Focus Rear Tire Wear - Camber Bolts or Control Arms? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-24-2008, 08:16 PM   #1
2003focusowner
Fan#: 51939
What I Drive: 2003 Focus SE SPI
Points 5,246, Level 46
Points: 5,246, Level: 46 Points: 5,246, Level: 46 Points: 5,246, Level: 46
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 2 2003focusowner Good Standing Member
Arrow Focus Rear Tire Wear - Camber Bolts or Control Arms?
Like allot of others I have the rear inner tire wear problem on my 03 sedan. I have been trying to pin my dealer down on it and finally got an answer from them today. They cannot correct it but they can slow it down with the installation on new upper control arms(TSB 03-13-5 date July 1, 2003), so they say. The revised +1.0 degree rear upper control arms is what they recommend installing. The control arms are $121.00 each and the say they can change them in about 1.5 hours.
I'm alignment ignorant so here goes my questions. I have been following the thread on alignment for these vehicles a while back. It was recommended to install a set of camber bolts and the thread gave the specs for putting the rear of the car in the proper alignment. I can't find that thread anymore however here is my question. Do I need to install the upper control arms or can I achieve what I need for the rear alignment simply using the camber bolts?
Also has anyone heard of repalcing the rear upper control arms and has it helped any?
2003focusowner is offline
Old 03-24-2008, 08:34 PM   #2
Assasin
Assasin's Avatar
Fan#: 346
What I Drive: 2002 CD Silver ZX5
FF Reputation: 1 Assasin Good Standing Member
id recommend the SPC rear camber arms. i got them on my car and have perfect wear on my rear tires. check em out. i got them off ebay for like 170.
I love chocolate pudding
I love nitrous
I love Chuck Norris
Assasin is offline
Old 03-26-2008, 11:16 AM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Camber bolts will do the job for a lot less money than either the Ford or SPC control arms. The bolts allow +/- one degree of adjustment flexibility wherein the Ford control arms are fixed at a one degree camber reduction. Sometimes you don't need that much which makes the bolts the better (and cheaper) solution.
Geezer is offline
Old 03-26-2008, 11:26 AM   #4
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,617, Level 48
Points: 5,617, Level: 48 Points: 5,617, Level: 48 Points: 5,617, Level: 48
Level Up 34% Completed
Forum Activity 4%
FF Reputation: 36 thenorm Great Standing Member
also look into your alignment as it is now, what is your toe at. camber alone doesnt have too much of an effect (i have -2º camber with no problem), but it is agravated by high toe. setting toe closer to 0 will improve the situation.
also i second using the camber bolts, they're only like 30$.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 03-26-2008, 03:47 PM   #5
pantherdan
pantherdan's Avatar
Fan#: 37438
What I Drive: 09Fusion SEL SAP and 07Focus ZX5
FF Reputation: 1 pantherdan Good Standing Member
My Wifes 2005 ZX4 SE was purchased used and I looked at the tires before buying. They were all about 50% worn - all evenly. Today (about 1 year later) I found the Drivers rear tire was cupped and there was inside wear on the passenger front tire. A very similar thing happened to a 2001 Focus LX that we had previously owned. I know all 4 tires were brand new when I bought that car.
IMHO, I think its the way we drive. We live in the western North Carolina mountains and we drive like its the road track in Nascar - as fast as possible with hard cornering all the time. I just installed a strut tower brace on my new ZX5 SES. My train of thought is that the uneven tire wear is from the flexing of the strut towers drastically changing the toe in during our hard cornering. The SES has both front and rear sway bars, and with the strut brace it now seems to be the tightest suspension I have driven on. If my new tires wear well, then I guess my theory would be right. I plan to order one for my wifes ZX4, but unfortunately the SE only has a front sway, so it might not help handling as much with the looser rear end.
Anyway, could your problem be from your driving habits? I know the Focus is a popular car for people who like to drive pretty aggressively.
2009 Fusion- Vapor Silver SEL SAP V6
2007 Focus- Aqua Blue ZX5 SES
Stupid warranty! Stupid emissions! Stupid gas prices!
pantherdan is offline
Old 03-27-2008, 10:43 PM   #6
Geezer
Fan#: 1427
FWIW, cupping is caused by either a tire out of balance or a bad/worn out shock. You're right aggressive driving can accelerate tire wear especially the front tires of a front wheel drive car.
Geezer is offline
Old 04-05-2008, 02:09 AM   #7
pantherdan
pantherdan's Avatar
Fan#: 37438
I also plan to start rotating my tires with my oil changes (which I do every 5000 miles).
I still think my tire wear problems are more driver related. In about a year I will have some info to support or disprove my theory.
Old 04-05-2008, 06:10 PM   #8
Garick
Fan#: 6143
What I Drive: 03 2.3l Twilight Blue Sedan
FF Reputation: 1 Garick Good Standing Member
Have you gotten your alignment checked? Sure, the driving could be part of it but the alignment would be my first suspicion.
Excessive toe will kill tires very fast, camber does not have anywhere near as drastic of an effect.
The effects of strut tower bars on our cars are debatable at best.
for the op I would suggest the camber bolts or spc camber arms. I think I'd shoot for something like -.5 degrees for just street driving and a bit more for competition use. You could go with fords tolerances on specs too but don't let them do a 'meh, thats close enough' kinda thing.
Garick is offline
Old 04-05-2008, 06:32 PM   #9
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,747, Level 78
Points: 14,747, Level: 78 Points: 14,747, Level: 78 Points: 14,747, Level: 78
Level Up 75% Completed
Forum Activity 11%
FF Reputation: 90 goinloco1 Excellent Standing Member
there is an easier and cheaper way to kill both birds. both of my cars have had this done with no problems what so ever over 45,000 miles combined.
pop the rear hub loose from the lower control arm. elongate the holes the bushing bolt goes through by about 3/8"-1/2" toward the center of the car on both lower control arms.assemble loosely and push the bottom of the hub toward the center of the car. this will take the camber out of it and some of the toe. the rest of the toe can be done with the toe adjustment. torque to specs and your set. i did find on lowered cars camber bolts will still be needed, but this gives alot more adjustment range.
or for a couple hundred buy the ford racing adjustable subframe.
goinloco1 is offline
Similar Threads
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
Help On TSB's Or ?? Rear Tire Wear. 03BSVT SVT Performance (2002-2004) 7 05-23-2004 04:31 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
Ford Focus Wheel & Tire Information hotfocus Wheels & Tires 0 10-24-2003 01:45 PM
rear camber bolts whiteboyslo Archive 3 10-01-2003 07:29 PM
