How to change the pcv valve in a 2001 zx3? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-25-2008, 01:35 AM   #1
Brivon
Brivon's Avatar
Fan#: 54232
What I Drive: 2001, gray zx3
FF Reputation: 1 Brivon Good Standing Member
Heres my problem... my zx3 (40.000 miles) stars having hesitations, and rough idle,,, first desconect the EGR hose on the top, get a lot better... after I change the rear hose from the pcv (completed suck itself when turn on the car, and soft when was off)...... going to the beach a engine light comes, then disconect the negative from the baterry and re-conect the top hose from the egr, it stops hesitations but rough idles is the same,,,
I'm thinking changing the pcv cause the gases can go by the rear pcv hose and it coul be coggled, called the dealer and told me was a pcv valve? where is it? what does it for?? I couldn't belive it!! and just labor hand cost $45 + pcv valve ($20)+ taxes...
Any tip how to change pcv valve to doit my self??
Also I'm planning to change the dpfe sensor, clean the maf... any more ideas how to eliminated rough idle? Thanks
Brivon is offline
Old 03-25-2008, 11:10 AM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
FF Reputation: 49 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
PCV is to the right of the exhaust manifold and behind it. Should see a black rubber 90, that's it. just pull it out and push the new one in.
Hesitations and stumbles can be a few things. Instead of clearing the codes, check them and report back.
iminhell is offline
Old 03-25-2008, 11:34 AM   #3
GZetec
GZetec's Avatar
Fan#: 36463
What I Drive: 01 White SE 4dr
FF Reputation: 1 GZetec Good Standing Member
yeah the pcv is probably thea easiest thing to replace on the focus next to the air filter... you don't need any tools to do it, its right under the header on the black box looking thing. your CEL came on because you disconnected your EGR tube! plug it back in and bu a new dpfe from ford, or do what i am going to do and save up for an xcalII and delete the whole damned egr system! in the long run you'll just be buying at least 2 more dpfe's they are total crap.
Currently cruising with: AEM CAI. Shorty header. FC HF Cat. CatBack 2.25" & Flex. FC UDP's. Euro Upper and Lower grill and clear corners. Halo Headlights. Tune by Turbo Tom. SVT Struts, Eibach Springs. Ported TB.
Television. Rules the Nation.
GZetec is offline
Old 03-26-2008, 08:54 PM   #4
Brivon
Brivon's Avatar
Fan#: 54232
Thanks for the advise... at the dealer in my country de pcv is $20, dpfe is a lot of more $ but have to do.. also I'm thinkin to buy a obd2 can bus and live data... cause mechanic here make money jus for plugging it!! i'll let you know if my zx3 get better...
Brivon is offline
Similar Threads
2001 ZX3 $4800 in Ohio. greenZX10 Archive 7 03-20-2008 06:38 PM
WTB: 2001 ZX3 Inner Fenders YellowZX3 Archive 0 10-11-2006 12:13 PM
pcv valve question???? crazybaked428 General Technical Chat 3 08-02-2006 07:51 PM
Stripping a 2001 Focus ZX3 d3f3nd3r Archive 11 01-11-2006 02:42 PM
PCV Valve on teh SPI.. - finally found it. The_good_guy SPI Performance (2000-2004) 2 06-17-2004 09:35 PM
