How-To: Replace the Fuel Pump (56k death) - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-29-2013, 04:32 PM   #41
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,380, Level 75
Points: 13,380, Level: 75 Points: 13,380, Level: 75 Points: 13,380, Level: 75
Level Up 33% Completed
Forum Activity 99%
^^^ - Yup!
And Trev. - Coil pack issues can also create higher rpm issues, check base for cracking after you pull it to look there is the common quick check diagnostic for that...
sailor is online now
Old 04-29-2013, 08:41 PM   #42
Kona Focus Lover
Fan#: 113907
What I Drive: 2000 Silver Kona ZX3
FF Reputation: 1 Kona Focus Lover Good Standing Member
how do you take out the rear seats in a hatcback?
Kona Focus Lover is offline
Old 04-29-2013, 08:43 PM   #43
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,586, Level 58
Points: 7,586, Level: 58 Points: 7,586, Level: 58 Points: 7,586, Level: 58
Level Up 18% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
Fold seats down and use torx bits to unscrew brackets. Seat bottom flips forward for access.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is offline
Old 04-29-2013, 09:52 PM   #44
Kona Focus Lover
Fan#: 113907
thanks bro :)
Old 10-04-2013, 02:56 PM   #45
WillK
Fan#: 117044
What I Drive: 2004 Blue SVT Focus 3 door
FF Reputation: 1 WillK Good Standing Member
Originally Posted by whynotthinkwhynot View Post
Hey, not to dampen anyone's ideas, but the hole in the floor for easy fuel pump removal is something I've noticed that American engineers lack the ability to think of- even on trucks!!!
Most every Japanese car I've ever changed the fuel pump on had a removable cover. WTH is wrong with our boys and girls in Detroit???
briandg510= Fuel pump relay?
Exhaust fumes in the passenger compartment tend to be frowned upon.
WillK is offline
Old 10-04-2013, 02:58 PM   #46
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Forum Activity 25%
If done correctly which is not hard to do there is no reason for exhaust fumes. Shouldn't have to worry about fumes anyways unless you have leaks.
Team Focalize
Hatch Nation #9
Blue5ive is offline
Old 10-04-2013, 05:11 PM   #47
Bills86e
Bills86e's Avatar
Fan#: 119322
What I Drive: 2000 green SE, 2007 Kappa Speedster
Points 398, Level 7
Points: 398, Level: 7 Points: 398, Level: 7 Points: 398, Level: 7
Level Up 96% Completed
FF Reputation: 1 Bills86e Good Standing Member
What we need here is what tool to cut the metal, then how to place back to avoid cabin exposures from exhaust asphyxiation or gas under car explosion. Use safe judgement!
My guess is remove rear seat and find the electrical fuel pump relay to wires rubber gromment, pull-look thru, then have water hose sprayer close, use a battery metal cut saw with non-arcing blade, and cut 10" square. Do this in a safe open area, and no one near by, or near other flamable materials.
Do same at local Boneyard but 11" square with a notch path cut to center wire, to get on your wires to your pump. Only saw no more that 1/4" deep thru the metal. Use a fire rated cauk under all edges of new 11" square plate and screw it down with drill point stainless #8 x 3/8" long panhead screws every three inches around the perimeter, centered on your 10" hole..
The gas tank fuel module ring is simply lefty-loosey. Make a notch cut U in a wood 12" long 1 x 4 as a tool, if ya can't un-loosen the ring. The entire fuel pump module with its lift arm
float with come out carefully. Put the thing on your bench and dis-assemble to replace the pump itself, or fix your fuel float reader card..ect Take a picture of its orientation as you lift out. Don't
loose the rubber o-ring that seales the module cap, or cross-thread it screwing it back on.
Bills86e
Bills86e is offline
Old 11-09-2013, 07:31 PM   #48
willysp
Fan#: 100057
What I Drive: 2002 red zx5
FF Reputation: 1 willysp Good Standing Member
hi, I have a 2002 and I am replacing the fuel pump. This fuel pump is the one "without" the springs that keeps it in place. for some reason I can't take it out of the tank. I tried pulling, turning it and tried to find any clips holding it in place but I couldn't find anything.
Any suggestions?
thanks
Wilson
willysp is offline
Old 11-09-2013, 09:12 PM   #49
willysp
Fan#: 100057
I figured it out! I just turned it counter clockwise and it came loose.
now I am having a lot of trouble putting the blue ring back. any suggestions? I was thinking about using some grease...
willysp is offline
Old 11-10-2013, 09:06 AM   #50
Bills86e
Bills86e's Avatar
Fan#: 119322
Points 398, Level 7
just wipe with a rag to clean it. no need to grease it.
Bills86e is offline
Similar Threads
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
Need help with Fuel Pump Mr.Bergner General Technical Chat 5 01-08-2008 01:15 PM
How to determine a vacuum leak or lack of fuel focus_SWT General Technical Chat 0 11-27-2007 08:36 AM
Fuel pump, little box inside basket needed? zGOTxBOOST2 General Technical Chat 0 11-11-2007 10:34 PM
2001 fuel pump recall? Silva_Bullet01 General Technical Chat 2 01-23-2005 12:30 AM
