Go Back   Focus Fanatics > Ford Focus Discussions > Ford Focus Technical Chat
Ford Focus Technical Chat This section is for technical discussions relating to general maintenance, electrical issues, engine trouble, and recalls.
Thread Tools Search this Thread Display Modes
Old 03-17-2008, 07:03 AM   #1
grimple1
FF Member#: 30544
FF Reputation: 1 grimple1 Good Standing Member
Zetec Water Pump Removal (How to)
Well I just got done replacing the water pump on my wife's 00 Focus ZX3 Zetec and I wanted to write a post on how I went about doing it. It's not a "simple" job as it takes some maneuvering to get that sucker out.
1. Jack front of car up.
2. Take off Radiator overflow tank from frame (1 x 10mm).
3. Remove bolts on Water Pump Pulley (3X 8mm wrench) (I took mine out from below after I loosened them from above).
4. Remove belt cover plastic from below (3x 10mm).
5. Flex tensioner pulley upward and remove serp. belt (15mm wrench).
6. Open Radiator overflow tank lid and Drain Radiator fluid via Radiator drain plug on lower driver side.
7. W/ wood block and jack support the engine's oil pan.
8. Remove passenger side motor mount w/ engine FIRMLY supported (2 x 19mm , 3 15mm).
9. Remove water pump bolts (4x 8mm? wrench)
10. Lower engine slightly and snake water pump pulley out downward.
11. Water pump downward next (I had to go up and down til I hit a magic spot).
Install is in reverse w/ burping radiator at the end.
It took me a bit of time as there's not much wiggle room for the pulley and pump to exit the vehicle. Why ford didn't enlarge the indention in the frame railing so to allow easy removal and installation is beyond me. (if you don't know what I'm talking about, you soon will).
First time doing it and it took me 2.5 hrs with the Haynes (which btw is useless in this situation b/c they show it coming out with the engine out of the car!! WTF!)
grimple1 is offline   Reply With Quote
Old 03-17-2008, 07:08 AM   #2
scrammer
scrammer's Avatar
FF Member#: 26570
What I Drive: 2003 SVT
FF Reputation: 163 scrammer Excellent Standing Memberscrammer Excellent Standing Member
Buy-Sell-Trade Rating: (27)
this would be great if you had pics. but ill stickie this until Chad can get it into the How-To Forum.
for future reference, anyone who wishes to put together a how-to, please take pictures. this aids newbe's without much auto experience emmensily.
Focus Rising 2010 Co-Event Organizer
Focus Rising 2010 - June 4th-6th - Check Out www.FocusRising.com
REGISTER for Focus Rising HERE before May 17th!!!!
scrammer is offline   Reply With Quote
Old 03-17-2008, 01:17 PM   #3
grimple1
FF Member#: 30544
sorry about not having pictures. It was a last minute fix (was dripping water)
I'd also like to add that I took off the A/C comp from it's pedistol. It's held in by 4 x13mm? very long bolts. They just zip right out. I just removed the bolts and let it swing out of the way. You can do this w/o loosing A/C freon. This should be considered step
9A.
Was looking at it this morning and realized I'd forgot to mention that.
Old 03-17-2008, 07:25 PM   #4
scrammer
scrammer's Avatar
FF Member#: 26570
hm, i dont believe playing with the power-steering is needed. i didnt have to do that when replacing a pump on a friends FoFo.
dropping the engine IS necessary for the water pump to be removed. the indent in the cradle next to the pump just isnt large enough to wiggle the pump out of there.
Old 03-21-2008, 01:24 AM   #5
Andrius
FF Member#: 36322
What I Drive: 2000 ZX3 EvoIII
FF Reputation: 1 Andrius Good Standing Member
i believe a drop is needed in some focus. Mine for example. I need to replace my Water Pump Gasket (for some reason there is currently a LACK of one on my car... i dunno why) and the best I can do is tilt the water pump to about 75 degrees... won't come completely out of the engine though... that indent just isn't big enough!
any other trick to doing this without dropping the engine?
-Andrius
"Imagination is the one weapon in the war against reality."
Andrius is offline   Reply With Quote
Old 03-24-2008, 11:46 AM   #6
S2
Corporate Lackey
S2's Avatar
FF Member#: 4939
What I Drive: 2005 RSX-S, 2006 S40 2.4i
FF Reputation: 68 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'How To Archive'....
Chad - FF Senior Moderator
S2@FocusFanatics.com
Forum Links:
Ford Focus: General History and Information
Complete 'HOW TO' Archive
Member's FAQ and Information Archive
Forum: Rules, Guidelines and Regulations
Forum: Staff Contact Information - Who's Online
Someone helped you on the forum, please consider leaving them some
reputation by clicking this icon to the left under their username.
S2 is offline   Reply With Quote
Old 09-18-2008, 05:12 PM   #7
ejanzen
FF Member#: 59284
What I Drive: 2000 Silver ZTS
FF Reputation: 1 ejanzen Good Standing Member
Thanks
I just used this procedure to change my water pump. The shop quoted me $600 to change it. I did it in 2 hours, since I had this procedure. The key was removing the A/C compressor. That gives you enough room to shift the engine so that the water pump comes out.
ejanzen is offline   Reply With Quote
Old 09-18-2008, 05:22 PM   #8
illinipo
Token Engin-nerd
illinipo's Avatar
FF Member#: 37693
What I Drive: 2002 SE wagon "Ol' Blue" 199k miles
FF Reputation: 261 illinipo Outstanding Standing Memberillinipo Outstanding Standing Memberillinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (16)
our radiators dont really need burping the system is designed to remove air on its own over time
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline   Reply With Quote
Old 09-18-2008, 05:41 PM   #9
Andrius
FF Member#: 36322
I don't have AC so anyone have any other ideas on how to get my waterpump out without dropping the engine? I'm scared of that
-Andrius
Old 12-20-2008, 11:35 AM   #10
jezzej
FF Member#: 61385
What I Drive: 2002 PEPPER RED 1.8 ZETEC
FF Reputation: 1 jezzej Good Standing Member
Ztec Water Pump Removal
Just completed changing water pump on my Zetec 1.8
thanks for the advice as haynes obviously never did this job engine in.
hope these are some helpful points
I took off the A/C comp from it's pedistol as soon as i had the belt off
this makes undoing the water pump easier
as my engine has the round water pump you dont need to lower the engine.
after undoing the 4 bolts spin the water pump around so the pulley end is inside the housing. with care the pump pulley will now slip through the groove in the housing that is visible from the A/C comp view underneath.
with some gentle jiggling and turning the rest of the pump will follow.
try to observe how it comes out, because the new one needs to back in this way.
Job not to bad and no forcing was needed, its all about alignment.
anyway
thanks for advice as i would not of had a go without it.
jezzej is offline   Reply With Quote
Old 01-01-2009, 05:39 PM   #11
bazookajoe
FF Member#: 61625
What I Drive: 2001 white Ford Focus
FF Reputation: 1 bazookajoe Good Standing Member
Haynes needs their butts kicked for their removal instructions in this case.
I have just finished and I am worn out. Thank you so much for posting this, as it is how I finally got the water pump out after a google search sent me to these forums. I am replacing the motor mount also, as I've had a vibration coming from that side for some time now.
Thanks again!
bazookajoe is offline   Reply With Quote
Old 01-08-2009, 06:25 PM   #12
MNELSON400
FF Member#: 61796
What I Drive: 2000 fOCUS
FF Reputation: 1 MNELSON400 Good Standing Member
To replace the water pump you need to remove engine mount and drop the engine. I've got the Haynes too and the show it motor out.... How long did it take Ya?
MNELSON400 is offline   Reply With Quote
Bookmarks
Search this Thread:
Advanced Search
Similar Threads
The Focus Nation Boredom Thread... MattZX3 Focus Nation 39337 04-15-2009 02:10 PM
zetec water pump pulley eatsleeprave ZETEC Performance Chat 3 02-07-2009 11:11 AM
For Sale: Complete Water Pump Assembly SVT and Zetec. homegrown2nr Archive 0 09-06-2008 06:42 PM
Water pump clicking... Marko1962 Ford Focus Technical Chat 9 07-03-2005 02:20 PM
Copyright 2002-2010 FocusFanatics.com. All Rights Reserved : Terms of Use : Privacy Policy : Advertise Information : Site Map
