Drag race the ATX with Nitrous?! HELP?! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 03-06-2008, 12:48 AM   #1
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
What I Drive: SC 5.0 FOFO BUILD IN PROGRESS
FF Reputation: 106 SquillyB Excellent Standing Member SquillyB Excellent Standing Member
So I bought a Nitrous kit as some of you may know already. This question is for the guys/gals that are drag racing their atx with nitrous?
What to do about the vicious wheel spin until I can buy drag radials?
Any tips on getting down the track the fastest are what I'm looking for, ie. smaller pill set up, larger pill but only spray in __ gears, etc., etc..
Thanks in advance!
BTW, I am currently running a ZEX TPS switch but I also have a ZEX traction control switch to hook up still. When I tried to hook them both up it wouldn't work, did one default the other? The problem is I am waiting for a MSD tach driver so I can hook up the window switch portion and set the proper rpm's as I currently have no way of hooking up the rpm sensor wire to tell the switch when to open accuratly and when to close.
MECP 1ST CLASS
FF08 FASTEST OVERALL TRACK TIME
SquillyB is offline
Old 03-06-2008, 12:59 AM   #2
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
FF Reputation: 272 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
You could get a track-only tune that doesnt let the trans shift until 5500rpm or so in each gear... cuz those bouts from 1st to 3rd due to wheelspin are no fun when the clock is ticking
I believe its as simple as changing the minimum shift mph in the shift schedule.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
Old 03-06-2008, 01:00 AM   #3
blackoutSVT
Lurking
blackoutSVT's Avatar
Fan#: 52102
What I Drive: 86 sportster1100, 12 Focus SE Sedan
FF Reputation: 9 blackoutSVT Good Standing Member
Buy-Sell-Trade Rating: (15)
well i can give you some advice.. first off don't spray off the line. hit it about mid track you don't have a drag car per say the only time nitrous is good off the line is when you are running slicks. i would also be careful putting slicks on your focus with out changing out the Differential. could snap the one you got on it... if you are having trubble getting traction try heating your tires in the water trap if they will let you or bring a portable torch with you but if you go that rout be careful of that don't want to blow out your tire.lol the goal is to heat your tires up so they kinda melt a little so you will get better traction. but no need to lower the amount of nitrous you are using just don't spray off the ling and you should be gold.
blackoutSVT is offline
Old 03-07-2008, 01:18 PM   #4
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
Well tonight are the races so wish me luck. I won't spray first cause a couple people have said that so far in other threads. Man I wish I had a few more replies from other Nitrous racers.
Oh well..
MECP 1ST CLASS
SquillyB is offline
Old 03-07-2008, 03:24 PM   #5
besthaticouldo
i wear no pants
besthaticouldo's Avatar
Fan#: 26970
What I Drive: '11 OBP WRX Sedan
Points 32,001, Level 100
Points: 32,001, Level: 100 Points: 32,001, Level: 100 Points: 32,001, Level: 100
Level Up 0% Completed
Forum Activity 6%
FF Reputation: 104 besthaticouldo Excellent Standing Member besthaticouldo Excellent Standing Member
Buy-Sell-Trade Rating: (23)
can you not spray in first billy?
that would be my best guess...cuz if you wait til the middle or end of first to start spraying you might eliminate some
remember that building a car shouldn’t come from parts it should come from deep inside your soul. let the car speak for all the emotions, memories and experiences youve made and the car will take a life of its own. truth over fame.
besthaticouldo is offline
Old 03-07-2008, 03:59 PM   #6
Xetchx
Xetchx's Avatar
Fan#: 49113
What I Drive: 03 Silver SVT
FF Reputation: 23 Xetchx Great Standing Member
for a 5 speed it's simple, always purge at the light next, unless you can redline launch and not spin the tires NO N2O in first, secound gear is debatable it all depends on how many RPMs you have left in that gear after you shift. The idle spot would be bottom of third as soon as the RPMs start climbin steady spray it till just before redlne. shift reapeat
High oct gas will help too, say 100oct.
yes Billy I know I dont have spray on my Fofo, but my truck used to and it was a 5spd Auto.
oh yeah Drag radials will help but if your just gonna use them for the 1/4 mile track just get some slicks, small light wieght rims and upgrade the halfshafts.
Also not all drag racers LAUNCH there car, becasue they say it too hard on the car. So E/T is good but getting down the track afterward is still requiered. LOL
See ya tonight dude, oh and I wanna drive it LOL
"If you’re going to lead, then lead. If you’re going to follow, get the hell out of my way"
Originally Posted by Trav-E2.0 View Post
I'm not hard, I'm fluffy...lol
#2846
Xetchx is offline
Old 03-08-2008, 03:48 AM   #7
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
^^^ all proven correct tonight except I can spray in second gear at the low to middle of the torque band and only spin a little bit. I'm thinking if I use the 75 I could wait a tick longer, more toward the middle'ish area and have no problem. Last time I tried though I spun them at about a 40 roll when it hit. Need to wait till closer to 45-50ish and the hammer in the 75 or the 100 shot till the beams.
MECP 1ST CLASS
SquillyB is offline
Old 03-08-2008, 03:52 AM   #8
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
I let the car shit itself with the O/D off aand due to the TPS switch when it shifts the voltage drops so it doesn't spray. Now I can leave the toggle off, run 1st, 2cnd up to about 3300-3500 rpm and THEN stand on it and throw the switch. However this gets me HUGE amounts of torque steer and I pee myself from the jolt up my spine.
I have a ZEX traction control/window switch that will let me set the rpm to start spraying at as well as when to shut off. What I'm looking to get is the one that will stagger the spray and ramp it according to rpm's, thats the shizzle in my I's!!
MECP 1ST CLASS
SquillyB is offline
Old 03-09-2008, 02:49 PM   #9
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
Talking
I am considering a tune, some drag radials and other things. My question is in what order should I do them to be able to continue to race while modding. Also my current tune shifts at 7250 @ WOT unless you feather the pedal to force the shift or are manually shifting the gears yourself.
MECP 1ST CLASS
SquillyB is offline
Old 03-09-2008, 02:55 PM   #10
SquillyB
4.9L SC Stroker !!!
SquillyB's Avatar
Fan#: 45801
Originally Posted by blackoutSVT View Post
well i can give you some advice.. first off don't spray off the line. hit it about mid track I currently hit the switch at about 3500 in second gear you don't have a drag car per say the only time nitrous is good off the line is when you are running slicks. i would also be careful putting slicks on your focus with out changing out the Differential. could snap the one you got on it...How does this happen? if you are having trubble getting traction try heating your tires in the water trap if they will let you they let me but I have always found I can chirp them pretty good just to clean the dirt and dust off and get em' a little warmer and run quicker from the gate. The box sprays water up into the wheel wells that drips back down at the line causing excess spin or bring a portable torch with you but if you go that rout be careful of that don't want to blow out your tire.lol the goal is to heat your tires up so they kinda melt a little so you will get better traction. but no need to lower the amount of nitrous you are using just don't spray off the ling and you should be gold.
Thanks, I have a window switch I need to wire in soon, hope that helps
MECP 1ST CLASS
SquillyB is offline
Similar Threads
For Sale: Full Zex wet nitrous setup netdrgoon Archive 0 05-08-2007 02:42 PM
Nitrous & the ATX opus1 General Forced Induction 1 08-11-2006 07:46 PM
how to get best drag launch?? ozan Drag Racing 22 04-06-2006 11:00 PM
NOPI TV & Car Show/NDRA Drag Race - Memphis, TN 7/30-31 Sally Fanatics: AR, LA, MS, OK 1 07-25-2005 12:13 AM
How Do You Race an ATX PZEV P0WeRbyDuratec DURATEC Performance (2003-2007) 18 12-24-2003 03:05 PM
