Crank Position Sensor - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-07-2008, 10:17 AM   #1
SVTMAZ
Fan#: 44374
What I Drive: 2003, Infra Red, SVT Focus
FF Reputation: 1 SVTMAZ Good Standing Member
Hey Guys,
Just wondering if anyone out there knows how to or has changed their crank sensor? mine seems to be fried cause on my svt gauge when put into test mode i get no reading under cranking of the RPM's and the car won't start. so i figure its th crank sensor.
Thanks,
SVTMAZ
SVTMAZ is offline
Old 03-07-2008, 02:36 PM   #2
cafociguy
cafociguy's Avatar
Fan#: 21858
What I Drive: 01 ZX3, 03 ZX3 PWSCed
FF Reputation: 46 cafociguy Great Standing Member
Buy-Sell-Trade Rating: (4)
I believe that sensor is located on the back side of the block above the passenger side axle can't miss it, one torque bolt holding it in and the wires.
cafociguy is offline
Old 03-09-2008, 08:38 PM   #3
SVTMAZ
Fan#: 44374
I'm pretty sure on the SVT's it's on the front of the trans bell housing just to the right of the exhaust manifold but I was just wondering if anyone had one out before and how it was done?? thanks
SVTMAZ is offline
Old 03-10-2008, 08:45 PM   #4
SVTMAZ
Fan#: 44374
Crank Sensor Specs.
Hey all,
PLease help if you can. I have the crank sensor out of my focus, it was on the tranny bell housing by the exhaust manifold. I am bench testing it and i get up to 0.03Volts when pulling a piece of metal away from the sensor, this means it is picking it up but is the signal strong enough?? and it has 380Ohms of resistance at rest?? is this normal?? please halp my car won't start and I've noticed there is no tach reading on my gauge in the digital mode.
SVTMAZ is offline
Old 03-17-2008, 08:34 PM   #5
SVTMAZ
Fan#: 44374
C'mon Guys,
I know some of you on this forum must of had this problem before please help me out here??
SVTMAZ is offline
Old 03-17-2008, 09:13 PM   #6
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,240, Level 72
Points: 12,240, Level: 72 Points: 12,240, Level: 72 Points: 12,240, Level: 72
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 77 S0C0nFused Excellent Standing Member
I don't know if this is going to help you. I will give it a shot! Your testing a 'hall effect sensor'. your testing method is somewhat flawed. Using a piece of steel approximate size of the 'nub' on your flywheel, bring the metal across the sensor (imitate the motion of the flywheel). I would guess that a small screwdriver would work. Speed is less important than distance. do NOT use a magnetized screwdriver or anything magnetized (can ruin it). You will probably need an oscilloscope to view and measure the actual output. VOM are to slow. Hall sensors last a very very long time. I would suggest you instead look closely at the wiring. measure the voltage supplied TO the sensor (I.E. make sure the connector has not gone or going bad). Hall sensors typically have a pretty wide voltage range with a fixed current, and the output varies with the voltage if I recall correctly. Without the specific industry part number it is impossible to look it up.
Hope that helps!
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
clutch position sensor JustBlazed1217 General Technical Chat 5 08-14-2007 05:13 PM
SVT IMRC wiring AND ApexI turbo timer install kruptminz General Forced Induction 29 01-13-2007 08:34 AM
Throttle Position Sensor out of range? viper14062 General Technical Chat 2 01-16-2006 05:43 PM
Crankshaft Position Sensor Signal Wire? autocrossman DURATEC Performance (2003-2007) 12 09-15-2004 11:04 PM
