Go Back   Focus Fanatics > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 03-11-2008, 04:08 AM   #21
akmer
Fan#: 25083
What I Drive: 2004 Infra Red zx3
FF Reputation: 2 akmer Good Standing Member
Buy-Sell-Trade Rating: (4)
did you took it to the track alrady?
akmer is offline
Old 03-11-2008, 07:15 AM   #22
BOOSTA
BOOSTA's Avatar
Fan#: 36047
What I Drive: 2003 White ZX3 2.3L Turboed Duratec
FF Reputation: 8 BOOSTA Good Standing Member
Buy-Sell-Trade Rating: (11)
Squilly is your car stock besides the Nitrous?
----The Honda Eater----
BOOSTA is offline
Old 03-11-2008, 07:19 AM   #23
BOOSTA
BOOSTA's Avatar
Fan#: 36047
sorry for the million questions but lets say you set it at 3000 rpms to kick in and 6500 to end in first gear, would it kick back in at 3000 rpms in second gear as well?
BOOSTA is offline
Old 03-11-2008, 10:22 AM   #24
ShadowStrike
ShadowStrike's Avatar
Fan#: 48473
What I Drive: 2003 Yellow ZX3
FF Reputation: 1 ShadowStrike Good Standing Member
haha.. Billy needs to do another nitrous sticky.
And I have yet another question. You probably don't want the nitrous in first gear, but if you have the window switch set to go at 3k rpms, how would you get it to not spray?. Only way I can think of is not having it at WOT.. but that would obviously mean your not pushing your engine as hard as you could. Is there any other way?
And BOOSTA, I believe he has intake/exhaust and answer your second question, yes, as long as you have it at WOT.
2003 ZX3 - Repoed.
2000 Kia Sportage
Looking for a SVT
ShadowStrike is offline
Old 03-11-2008, 11:30 AM   #25
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
What I Drive: SC 5.0 FOFO BUILD IN PROGRESS
FF Reputation: 106 SquillyB Excellent Standing MemberSquillyB Excellent Standing Member
akmer, I went from a 17.5 car to a low 15's car with out the traction control switch installed, just using the TPS (throttle position sensor) and my foot. The ZEX rep said another .5 seconds should be reachable with the traction control switch in.
Boosta, I have a modified version of the stealth intake, and a custom exhaust. With the window switch in I am spraying first gear now as I was NOT before. When going down the track with just the TPS switch installed I would launch, count to two and spray, a heela wheels spin would occur all the way into the middle of second gear, then it would grab and I'm gone!! Now with the TCS switch in I have set it to spray in every gear, from 3100 rpm to 7100 rpm. I have yet to go back to the track with the new switch in but I can tell you I have minimal wheel spin now and that car is fo sho faster than last track day which my best run was a 14.91, my top speed so far in the 1/4 has been 99 mph! Almost a 100 but not quite. With the window switch you can pick how many times the unit has to pass the cut off rpm point before it engages, essentially you can skip gears if you want. Like if you had a turbo and only wanted N2O to spray in the very begining for a brief second to eliminate the "lag" you could easily do that.
MECP 1ST CLASS
FF08 FASTEST OVERALL TRACK TIME
SquillyB is offline
Old 03-11-2008, 01:44 PM   #26
akmer
Fan#: 25083
dang that is pretty darn good...im just too much of a to run nitro on my car
akmer is offline
Old 03-11-2008, 03:05 PM   #27
BOOSTA
BOOSTA's Avatar
Fan#: 36047
lol, he me too kinda, afraid it might blow up. Now is there a switch that turns the nitrous off? Cuz i dont want it to go on each time i got the pedal at WOT!
BOOSTA is offline
Old 03-11-2008, 03:34 PM   #28
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
ok, to clarify for every one.
When you install a TPS (throttle position senor) switch it detects the amount of voltage going through the out put of the pedal sensor to the ecu to tell everything else what to do ie, shifting pressures, fuel regulators, etc. So you driving, just chill. A V8 stang rolls on you at the light and rev's ya. Go time. Two options here
a- green light, you floor it then manually throw the switch to activate the nitrous oxide and woosh your out.
b- you turn the switch on now, then light goes green. You take off and feather the pedal over about a two second time span to get into higher rpms, then stomp it to the floor, whoosh your gone.
The traction control switch is the best of both worlds. It won't activate unless you stomp it, but it takes a second or two for the rpm's to get to where ever you set it, which you control when it starts to spray and when it stops, but NO MATTER WHAT IT WILL NOT SPRAY DURING A SHIFT!!
MECP 1ST CLASS
SquillyB is offline
Old 03-27-2008, 10:27 PM   #29
FocusFreak87
FocusFreak87's Avatar
Fan#: 28487
What I Drive: 2010 Toyota Tundra SR5
FF Reputation: 2 FocusFreak87 Good Standing Member
What if your pedal doesnt go all the way to the floor?? (Aftermarket pedals??)
Go STEELERS!!!
TEAM DURATEC #108
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature
Metal... is... AWESOME!!!
FocusFreak87 is offline
Old 03-27-2008, 10:52 PM   #30
MightyMouse
Scuba Edition
MightyMouse's Avatar
Fan#: 34537
What I Drive: 2006 Liquid Gray ST (Scuba Edition)
FF Reputation: 20 MightyMouse Great Standing Member
It will still learn it. You push a button get in the car push the pedal all the way down and after a certain amount of time it reads the voltage and saves it. After that whenever it reads that voltage again it activates the solenoids and bam instant power.
ST Crew #32
FocusFest 2008 and 2009 Fastest NA, 2009 Fastest FI Runner-Up, and 2008 Bracket Winner
MightyMouse is offline
Similar Threads
For Sale: Full Zex wet nitrous setup netdrgoon Archive 0 05-08-2007 01:42 PM
Nitrous & the ATX opus1 General Forced Induction 1 08-11-2006 06:46 PM
how to get best drag launch?? ozan Drag Racing 22 04-06-2006 10:00 PM
NOPI TV & Car Show/NDRA Drag Race - Memphis, TN 7/30-31 Sally Fanatics: AR, LA, MS, OK 1 07-24-2005 11:13 PM
How Do You Race an ATX PZEV P0WeRbyDuratec DURATEC Performance (2003-2011) 18 12-24-2003 02:05 PM
