Performance numbers for my SVT (see inside) - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-08-2008, 07:21 PM   #41
pelotonracer2
pelotonracer2's Avatar
Fan#: 49917
What I Drive: 2014 Ford Fiesta ST
FF Reputation: 17 pelotonracer2 Great Standing Member
Aerodynamics
Originally Posted by CaysE View Post
How did you test the cowl induction? It seems unlikely as they are still a good distance from the windshield.
The vacuum is always there at speed... air is flowing over the hood and vents, pulling air out of the vents. With the vents facing the opposite direction, you'll have less resistance into the intake. As you said, it's not sealed though, so you're likely just getting a portion of air from the vents and the rest from whatever openings are around the airbox.
Testing is easy. I used a plastic bag taped underneath the open squares where the vents were going to be. Depending on suction, the bag moves up or down... With a mostly sealed box, the filter was pulling the bag down (especially at higher throttle openings). It's an easy and effective way to test for high and low pressure areas.
My airbox is sealed more than that, just not a "pressurized" system such as a ram air. I'd say 90% or more of the air has to be coming IN from the vent. I did this mainly to isolate the filter from underhood air. But then there's really not enough area to "pull" air from under or around the filter and there is not a steady stream flowing under the hood and up through the vents (thanks to the mostly sealed box).
The further back on the hood the less pressure there is until you get to the cowl area. This has more to do with the aerodynamics of this particular front end design and the shape of the hood than anything else. The part of the hood where the vents are is a low pressure area (outside of hood). Also, the cowl area creates a swirling effect and there is very little suction unless there is an actual opening or bowl area. The cowl pressure is effected by the shape of the hood and the rake and angle of the windshield. The lower angle of the windshield, the less cowl disturbence there is. Cowl turbulence or using it as a form of induction might be ok for drag racing but it actually can cause more CD at higher speeds such as oval racing or flat out top speed runs.
The frontal area of the car pushes the air outwards until it hits the upper half of the windshield or the roofline. The rear half the hood up until the cowl area there is not much movement of air, at least not enough that would adversely effect performance. Air coming over the top of windshield and roof is what creates the actual "cowl" phenomenom. This only works *IF* there is a place for the air to escape (ie: an opening). If you've ever seen a car inside a wind tunnel you be able to see the actual stream line of the air as it goes over the entire body of the car. There is very little pressure that far back on the hood. This is the biggest reason a properly designed ram-air system is placed in a high pressure area (usually at the front and radius of the hood).
There is less wind resistance the further downstream you get from the initial (offending) frontal area (the area actually cutting or splitting the wind) until a convergence point. A more streamlined rear portion of a car is much more aeodynamic than a wedge (like our hatchback is). For instance, stick your hand outside your window 6" from where the glass would be (like where your side mirrors are for instance) and then stick your hand out 2-3 feet. If you could do it further back on the car, the more it would make drag. The faster you go, the bigger the difference but you get the idea. This is because the air does NOT hug the curvatures and surfaces as you suggest. Air hits a frontal area (high pressure) and there is a certain amount of "deflection". This is normal.
This is one reason you need a BIG rear spoiler (v.s. a smaller one) to catch and apply downforce to the rear of an automobile.
Suspension heigth also plays a very important role as well. Keeping air from going UNDER the car adds more down force and makes it stick better at high speeds. Doing so also creates more frontal area and LESS pressure closest to the actual surface of the car. That's why you have a fan shroud on most cars (it creates more frontal area to catch more air and literally force it through the radiator which of course then there is a heat transfer/exchange). Just ask any NASCAR driver how much of an effect taping the front air inlet areas and how it effects aerodynamics, downforce and drag.
Again, if you study the slipstream of a car in a windtunnel, you'll see that the more aerodynamic the body shape, the less frontal area there is and the less coefficient of drag you will have. This also effectively moves the slipstream closer to the body (as it isn't pushed outward as much as a squared shape would). On most production cars (and especially hatchback designs), you will see that most of the air moving over the body of the vehicle is several inches to a foot or more from the actual surface depending on the area of the car. These "high slipstream" areas are what are called low pressure areas below the "line". If my vents were closer to the front of the hood (where a high pressure area exists at higher road speeds) or at the second half of the windshield/roofline for instance, then there would definately be some issues, especially if air was able to be dragged from under the car and through the vents.
Usually cars with good coefficient of drag, utilize lower body panels to funnel the air BACK smoothly instead of up through the engine bay and over suspension parts which create significant drag. As you get to the rear of the car, you want to straighten the air as much as possible as otherwise it will cause turbulence, LIFT and subsequent drag. A properly designed under spoiler, rear apron or diffuser is will straighten the flow of air as it exits the underbody.
NACA ducts are better "air scoops" in low pressure areas and that's why they are used on racecars in odd areas. NACA function involves a venturi effect which I'm not going to discuss in this thread (it would be TMI at this point).. hehehe. Some "production" cars (Viper and Z06 Corvettes) use NACA style ducts for ram-air but they are mostly for styling than actual function (they look sweet)
Go FAST or go HOME! 2014 Ford Fiesta ST
pelotonracer2 is offline
Old 03-08-2008, 10:18 PM   #42
pelotonracer2
Fan#: 49917
Originally Posted by MVent View Post
How do you determine what direction the plugs are facing?
Take a magic marker and make a mark on the socket. Make the same mark in exactly the same place at the very top of the extension so you can see it as you are tightening down the plug. Insert the plug with the ground electrode facing out (aligned with both marks). Wherever the "mark" on the top of the extension ends up facing once the plug is snugged down, is the direction of the opening of the ground electrode.
Old 03-08-2008, 10:36 PM   #43
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
OK you went waaaay overboard on the explanation. LOL...
My question wasn't "are you getting air into the vents" which I'm sure you are. My question is how you're able to determine that air is going in via cowl effect, or just engine vacuum. Obviously air is going in... but you have to get pretty close to the windshield to actually get a cowl induction going.
CaysE is offline
Old 03-09-2008, 12:54 AM   #44
FrozenFoci
FrozenFoci's Avatar
Fan#: 41195
What I Drive: 2002 InfraRed SVTF
Points 237, Level 4
Points: 237, Level: 4 Points: 237, Level: 4 Points: 237, Level: 4
Level Up 74% Completed
FF Reputation: 3 FrozenFoci Good Standing Member
I feel like I just got a lot smarter. Or at least better informed...
'02 InfraRed SVTF, #2,783/4,788: Tom's tune; JayRacing HFC; Hawk pads; Torsen ATBD; CFM pulleys, mounts, and STS; Screamin Demon & Livewires; AEM-esque CAI; lunchbox hack; EAP rims; 2" German antenna.
For Sale!!
FrozenFoci is offline
Old 03-09-2008, 01:37 AM   #45
pelotonracer2
Fan#: 49917
I tend to go overboard sometimes...
Yes and you'd be correct, not much cowl action is happening, but at higher speeds it does a little. If a car is using plastic covers underneath (especially the front half of the car) "cowl" type pressures are nearly non existant.
I just figured a little info on aerodynamics might be beneficial.
Similar Threads
"The Official/Unofficial SVT Header Conversion Guide" svtguy88 ZETEC Performance (2000-2004) 110 07-05-2013 02:54 PM
Svtoa goixoye SVT Performance (2002-2004) 16 03-22-2007 08:08 PM
Poppin3000's 3-Day SUPER SALE. SVT parts inside! poppin3000 Archive 18 03-05-2007 11:21 AM
how to get svt performance out of a zetec? chad_p71 ZETEC Performance (2000-2004) 18 11-08-2006 11:51 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
