Tire Question (Please Help) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-17-2008, 01:10 PM   #1
rwebb
Fan#: 54404
What I Drive: 2005 Grey ST
FF Reputation: 1 rwebb Good Standing Member
Question Tire Question (Please Help)
Hi my name is Will and I am new to this forum. I have a question about the tires on my Focus. I have a 2005 Focus ST that has the 205/50/R16 my question is can I put a 205/55/R16 on it without it rubbing. My next question would be is it possible to put a 15" wheel on it. I am trying to get away from the stock tires because they are expensive and I comute. I understand that changing the tire size will cause my speedometer to be off. I just want to know if the next size up will rub or if the 15" wheel will fit. I wasn't sure if the breaking system was different for the ST than the other Focuses. I know a bigger brake rotor will not allow you to downsize wheels. Thanks in adavance for any help.
rwebb is offline
Old 03-17-2008, 02:49 PM   #2
Sid03SVT
Sid03SVT's Avatar
Fan#: 39759
What I Drive: 02 Explorer 4.6L, 02 CBR600 F4i
FF Reputation: 8 Sid03SVT Good Standing Member
check here for speedo differences, i'm not sure about the st brakes clearing 15" wheels, im pretty sure the rotors are bigger than regular focii
http://www.miata.net/garage/tirecalc.html
save a cow, eat a vegan
missing my 6-speed until proven otherwise
if someone helps you out, give them a rep point
don't know how? click on the number next to "FF Reputation" and add a comment
Sid03SVT is offline
Old 03-17-2008, 03:04 PM   #3
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
15" wheels are the smallest you can fit. OEM definately will fit. Aftermarket should as well, but you have to double check on those, since its a really tight fit with OEM wheels.
With a stock suspension, you'll be fine with a 205/55-16. Like you said, your speed will be off.
Egz is offline
Old 03-17-2008, 04:40 PM   #4
rwebb
Fan#: 54404
Thanks. I had a truck once I wanted to downsize the wheels but the rotors wouldn't let me. Checked out that site and the 205/50/R16 was almost the same as 195/60/R15. Checked my spare and it is on a 15" rim so I am pretty sure the 15" will work. Thanks again.
rwebb is offline
Old 03-17-2008, 06:55 PM   #5
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
If you are traveling a long ways at one time at a high speed say on a freeway wouldn't a larger diameter make sense as far as gas and distance traveled? In essence changing your final drive.
jetrinka is offline
Old 03-17-2008, 07:10 PM   #6
Oregon-ized
Oregon-ized's Avatar
Fan#: 37274
What I Drive: 2004 Twilight Blue ZTW 2.3L
FF Reputation: 82 Oregon-ized Excellent Standing Member
I've got 205/55/16 on OEM wheels on my 04 wagon, which replaced the original 195/60/15s. No problem.
ATX Faction #33
Oregon-ized is offline
Old 03-17-2008, 08:32 PM   #7
rwebb
Fan#: 54404
jetrinka,
you are right a larger diameter wheel would equal less wear less rotations per miles traveled, However there is not much room for a much larger tire. I was just concerned with having a tire that would rub while turning.
Oregon-ized thanks for the response. I was really wanting to get that size tire, I just didn't want to buy a new set and have them rub. I am going to check locally for a set of tires on a 15" rim or I may just go with the 205/55R16 as you did.
Thanks to everyone for the help.
rwebb is offline
Old 03-17-2008, 09:47 PM   #8
Saucymuffin
Saucymuffin's Avatar
Fan#: 53106
What I Drive: 2003 Because Racecar SVT
Points 2,288, Level 28
Points: 2,288, Level: 28 Points: 2,288, Level: 28 Points: 2,288, Level: 28
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 4 Saucymuffin Good Standing Member
yeah I just got tires and it was a bitch trying to find the 205/50R/16s had to order them and wait for three days.
Saucymuffin is offline
Old 03-18-2008, 06:57 PM   #9
rwebb
Fan#: 54404
Yeah I feel your pain no one around here ever has them in stock, they are overpriced, and the tread life sucks. I would rather have a longer lasting tire, I hardly ever do any hard driving.
rwebb is offline
Old 03-18-2008, 08:56 PM   #10
mavtoy
mavtoy's Avatar
Fan#: 53994
What I Drive: 2001 focus wagon
Points 1,043, Level 17
Points: 1,043, Level: 17 Points: 1,043, Level: 17 Points: 1,043, Level: 17
Level Up 44% Completed
FF Reputation: 1 mavtoy Good Standing Member
Hi Sir with tire question, I used to have a 06 Zx4 With the bigger size brake rotors on the front like the svt has , stock 15s wouldnt fit on it I tried it. make sure you try them before buying them if you have the bigger calapers they wount work. I just put a set of215/45/17 on my focus they clear fine no problems.
mavtoy is offline
Similar Threads
205/55/15 vs 195/60/15 klodkrawler05 Wheels & Tires 35 03-13-2008 11:50 PM
Another tire question BMARTIN03ZX3 Autocross Racing 21 03-13-2008 05:23 PM
Tire Wear Question drmike6054 Wheels & Tires 0 02-11-2006 11:18 PM
New Tires for Cheap and a Question Oni Wheels & Tires 24 01-28-2006 12:40 AM
