How To: Aftermarket radio wiring with stock SVT sub and amp. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2008, 12:16 AM   #1
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
What I Drive: 2014 ford
Points 16,124, Level 81
Points: 16,124, Level: 81 Points: 16,124, Level: 81 Points: 16,124, Level: 81
Level Up 55% Completed
FF Reputation: 23 MattZX3 Great Standing Member
Buy-Sell-Trade Rating: (4)
Hey, just wanted to post this up for all of you svt guys, helped out another member on here with this wiring.
If you want to replace the audio-pile with an aftermarket, but want to retain the stock sub, follow this wiring and you should be all set
When installing a deck in a 2003 Focus SVT I was able to integrate the factory sub amp using the extra 7 pin plug from behind the factory radio. the wiring in the plug is as follows:
white/green-
yellow/brown-
white/red- amp turn on (6volts)
white/black- column control(resistance)
brown/yellow- column control (power)
white/black- pre amp output (+)
grey/black- pre amp output (-)
I used a 249 OHM resistor to drop the amp turn on (white/red)voltage so that the sub doesn't pop when the radio is turned on/off. Using a male RCA connector, you can wire into the low level factory input wiring (white/black,grey/black) so that it will accept the female sub output on the aftermarket radio.
Make sure that the new deck has an adjustable/low-pass sub out, or you will need an adjustable crossover. Good luck, and have fun!!
Step 1:
Cut the RCA cable in half and strip it like this: The white area is the positive and the other area is negative.
Step 2:
Cut two 1-foot (1 Red, 1 Black) of 16-gauge wire and connect it to the spliced RCA wires from Step 1. Red with positive and black with negative. Note that the RCA end will plug into the sub output from your receiver.
Step 3:
Cut another 1-foot of 16-gauge BLUE wire and connect it to the red and white wire. This wire is for the remote (turns your amp on and off with the ignition position).
Step 4:
Cut another 1-foot of 16-gauge RED wire and connect it to the black and white wire. This wire is for the positive sound input.
Step 5:
Cut another 1-foot of 16-gauge BLACK wire and connect it to the black and grey wire. This wire is for the negative sound input.
Step 6:
Now you would connect the Red & Black wires together from Step 2 to Step 4 & Step 5. (Which completes the sound inputs)
Step 7:
The BLUE wire from Step 3 needs to be connected to the remote switch wire from your deck (This color varies depending on your head unit model, consult your owner's manual). If you get a popping noise then you will need to install Resistor between the two to lesson the load.
MattZX3 is offline
Old 01-30-2008, 04:01 PM   #2
Sonicbluezx3
.....NObama.....
Sonicbluezx3's Avatar
Fan#: 8674
What I Drive: 05 Sonic Blue ZX3
Points 11,396, Level 70
Points: 11,396, Level: 70 Points: 11,396, Level: 70 Points: 11,396, Level: 70
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 2%
FF Reputation: 18 Sonicbluezx3 Great Standing Member
Buy-Sell-Trade Rating: (9)
Got any pictures?
Sonicbluezx3 is offline
Old 01-30-2008, 04:38 PM   #3
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
i unfortunately do not...
i do believe another member or two have used this wiring, so hopefully they either have pics, or can pull the radio out to take some pics
MattZX3 is offline
Old 02-26-2008, 10:07 PM   #4
pat247
pat247's Avatar
Fan#: 27781
What I Drive: Focus SVT
FF Reputation: 19 pat247 Great Standing Member
Buy-Sell-Trade Rating: (17)
After searching around for wiring info for the stock SVT sub and amp, and unable to find any usable info. I decided to make a small "how-to" for you guys.
Solder and shrink wrap wiring harness connections
Wrap wire loom around wire bundles (so it looks good)
Strip single RCA cable and twist core wire and shield wire like shown.
Solder "male" spade connector to blue/white wire.
Solder Blue/White wire to the White/Red wire.
Solder RCA core wire to the White/Black (+) wire.
Solder RCA Shield (negative) wire to the Grey/Black (-) wire.
Shrink wrap connections
Will update with more pics of the sub wiring harness later.
If anyone has any questions I will answer them as best I can.
2003 ZX5 SVT, Pitch Black, JRSC/BBK Sold
pat247 is offline
Old 02-27-2008, 01:04 AM   #5
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
look about two or three thread up and i posted about it, im actually going to merge those threads, because you have pictures..
when i did the install, i didnt take any pics.. so ill merge the two threads together
MattZX3 is offline
Old 02-27-2008, 01:10 AM   #6
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
threads merged
MattZX3 is offline
Old 03-02-2008, 07:47 PM   #7
focusguy87
I AM DA FOCI FANATIC
focusguy87's Avatar
Fan#: 40962
What I Drive: 03 Red EvO & 03 TURBO SVT
Points 9,232, Level 64
Points: 9,232, Level: 64 Points: 9,232, Level: 64 Points: 9,232, Level: 64
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 9 focusguy87 Good Standing Member
Buy-Sell-Trade Rating: (6)
this is great good jobs guys!
FOR SALE,
2003 Turbo SVT ZX5 318WHP (SOLD)
2003 Evolution 8 320AWHP
focusguy87 is offline
Old 04-03-2008, 06:18 PM   #8
lildudeinacar
lildudeinacar's Avatar
Fan#: 49485
What I Drive: 2003 Black SVT
FF Reputation: 6 lildudeinacar Good Standing Member
Just my luck, now i gotta buy a stuiped crossover..... and now i got to hope and pray that i dont screw up this simple wire job.
2003 SVT ZX3 Build # 2002 Birth: 5/20/03
"You know you drive a SVT Focus when... you take evey single off ramp or turn at double the suggested speed. "
Have you ever shifted so hard that you fart...
lildudeinacar is offline
Old 04-25-2008, 10:31 AM   #9
FOCUSSTDRIVER
FOCUSSTDRIVER's Avatar
Fan#: 50034
What I Drive: 2007 pitch black zx4 st SAP1
FF Reputation: 4 FOCUSSTDRIVER Good Standing Member
Buy-Sell-Trade Rating: (7)
um will this work on 2007 focus?
07ST
ST Crew #82SAP Crew#19
FOCUSSTDRIVER is offline
Old 04-25-2008, 08:38 PM   #10
WUGcatsvt
Obama Can't Gymkhana
WUGcatsvt's Avatar
Fan#: 36697
What I Drive: 02 SVT, 86 BMW E30, 10 VW GTI
FF Reputation: 62 WUGcatsvt Excellent Standing Member
Buy-Sell-Trade Rating: (18)
double
"No, the Focus is SLOW and just kinda stays that way."-Joe GCR SCCA VP
gumpcrew#10
Gulf Coast Region #12 - Me-45 DSP
My Girl-451 DSPL
WUGcatsvt is offline
