How To: Aftermarket radio wiring with stock SVT sub and amp. - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-14-2012, 02:37 PM   #51
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,193, Level 34
Points: 3,193, Level: 34 Points: 3,193, Level: 34 Points: 3,193, Level: 34
Level Up 96% Completed
Forum Activity 14%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
thank you will be using this very soon
qweesy is offline
Old 12-25-2012, 12:31 AM   #52
04CompOrngSVT
04CompOrngSVT's Avatar
Fan#: 89598
What I Drive: 2004 Comp Orange SVT-EAP
FF Reputation: 1 04CompOrngSVT Good Standing Member
works great thank you!!
compition orange SVTF: mbrp 2.5" cat back, ORP w/ o2 cheater, H&R coilovers, aem cai, CFM adjustable short shifter, taylor 8.2mm wires, more to come as the money comes.
04CompOrngSVT is offline
Old 03-25-2013, 09:26 AM   #53
Lackanookie
Fan#: 111747
What I Drive: 2002, Black, SVT
FF Reputation: 1 Lackanookie Good Standing Member
I finished up the install of a pioneer 2Din Appradio thanks to the how to posts.In was able to use the existing factory amp and sub thanks to the posts. The new system works flawlessly. Can't say thanks enough.
Lackanookie is offline
Old 06-07-2013, 10:39 AM   #54
Focus112
Focus112's Avatar
Fan#: 50026
What I Drive: 2002 SVT Focus
Points 3,634, Level 37
Points: 3,634, Level: 37 Points: 3,634, Level: 37 Points: 3,634, Level: 37
Level Up 90% Completed
Forum Activity 5%
FF Reputation: 5 Focus112 Good Standing Member
For the amp speaker wires, anyone know which is positive and which is negative. I have grey and white
Focus112 is online now
Old 09-29-2013, 09:38 PM   #55
ausatz
ausatz's Avatar
Fan#: 117782
What I Drive: 2002 Sonic blue SVT
Points 596, Level 11
Points: 596, Level: 11 Points: 596, Level: 11 Points: 596, Level: 11
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 1 ausatz Good Standing Member
Good post worked for me! I looked for a while and this was the best post i could find. You used a couple unnecessary wires but it works. I just went straight from the RCA cable to the sub control wires on the plug.
ausatz is offline
Old 05-03-2014, 07:19 PM   #56
MitchellC
Fan#: 29029
What I Drive: 2003 Pitch Black SVT ZX3
FF Reputation: 1 MitchellC Good Standing Member
I know that this thread is a bit of a dinosaur, but it was a big help in adapting the factory subwoofer to the head unit I just installed. There was one thing that I did differently, though, that others may be interested in.
I didn't like the idea of tapping into the car's body harness for the steering wheel controls and subwoofer wiring. I wasn't planning on reusing the factory radio, so I took it apart and removed the female plug from the board. You will need a T-9 bit for the screws; I had it on a folding pocket Torx set. I softened the solder with an iron, and then pushed the wires through with a screwdriver. Flush wire-cutters would have been 100x easier, but I don't have any, and I didn't want to go to the store.
I then straightened out the plug's wires, and ended up with this:
Here is my harness with everything is soldered and shrink wrapped:
And everything installed. Hooray!
The head unit is a Pioneer DEH-X7500HD that I picked up from Crutchfield, with an Axxess ASWC-1. The DEH was the cheapest head unit I found with subwoofer pre-out/steering wheel control capability/HD radio/USB input.
Hope this all helps.
2003 3-door Pitch black non-EAP
MitchellC is offline
Old 05-06-2014, 12:28 AM   #57
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 14%
uh can I get labeled wires and some hi res pics i can zoom in on? very nice job.
qweesy is offline
Old 05-06-2014, 02:27 PM   #58
streetfocus
streetfocus's Avatar
Fan#: 5768
What I Drive: 2004 Black Focus SVT
Points 2,551, Level 30
Points: 2,551, Level: 30 Points: 2,551, Level: 30 Points: 2,551, Level: 30
Level Up 68% Completed
FF Reputation: 2 streetfocus Good Standing Member
What about the steering wheel controls? I don't see that part.
05 ZX3: Steeda intake, 67mm TB, custom 2.5 Magnaflow exhaust, Tom's Tune.
New: 04 SVT : K&N panel filter, 3 performance motor mounts, Taylor wires, orp, 67mm TB, Tom's Tune.
streetfocus is offline
Old 05-13-2014, 10:39 PM   #59
VinnyB
VinnyB's Avatar
Fan#: 97705
What I Drive: '03 Screaming Yellow EAP
Points 1,199, Level 18
Points: 1,199, Level: 18 Points: 1,199, Level: 18 Points: 1,199, Level: 18
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 18 VinnyB Great Standing Member
Do you need help with the wiring? It's pretty simple, when is all said & done.
On the RCA plug, the center wire (the wire with the protective insulation around it) is the +.
The wire wrapped around the center wire, is the -
Regarding the actual wiring, it goes like this:
On the RCA plug, the center wire (the wire with the protective insulation around it) will get tapped into the black/white wire on the harness.
On the RCA plug, the outer wire (the wire around the protective insulation) will get tapped into the black/gray wire on the harness.
On the radio harness itself, (consult the manual for your specific model radio if you're not sure), the remote power wire is usually blue, or blue with a white stripe. If you happen to have both (like I did) you want the wire labeled "remote power" or something similar (the other blue wire was for a power antenna).
The "remote power" wire, is going to tap into the red & white wire on the amp/sub harness (the third harness in the pics on the first page)
Hope this helps!
VinnyB is offline
Old 05-14-2014, 01:04 AM   #60
qweesy
qweesy's Avatar
Fan#: 12042
Forum Activity 14%
Hope this helps!
I have an 04 SVT im going to PM you...... trying to figure out what you did with that plug
qweesy is offline
