HOW TO: Install Kenne Bell Boost-A-Pump - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-09-2008, 03:04 PM   #1
focusguy87
I AM DA FOCI FANATIC
focusguy87's Avatar
Fan#: 40962
What I Drive: 03 Red EvO & 03 TURBO SVT
Points 9,232, Level 64
Points: 9,232, Level: 64 Points: 9,232, Level: 64 Points: 9,232, Level: 64
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 9 focusguy87 Good Standing Member
Buy-Sell-Trade Rating: (6)
First would like to thank Pete(Illinipo), and Kyle(KS1) for showing up and helping with the installs. Later we played with Kyle's car.....
Now for the BAP.
First, for SVT's the seats are pretty simple. Just pop off the plastic caps by pulling at the bottom and they should pop right off. After that grab the back of the bottom seats and the flip over exposing the carpet.
Other foci I believe have to unbolt the rear seats and remove them.
After that, for SVT's I found the best place for your light is to wedge it in between the notch cut out for the seat belts. IT WAS PERFECT!
Next, remove the side trim pieces at the base of the doors (ZX5). Then pull back the carpet exposing the Fuel Pump, wiring, and FPCM. Make sure you splice in between the Fuel Pump and FPCM.
I mounted my BAP under the driver's side rear seat. It dido's the placement of the FPCM on the passenger side. After placement you can extend and measure the amount of wire needed to reach the fuel wires, and ground. I ran my + wire behind the seat belts. Then my - was grounded to the seat belt bracket.
The ground is very important. If the ground is not efficient enough the BAP will not be able to run properly. Not shown in this picture but later I took a wire brush and wheel and made sure I had clean contact between the car, bracket, and bolt.
Next cut and splice into the Orange/Green Wire that is in between the pump and FPCM. Make sure the + Fused side goes toward the FPCM and the Signal goes toward the pump.
Then that leaves the Dial and Pressure switch, for the dial I wanted somewhere I could get to it, but also somewhere it would be impossible to bump, accidently kick..ect I chose to mount it in the truck behind the back seat in the sub compartment. Remove the interior carpet of the sub and expose the plastic wall.
Then mark where the dial will sit making sure its not to far back you can't get your fingers to it, but also not to far forward so the rear seat hits it when it comes back.
Then for the pressure switch I bypassed it by soldering the ends together and tucked the extra wire and the seat. Note you can not change the length of these wires.
If you choose to use it you will need to "T" one of you vacuum lines and run the wire accordingly up to the engine compartment. Then connect to the pressure switch that activates at 5 PSI.
After the put the carpet back install plastic trim pieces and put the seat back and your DONE!
Note I found this out:
With Engine "OFF" key in "ON" position
With No bap stock pump ran: 11.8v
With BAP install but ungrounded "Off": 11.3
With BAP grounded and "ON" but dial at 0: 13.2
I am not sure what to run with before I get my tune done.
FOR SALE,
2003 Turbo SVT ZX5 318WHP (SOLD)
2003 Evolution 8 320AWHP
focusguy87 is offline
Old 03-09-2008, 03:28 PM   #2
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
We should note that those voltages are with the engine off, just turning the key to on. The voltages should be higher with the engine on.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 03-09-2008, 03:32 PM   #3
focusguy87
focusguy87's Avatar
Fan#: 40962
Thanks pete......surprised your awake...lol
FOR SALE,
Old 03-09-2008, 06:28 PM   #4
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
Congradulations.... I'm making this a STICKY!!!!
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 03-09-2008, 06:29 PM   #5
IslandFocus
Fan#: 22161
What I Drive: 2000 Imperial Blue Focus ZX3
FF Reputation: 3 IslandFocus Good Standing Member
Great write-up!
IslandFocus is offline
Old 03-18-2008, 08:42 PM   #6
egbertnr
Focus Factor
egbertnr's Avatar
Fan#: 27383
What I Drive: 2011 Blue FX4 F150 SCREW Boosted
Points 10,886, Level 69
Points: 10,886, Level: 69 Points: 10,886, Level: 69 Points: 10,886, Level: 69
Level Up 9% Completed
FF Reputation: 7 egbertnr Good Standing Member
Very nice write up, I oculd of used this a whiile ago, but now Tom is taking care of that for me.
2011 F150 FX4 Blue Flame Metallic SuperCREW EcoBoost 371RWHP/458RWTQ
1986 Mustang Coyote Swap in progress
2013 Focus ST3 Performance Blue-Gone
89 Mustang 5.0 Turbo 670 rwhp-Gone
03 SVT Focus Turbo 326whp/278wtq-Gone
egbertnr is online now
Old 03-31-2008, 12:13 PM   #7
KS1
KS1's Avatar
Fan#: 46191
What I Drive: '04 Toreador Red Manual ZX3
FF Reputation: 4 KS1 Good Standing Member
Nice write up bro, and thanx for posting the pic of my dirty ass car, lol
and, depending how things go after my turbo install, I'll probably be doing this to my car pretty soon
Zetec Crew #159
"The road of excess leads to the palace of wisdom."
KS1 is offline
Old 03-31-2008, 01:01 PM   #8
focusguy87
focusguy87's Avatar
Fan#: 40962
Bring it back down if you need a place to work
FOR SALE,
Old 03-31-2008, 01:08 PM   #9
KS1
KS1's Avatar
Fan#: 46191
will do, I just ordered my 3" flex and resonated exhaust from Trubendz, so, my turbo should be ready for install, after that, I'm heading down to see Tom, then I'll probably need to come to Decatur for the BAP
I'm going to be busy as hell for the next couple months with the turbo install and work, it should be interesting
Zetec Crew #159
KS1 is offline
Old 08-03-2008, 08:18 PM   #10
kimbo305
kimbo305's Avatar
Fan#: 52390
What I Drive: '00 Zetec ZX3
FF Reputation: 12 kimbo305 Great Standing Member
I have a dead BAP I've been meaning to remove from my car. Assuming a pressure line on the intake side has already been T'ed for the pressure switch, what would I want to do to that setup to get rid of the BAP? could I just leave the pressure switch there?
check out my Fiesta Movement entry: youtube.com/watch?v=dXY3mi1NWeg&eurl=http://www.focusfanatics.com
I wholeheartedly endorse McNew's for installing and tuning your Focus.
kimbo305 is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
if u want a sc then u should read this good info blazealm General Forced Induction 15 01-26-2005 02:37 PM
how to you install a boost controller on a turbo evokona00 ZETEC Performance (2000-2004) 8 11-27-2004 08:35 AM
Who can install a fuel pump in NYC area? jericoholics Mid Atlantic Fanatics 0 10-03-2004 10:39 AM
Install Boost gauge xyzalvarez General Forced Induction 12 05-13-2004 11:23 PM
