Leaking coolant and stinkin up the joint? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-06-2008, 04:10 PM   #1
F1shFocus
Fan#: 54135
What I Drive: 2001 Clound 9 White ZTS
FF Reputation: 1 F1shFocus Good Standing Member
I have a 2001 zts and I'm leaking coolant fairly quickly, but it doesn't go empty. Also, when I fill the reservoir, and turn my heat on, I get a very strong smell of coolant in the car. I'm thinking it's leaking onto something hot and the evaporation is being sucked in through the heater. I haven't had a chance to dig into it yet because it's been so damn cold, but just thought I'd ask if any of you have had the same problem to help guide me to the correct spot. Thanks!
Ernie
F1shFocus is offline
Old 03-06-2008, 05:08 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Thermostat outlet/housing on the engine is a quite common place to leak. Search the messages for more info.
penguin is offline
Old 03-06-2008, 08:00 PM   #3
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
Is the floor wet with coolant? Does the windshield fog up inside when you put the defroster on? These things are caused by a leaking heater core.
Often wrong but never in doubt.
Blurvfocus is offline
Old 03-21-2008, 03:02 AM   #4
F1shFocus
Fan#: 54135
No wetness on the floor and not fogging up. I've found if I turn on the recirculation, I don't get the smell in the cab.
Old 03-21-2008, 10:59 AM   #5
eayste
eayste's Avatar
Fan#: 52333
What I Drive: 2000 White SE
FF Reputation: 1 eayste Good Standing Member
I'll 2nd what Peguin stated , as I had the same issue with my car.
I found the gasket/seal that goes between the Thermostat housing and engine block had a crack in it , and a small cut in one of the hoses that run into the thermostat housing.
Is there coolant on the ground after you stop ? Is it on the drivers side or dripping of the transmission ?
If so , then start looking in the housing area.
eayste is offline
