5
Points 19,067, Level 87
Points: 19,067, Level: 87 Points: 19,067, Level: 87 Points: 19,067, Level: 87
Level Up 44% Completed
FF Reputation: 97 JRODSVT Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Loosen the parking brake cable adjustment nut until there is no tension in the cable.
1 Remove the retaining clip.
2 Loosen the adjustment nut.
Apply and release the brake pedal to make sure the rear brakes are correctly adjusted.
Raise and support the vehicle.
Make sure the parking brake cable and conduit is correctly routed and located in its clips.
Raise the parking brake control up four notches.
Tighten the parking brake cable adjustment nut until increased torque is noticed.
Apply and release the handbrake lever several times with sufficient force to settle the parking brake system.
Release the parking brake control to its lowest position.
CAUTION: If adjusting the cable does not affect the plunger movement, then the cable is either damaged, binding or seized. Install a new cable and conduit. NOTE: The total movement of both the left-hand side and the right-hand side plungers added together should be between 1 mm and 8 mm . Check the movement of the plunger in the left-hand side and the right-hand side backing plates. If further adjustment is required, adjust the cable using the parking brake cable adjustment nut.
J-RAWK!!!
FocusFests best of sound 2008
(Oo> (SVT) <oO)
o xxxxxxxxxxxx o
JRODSVT is offline
Old 03-28-2008, 11:17 AM   #7
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
thanks jarod, now i know what im gona be doing extra when i bleed my brakes...
SUV this!
illinipo is offline
Old 03-28-2008, 11:28 AM   #8
lildudeinacar
lildudeinacar's Avatar
Fan#: 49485
What I Drive: 2003 Black SVT
FF Reputation: 6 lildudeinacar Good Standing Member
my svt one side doent move but the other one locks up.... i ikno thats irrelevent to you but thought thati would say something
2003 SVT ZX3 Build # 2002 Birth: 5/20/03
"You know you drive a SVT Focus when... you take evey single off ramp or turn at double the suggested speed. "
Have you ever shifted so hard that you fart...
lildudeinacar is offline
Old 03-28-2008, 11:36 AM   #9
JRODSVT
Dragon Warrior
JRODSVT's Avatar
Fan#: 15362
make another thread about it and i can see if i can help you out.
J-RAWK!!!
(Oo> (SVT) <oO)
o xxxxxxxxxxxx o
JRODSVT is offline
Old 03-28-2008, 01:15 PM   #10
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
When car is that old I would try replacing the E-brake cable itself, the outher part tend to collapse ..
nilskje is offline
Similar Threads
Removing the rear brake drums kcin67 Brakes, Suspension & Body Chassis 23 06-20-2014 03:12 AM
Brake and Drums Cmmcc SPI Performance (2000-2004) 3 08-19-2005 10:29 PM
PLS HELP!! Noise when taking off: clutch or brake oh-la-la SVT Performance (2002-2004) 17 02-09-2005 12:34 PM
WTB: Stock brake parts, rotors, drums, etc.. BlownSkillet Archive 0 03-21-2004 07:58 PM
Holy parking brake batman! CowsGoMoo Ford Focus & General Car Chat 8 10-27-2003 12:14 AM
