Engine & Transmission Swap The place to chat about any engine and transmission swap.
#1 | ||||
speed 3 into focus?????
everyone says that the mazda 3 is a 2.3 dura, Right??? so will i be able to just do a swap from a speed 3 to the focus, i have the 2.3 dura so it should bolt right up, right?????
if its possible what i will need????? |
Remove Advertisements |
Fan#: 1
#2 | ||||
BAD EGG
I don't think it is doable, but here is good reading on the engines in any case:
http://en.wikipedia.org/wiki/Mazda_MZR_engine
04‘ SVTF/5, EAP, Pitch Black (rip) # 908 of 1079, Born 03/16/2004 SVT SQUAD # 68 " I brake for saucy Pirate wenches" Last edited by LastRites; 03-25-2008 at 10:11 PM. |
#3 | ||||
Just boost your 2.3... save the expense and hassle of the swap. You probably have the BEST engine for a focus to begin with.
Zetec Crew #137 / Boosted Crew #88 2003 Liquid Grey ZX5 SES - see profile for pics |
#4 | ||||
i heard those Mazda3 speed engines go for like 7 geeeeez yooo
I'm here to raise that BS flag.Ford Focus ZTS 125whp/129wtq Subaru Impreza WRX Stage 2 Protuned On Mustang Dyno 207whp/273wtq I have 5 points on this site :-/ |
#5 | ||||
暗炎
ECU wouldn't hook up. Gauges wouldn't work. Mazda Speed3 uses a six speed transmission, so it probably won't bolt up to your transmission.
#6 | ||||
GL1TCH
yeah its easir to call focus sport and say turbo me, you'll end up wiht twice the car for half the cash easy.
focus owner whos runnin with the hatchet zc187 focus nation and fvscc's car 343 still getting part and things for this turbo. will it run soon?? who knows. |
#9 | ||||
honestly. i could see it being worth it. just looking quickly at the specs of the speed 3 motor. it has slightly less compression that the focus 2.3, so you can probably run alittle more boost.
and sinse its a factory boosted engine, it'll more than likely have stronger internals. the ignition and timing system is more advanced. and the block and head are stronger pieces, the focus has cast alluminum, and the speed has alluminum alloy. and also one small thing, the speed engine will be alot quieter, sinse it has a better "lifter" system for the valve train. not like our noisey mechanical buckets. so just thinking about it, i would say... you need the engine, tranny, shifter linkages, and possibly shifter out of a speed 3. then the entire engine harness and the PCM, which you can probably get those 3 things together(engine, harness and PCM) from a junkyard. and i would say start from there, the axles may have to be one offs but maybe not. a drive shaft shop should be able to take the speed 3 axles and shorten or lengthen them to work with the focus spindals/track width. so im sure with maybe a weeks worth of work, if nothing has to be fabricated from scratch, such as engine mounts, then i could honestly say its do-able. because you cannot beat the specs. if you get a turbo kit from focussport, and put it on a 2.3 in a focus, you can only get roughly 240whp without built internals, the speed 3 already has a leg up at that point with 263hp 14% driveline loss, puts you at about 223 whp with the speed engine. but then you've got a great platform, and could very very easily get the whp up on the speed 3 engine alot quicker, and probably very well without opening the block. oh and sinse im sure the downpipe wont work properly, maybe... but you can then fab a 3inch down pipe to a 3inch exhaust, and that'll give your speed engine a bit of breathing room.
http://www.full-race.com/r14-fire-video.html |
#10 | ||||
I agree with honhon in that it'd be a great swap to try, and I've thought about it a lot, came close to buying the parts once too, but upon closer inspection, for the focus we'd also likely need to replace the hood with a one-off hood, since the speed 3 uses a top-mount intercooler, as opposed to the front mount on the focus turbo kits.
You can see an ultra high-res rendering of the speed 3 engine here: http://michaelmallon.net/fordfocus/MAZDA3_engine_HR.jpg The other thing I've thought about is just the 6-speed transmission swap, but I've yet to find any decent pictures of the lower mount to see if it'd be close to bolting straight into the focus subframe without modification. Realistically, Assuming the mount fits, custom axles would be the only real issue with making it work. Anyway, if I ever attempt any of this I'll be sure to post a thread, but don't count on it in the near future by any means. cheers, -- michael
My "SVT EAP" D23E sedan... done: Recaro's ◆ HID's ◆ BSD ◆ Brisk LGS ◆ SVT brakes & suspension ◆ 22mm RSB wishlist: built engine ◆ oil sump baffle ◆ mazdaspeed3 tranny ◆ stage 2 turbo ◆ tune |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2008 Focus | SpcghostII | Ford Focus & General Car Chat | 55 | 09-17-2007 08:05 PM |
| 2008 Ford Focus US-Spec part 1 | mitchlguzin | Ford Focus & General Car Chat | 9 | 01-08-2007 05:57 PM |
| Soon to come, more SVT parts for your non-SVT Focus... | myFordPerformance.com | ZETEC Performance (2000-2004) | 33 | 01-02-2007 11:41 PM |
| Ford Focus Wheel & Tire Information | hotfocus | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 0 | 10-24-2003 12:45 PM |
